Question about Philips Magnavox 51MP392H Rear Projection Television
TV won't work with rabbit ears
I have a 19" Magnavox flat screen the tv is only 3 years old i unpluged
the cable for dish tv and put rabbit ears now i get no picture
  • Anonymous Mar 13, 2014
    How to hook up a rabbit ears to this tv
You must change the input on the system to be AIR/Antenna , the way it was before was set to cable/dish/DTV.
The tv sees the input different.
Posted on Jun 08, 2008
How do you connect rabbit ears to a tv
First you may need a 300 ohm to 75 ohm transformer if you have a flat wire with 2 leads coming out of the rabbit ears..you can get one at walmart, I attached a picture of what they look like...hook the 2 terminals from the rabbit ears to the transformer and plug it into the round terminal of the tv, set the tv to cable or antenna, what ever it has for settings, unfortunately though you may not get all that much with old rabbit ears as they are lower frequency pickup than the new HD channels run on.
aceb6079-dc98-4da7-926e-7d52885feaff_1.13301fb611a36dff57b92b05b4fdcbd5-j2qglkibcccvgpapoz0ib4qd-2-0.jpeg
Nov 08, 2017 | Televison & Video
Trying to get DTV, I can't figure it out
If you are in the US you need a digital reciever, rabbit ears or otherwise and have since February. That when all US broadcasters switched to digital broadcast. If it's more than about 5 years old you will likely have to purchase a new TV.
Jun 02, 2009 | Akai LCT3201TD 32 in. LCD Television
Does this TV need a converter box?
if you are on antannae only yes you will need one if you are on cable you shouldnt need one
Feb 23, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
We have a new HDLCDVD220 Sansui television. The rabbit ears antennae we were using on our old tv worked ok, but on this one. its awful. There is almost no color and terrible reception. We were told to get...
You mentioned rabbit ears for old tv, how old are the rabbit ears? Time and humidity will make rabbit ears lose connections internally. Also, if your old rabbit ears have the flat cable going to the tv you probably had to add a converter to go to the new tv. The flat cable will lose signal strength were ever the cable touches metal. Also the adapter will cause signal lose. The best bet is to buy an amplified indoor antenna. You also may try a paper clip and about 3to4' of small gauge wire put the paper clip (bend out to fit) into the center of the antenna in on the tv have the wire connected and let it hang or lift it to see how the picture improves. The problem with rabbit ears is that you have to use war time tactics. Crawl on your stomach and adjust to best picture, if you stand and adjust the signal is usually reflected off your body and will be nice until you walk away.
Jan 28, 2009 | Sansui HDLCDVD220 22 in. LCD TV TV/DVD...
How can this be happening if she is not hooked up to the cable
if you see the logo she has directv. tune her t.v. to channel 03 or 04 and she should have a picture,if she lives in a apt. her feed may be coming from her provider or her t.v. is hooked up to another t.v. that does have a directv receiver. if this doesn't solve your riddle get back with me as i work for direcv in the tech dept. hope this helps you...
Dec 17, 2008 | RCA TruFlat 27F520T 27" TV
Rabbit ears to digital conversion box
Your TV is old enough to have not only screw terminals for the antenna, but it sounds like it has separate UHF and VHF terminals as well. Pick up a 75-ohm to 300-ohm adapter (available at Radio Shack and probably most other places that sell TV's and antennas). This is a small cylinder-shaped part with a threaded antenna connector on one end, and a flat wire with two terminals on the other end. Connect the cable from the converter box to the round connector, hook the two terminals to the VHF antenna screws on your TV, put the TV on channel 3 and you'll be set.
You should also pick up a new antenna designed to work with digital broadcasting. If you use the old rabbit ears you were using before, you will probably not pick up all the channels available in your area.
Oct 31, 2008 | GE 35GT740 35" TV
TV does receive broadcast signal
get some rabbit ears..... or a little dish reciever that sits ontop of ur tv til FEB 17th...then u have to have the new converter, which u can get government coupons online ....or ull just get fuzz after that... i use the old cheap rabbit ears antennae and i get 6 channels ....
Oct 25, 2008 | Sansui Televison & Video
Magnavox TB 100 MW9 STB Converter Boxes I'm trying to solve the antenna/rabbit ear connection from this converter box to the t.v. I only get a pic when the rabbit ears are connected to the back of the...
Analog signals have nothing to do with your problem. Make sure that the TV is set channel is set to 3 or 4 (cf read of Converter box for channel switch). The TV received signal from Converter box on Channel 3 (or AV Cables if you have them)
Jun 11, 2008 | Televison & Video
No television without cable
You have the TV set to cable. You need to go back into the menu. Go to the settings and change the setting where it says cable to AIR.
Sep 17, 2007 | Polaroid FLM-3225 32 in. LCD Television
TV won't turn on, makes high-pitched clicking noise
Its a real good chance that the HOT (horizontal output tranistor) transistor is shorted if so the flyback trasformer may be bad also. the transformer will make a tick tick sound if it is trying to start.
Mar 30, 2007 | Philips Magnavox MT1905B 19" TV
Philips Magnavox 51MP392H Rear Projection Television Logo
167 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
