Question about Frigidaire GLET1031 Top Load Stacked Washer / Dryer
Frididaire GLGT1031CS1 dryer sounds like nails on a chalkboard?
The belt broke so bought a new one, put it in. It ran fine, but when I installed all the hoses , the dryer run and sounded like it was on nails on a chalkboard.Could it be that I bought the wrong belt. The belt installed ok. not too tight and not too loose. What could it be?
    New Friend:
It;s the bearing on the back of the dryer drum
Posted on Apr 20, 2013
Dryer squeeks terribly. could this be the drum bearing?
Posted on Feb 15, 2011
I have a any problem with a any machine like that, i feel a burning smell, when the machine washing, but not when drying i don´t understand, i appreciate all opinions all respect, thanks
Posted on Jan 11, 2010
Use some brake grease and lube the wheel and belt in the far back left
Posted on Oct 24, 2009
Check the bearing behind the drum assembly, the part against the rear wall is probably worn so low there is metal to metal contact, if so replace bearing.....
Posted on Aug 21, 2008
Maytag dryer.replaced belt and it ran briefly and broke new belt
reasons for breaking belts
drum running out of round ( bearing failure , bent shaft)
overloaded
belt incorrectly fitted
Feb 26, 2017 | Maytag Dryers
Dryer barrel does not turn
If the motor comes on but the drum doesn't move the belt probably broke. On most dryers you can open it at the back with a couple of screws if the belts broken a new one can be bought and installed without much hassle
Oct 20, 2015 | Dryers
Hi, My Hotpoint TVM570 Aquarius is making a loud screeching noise occasionally. It isn't doing it every time my partner just used it for an hour with no issues. However I used it for 5 minutes this...
wonder if you are overloading the machine and the noise is the drive belt screeching. if it sounds similar to a loose fanbelt on a car, it could be drum bearings that are seizing up (check by manaually rotating the drum. if it spins freely its ok) or the drive belt is getting worn and needs replacing
May 09, 2014 | Washing Machines
Frigidaire GLGT1031CS1 washer timer
Yes. Replace the timer and you are good to go.
Jul 05, 2010 | Frigidaire GLGT1031C Dryer
My tumbler is not turning. It sounds like the motor is running but it's not spinning
the dryer is ran off a belt surrounding the entire drum and the belt also goes through a belt tensioner too. The tensioner provides to keep the belt on snugly. It sounds like the belt broke. I would go to Sears for they can get parts for yours. You will need a belt with the tensioners roller/bearing assembly. The roller wears out usually quicker than the belt so get that also.. These items are sold in a kit form in most cases for they are replaced as a set by 99 repairmen and do it yourselfers
Apr 10, 2010 | GE Profile Harmony DPGT750EC Electric...
New timing belt keeps getting loose when it cools down
yes you can get defective auto tenioners.Chage ASAP.
May 30, 2009 | 1992 Mitsubishi 3000GT
Lse1000
The hard work is over! The old belt should pull out from the drum area if it is broken. There should be two ends to it now. Get a new belt and put it over the front of the tumbler. You should, (with a flashlight) be able to see where the old belt was running. Get the new belt close to that spot.. I believe your model ran with the smooth side of the belt to the drum.It will not look right to you, but the tensioner passes the belt through the pulley and motor pulley on the grooved side of the belt.Once the belt is on, reassemble the dryer front in reverse of disassembly.
Jun 13, 2008 | Maytag LSE7806A Top Load Stacked...
Seimens wt 3301 How to install a belt
hi
it very simpel
opening back and top of the dryer
opening back bearing - by 4 small scrows
push out the shapt holder
install the new belt
close every thing
start to work
Apr 26, 2008 | Dryers
Frigidaire GLET1031 Top Load Stacked Washer / Dryer Logo
265 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
