Question about Hotpoint NVL333EY Electric Dryer
HotPoint Dryer Model Number NVLR333EVOWW not getting hot
Set the timer one day, later clothes not warm at all, dryer still running and timer had not moved. It has never heated up again. Can you help me figure out the problem? Where all the heating elements, thermostats etc may be. thank you for your help.
  • champion2022 Nov 26, 2008
    my dryer just got cleaned out yesterday and now the timer stays in one spot and there is no heat. how do i fix this?
  • Anonymous Dec 30, 2008
    same as above comment.
Posted on Nov 24, 2008
You have the old style GE/Hotpoint machine which has a round plate behind the drum.
The plate has the heater coil, limit t-sta,t and operating t-stat[s] mounted on it.
Try checking out Appliance Parts Pros.com Discount Appliance Parts – Appliance Repair Parts because you'll find some parts breakdowns which will help you.
The top is held on by 2 screws at the front of the top.
Posted on Mar 27, 2009
Hotpoint TVM572 timer is faulty
It is important not to open the door of the dryer if it is still running. The timer controls the cooling cycle otherwise the clothes will get damaged if kept on hot.
It is very likely the timer contacts are frozen at some point and the timer will need some attention.
It is not hard to locate it. I cannot find the actual parts drawing for your model (it is good you have provided the full model details). But to help you locate the part I have found another Hotpoint model that may be similar to yours. Check this drawing to see if the front panel is similar.
Item 100 is the timer.
HOTPOINT Electric Dryer Backsplash blower moto Parts Model NWSR483EB1WW
The actual timer for your model looks like this.
Hotpoint TVM572P Timer
As the clothes are not getting burnt or singed I will assume the thermostat is ok and keeping the temperature within the range.
Aug 07, 2014 | Hotpoint Dryers
My hotpoint BWD129 , dryer does not work clothes are barely warm
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Washing Machines
MY NVLR333EVOWW HOT POINT DRYER IS NOT HEATING. HOW CAN I DETERMINE IF IT'S THE HEATING ELEMENT?
I worked on one of these not long ago that was tearing up clothes.. Took some pix
I would say take a look at your element for breaks.
Sep 19, 2011 | Hotpoint NVL333EY Electric Dryer
Hotpoint nvlr333evoww runs but clothes will not dry
there is chance that the heating element has gone bad but the first things to check are all your thermal fuses inside the cabinet of the dryer. They should all have continuity and the one that does not have anything then it needs to be replaced
Jul 06, 2010 | Hotpoint NVL333EY Electric Dryer
Model NVLR333EVOWW Not heating up
your element has burnt in half where the sparks are coming from is the end of the element touching the metal. You need the model and serial number go to the nearest appliance parts supplier and get a new element they aren't that hard to replace. Always make sure you disconnect the power source before doing any repairs to the dryer. Good Luck
Dave
Jul 22, 2009 | Hotpoint NVL333EY Electric Dryer
I have a Frigidaire Dryer model GLER331AS1 and one day it was all lite up with heat I had to manually turn it off, after that it will run but it wont turn off if it's not on the minutes drying time it just...
hi Gwen. I can help you.
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Jun 08, 2009 | Dryers
Dryer turns on, gets hot, but knob does not move with timer.
could be your operating thermostat on your heater or your timer if it runs on timed dry but not auto dry then it is a thermostat issue if it just does not run at all then it is a timer issue also make sure your vent is clear check by removing vent hose from back of unit and running a load if it works properly clean your vent.
Feb 23, 2009 | Hotpoint NVL333EY Electric Dryer
Dryer never shut off and now does not heat up
Your timer has gone out. (this is a very common problem) If you get me the model number i can get you a part number so you can order the part from sears.com
Nov 19, 2008 | Dryers
Hotpoint bwd129 washer dryer won't dry my clothes.
my Hotpoint dry will not dry my clothes. It will run for hours and the clothes still haven't dry just felt hot.
Oct 05, 2008 | Washing Machines
Hotpoint NVL333EY Electric Dryer Logo
1,764 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
