Question about KLH KD1220 DVD Player
I need directions on how to use the universal remote with my VCR.
I can't remember how to play dvd's on by dvd player.
Posted on Nov 22, 2008
Need the code to program my universal remote to my jvc tv the serial# to my remote is rc24922-c1122 model jc024
Do a code search method as follows.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Dec 26, 2014 | GE 24926 Glow Keys Universal Remote...
I need a remote for my RCA DVD player, model DRC282. I haven't had much luck with a couple of universal remotes. Any help would be appreciated.
Just try a code search process. Sometimes it might help you:
May 12, 2012 | Televison & Video
I have a all for one remete urc#4063b06 need code for samusung tv/vcr modelcxa192680b
There is no code for Samsung TV/VCR combo units. Try the Samsung VCR codes: 240, 045 and the Samsung TV code: 060, 427, 056, 030, 019, 178 . Program the VCR and the TV buttons separately.
Most One for All universal remote manuals and code lists are available from: http://www.oneforall.com/support/manual . You may need to change the country listed at the top of the page. Then use the drop down menus to select Universal Remote and the model. The direct link to the manual for the URC4063 is http://www.oneforall.com/uploads/support/00b313f46269f3fc78988edae4518f03.pdf .
Please note that the codes programmed into a universal remote are limited to those for devices released 6 months or more before the remote was programmed. If your TV/VCR is newer than your remote, you may need a new remote.
I hope this helps.
Oct 03, 2011 | One For All URC-3021 Remote Control
Need code for magnavox tv/universal remote control
http://kbase.x10.com/wiki/Universal_Remote_Code_List
 you can also manually find it follow your universal remote control user guideIf after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
Manually turn on the device (TV, VCR, etc.) to be controlled.Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.Press and release MUTE to install the code. The indicator light goes off.Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Mar 05, 2011 | One For All URC-3021 Remote Control
Universal remote need a code ? or a remote
Hello
Universal remote code for Prima TV are :-
1019 0165 0116 0167
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
OK
Jan 19, 2011 | Prima C2012 TV
Can not program my rca remote model rcr311w.
If you go to rca.com they have a full list of manuals. Just select your model and follow the directions. Have a great day..
Aug 27, 2009 | Universal Remote Control DIRECTV Universal...
Universal remote control codes for toshiba t.v. amd syphonic vcr
have a jensen universal remote need codes for toshiba tv vcr combo lost book.
Jan 19, 2009 | Directed 434MHZ Remote Control
Universal remote
If you need help with the codes ask here
They will find the right code for your specific VCR.
Oct 07, 2008 | RCA Universal Remote 3 Device Remote...
Remote codes
Contact Direct tv and they should have the codes to program the remote tothat tv. Or contact Universal remote @ 919-573-7854 919-573-7854
Aug 17, 2008 | Philips Magnavox Learning Universal Remote
RCA GuidePlus Gemstar Universal Remote Control 242524
i need to program my remote for my tv with this gemstar universal remote control "crk76te1 . how do i do this ? its for a zenth televison . thanks
Jun 08, 2008 | RCA Universal Remote Control
KLH KD1220 DVD Player Logo
103 people viewed this question
Top KLH Televison & Video Experts
Jason Morris
ray gallant
Are you a KLH Televison and Video Expert? Answer questions, earn points and help others
