Question about Weber Q300 Grill
Gas grill ignitors
My gas grill ignitor stopped working so i purchased a new one, but it doesn't work either. is there a way to test the igintor itself, off of the grill to see if it is indeed the ignitor or something else?
(my grill is a charmglow three burner grill)
  • 2 more comments
  • Anonymous Jun 10, 2008
    Changed battery, still no ignition and it is less than a year old.
  • Anonymous Sep 07, 2008
    Same problem
  • Anonymous Sep 26, 2008
    Same problem. Electrode is new, checked the wire for continuity, want to know how to check the ignitor to see if it's creating the spark.
  • burdine1 Mar 07, 2009
    ignitor dosen't work on my charmglow gas grill also looking for an owners manual for this grill purchases at home depot
Check the electrode.  That is the end at the burner.  It may be corroded and no longer creating a spark.
Posted on Jul 08, 2008
I recently moved. When the grill arrived to the new home I had to purchase a new propane tank to replace the old one. The grill will not light. For some reason it isn't getting any gas. Any suggestions on what the problem might be?
I tried the obvious... tightening the connections, trying to light it manually etc.
Thanks,
K
Posted on Jul 13, 2008
Ignitor isnt working
The oven ignitor should have a resistance reading of about 3.2 to 3.6 ohms. If the readings are out of this specification or show open replace the ignitor. measure the resistance of the oven valve. The gas valve should have about 1.5 ohms of resistance. If the gas valve is OK, the control board is suspect. The ignitor needs 120vac to work.
Apr 07, 2014 | Kenmore 91112 / 91114 / 91117 Electric...
Ignitor doesn't work on DCS grill
Just use a 9 volt batterie
Jan 20, 2018 | DCS Grilling
Ignitor keeps clicking on burner
A creda microwave oven doesn't have an ignitor or burner, so I assume you are talking about either a BBQ grill or gas range.
A suggestion: Clean the ignitor tip with a CLEAN and DRY green scouring pad; check that you have gas coming out of the burner.
If you have gas at the burner and the ignitor is clicking (sparking) then it is usually an ignitor alignment problem where the ignitor got bumped out of position.
Jun 06, 2011 | Creda Microwave Ovens
I have been using the grill for about a year now. All of a sudden the electronic igniter dosen't spark on all control knobs. I checked the battery and replaced it with a new one. It did not change...
First, Bud make sure the battery was installed facing the proper direction. The Positive end (+) should be facing out when installed. If that's not the problem, check the wiring from the ignition module to the each burner ignitor. One may be loose or the grounding wire from the ignitor module to the grill's frame, may have lost contact. Also, look carefully at each ignitor tip at the burners. They may have an accumulation of grease, which needs to cleaned off.
If all that doesn't resolve the problem, you will need to replace the ignitor module. You can purchase one online directly from NEX Grill http://www.nexgrill.net/ or from Factory Appliance Parts
http://www.appliancefactoryparts.com/search/index.php
Hope this helped you troubleshoot and solve the problem. Please let me know and Happy Grilling!!
Jun 04, 2011 | Nexgrill 720-0234 (LP)
Igniter turns red but will not fire the burner. Gas is coming out and I've changed the burner with a good burner.
You need to adjust the ignitor so that the flame is closer to the burner. If you try match lighting the burner, does it light? If it does, then the igintor need to be adjusted closer to the burner.
Mar 05, 2011 | Fire Magic Regal II (LP) 15-S1S1P-A...
Oven ignitor won't ignite GE RANGE : JGBP28DED1CT
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Jul 14, 2010 | GE Kitchen Ranges
How to test oven igniter
The best way to test the igintor is with an amp meter. Connect a clamp on amp probe to one of wires going to the ignitor (either one is fine) turn the oven on, match the current you get from the amp probe to the rating on the gas valve to see if you have enough current. (typically you need 3.2 amps for most systems).
As ignitors get weak the resistance in them gets higher causing the amp draw to go down.
You can also get 'a feel' for the strength of the ignitor by how bright it glows, when working right, the orange will be bright almost whiteish in color. As it ages and weakens it will be more of a dull orange.
As a rule of thumb, if the ignitor is glowing and the burner will not come on the ignitor is bad.
I hope this helps
May 05, 2010 | Frigidaire FGB24T3A Gas Single Oven
Arg7600 oven won't light. Glow plug works. No gas.
This typically indicates the Hot surface ignitor (glow plug) is weak, and needs to be replaced. Even though it glows, it simply doesn't generate the amperage required to open the gas valve. These two compnents work in series, when the igintor becomes to corroded it cannot draw enough current to sufficiently power the magnetic coil in the gas valve. replace the ignitor and let me know when the turkey is ready ! :)
Sep 25, 2009 | Amana ARGS7650SS Gas Kitchen Range
Ignitor on performer grill stop working. Can
Call Weber at 800-466-1071 and order the ignitor kit: http://www.weber.com/publicSchematic/view.aspx?model=841004&Sequence=26&Suffix=
Aug 22, 2009 | Weber Performer Grill
Gas grill ignitor no longer ignites burners
it is bad you need a new igniter, the flint part goes bad
Feb 20, 2009 | Grilling
Weber Q300 Grill Logo
1,675 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
