Question about LG LRSC-26922 Side by Side Refrigerator
Refrigerator water line
How do i get into the fridge to disconnect the line
  • pcbeats Jun 09, 2008
    the main water line into my fridge split,i have the replacement for it but no service manual.i need to know how to take the old one off in order to replace it.
                         hope this clarifies things,thanks,pcbeats
  • Richard Lew May 11, 2010
    What are you trying to do??
  • 489 Answers
The water line is located in the back behind the lower panel.  Remove the panel and you will find the water valve with all the water lines going to the ice maker and to the dispenser.  Everything is accessible and should be easy to replace.  If you're still having problems, add a photo of the line your trying to replace in your next response.
Posted on Jun 09, 2008
Water is leaking under fridge when I use the water dispenser
This means you have a cracked water line tube coming from the valve. The water valve will be in the rear near the compressor, likely made of blue plastic. If the fridge has an icemaker, there will be two fill tubes coming off of the valve, the water dispenser line will be the larger of the two... depending on the model, there will be a quick disconnect behind the kickplate below the freezer door, disconnect the water line there and replace that section back to the valve... Water Line 5210JA3004U
Jul 18, 2016 | Refrigerators
I have mold that has formed in the water lines of my refrigerator. What can I do to fix this problem.
It is best to replace the line inside the door that goes to the pressure handle. Check the inside of the water supply line at the back of the fridge to insure it doesn't have mold. A chlorine solution will kill the mold but will leave the lines stained black inside. Installing a filter in the fridge line, some fridge makers sell them for their units helps prevent mold spores from getting inside the water lines. In most cases, only the small, short water line in the door tap is all that is affected.
May 29, 2015 | Samsung RFG298HDWP 29 cu. ft. French Door...
How do I disconnect the plumbed water to my Fisher & Paykel fridge?
Shut the water down and disconnect water line behind your fridge and remove your fridge
Jan 11, 2015 | Fisher and Paykel Refrigerators
How to disconnect water line
If you following the water line into the back of your refrigerator, it will come to a threaded nut. That is how you disconnect it.
Jan 25, 2012 | Jenn-Air Jenn Air 19.8 Cu. ft. Counter...
We just bought a home .w/it came a great fridge.but now in 4 mo the filter in the fridge needs replaced for the 3rd time >??whats the deal ? presourse 2 2000
probably the water line is clogged with some kind of dirt. Disconnect the water supply and disconnect all the water lines and blast them through with compressed air.
Dec 03, 2010 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire Gallery Professionaly series broken ice maker
If you hook up the water to the fridge, that means you connected the water line to the 'Water Inlet Valve' of the machine. There should be a two wire harness connected to the water valve back. Look for that....
But please note following...
Some water valves in fridges are complicated with one harness for water dispenser line valve and another harness for ice maker water line.
Also seeing a disconnected wire harness does not mean it is for the water valve. May be most likely. But be careful sometime there are test wire harness for technicians to get power readings for components.
Oct 25, 2017 | Frigidaire Professional Side By Side...
GE GSH22JFR side by side refrigerator
Yes the water line has frozen in the door. There is a kit to repair this WR49x10173
Feb 09, 2010 | GE GSH22JFR Side by Side Refrigerator
GSS25L GE no water
Check the electrical connector that is next to the water pipe at the bottom of the freezer door
Aug 19, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Disconnect water line at door
press on the collar of the assembly where the water tube enters the coupler with your thumb. The pressure of your thumb should allow you to remove the water supply tube.
Mar 22, 2008 | Samsung RS2578BB Side by Side Refrigerator
LG LRSC-26922 Side by Side Refrigerator Logo
267 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
