Question about Smeg FA561X Side by Side Refrigerator
Freezer compartment alarm keeps going off for Smeg FA561X
The temperature alarm for the freezer compartment goes off intermittently. It seems the freezer and fridge are working fine inside. Any ideas how to make our life more pleasant without the nightly disturbances from the freezer alarm? Thanks in advance.
  • 1 more comment
  • sicily7 Jun 22, 2008
    the led on my fridge freezer has started to constantly flash and every 6 hours or so the freezer alarm will sound and the freezer led display will change from -21 to -- -- , if i press standby button twice everything is ok again for another few hours except the constant flashing even the light from the water dispenser will flash
  • cabbiesandra Sep 11, 2008
    my smeg fridge freezer alarm keeps going off flashing the letters CF what does this mean and how do i solve it
    thanks
  • LiftedLorax Nov 27, 2008
    same problem with Smeg FF SRA20X1
5 Suggested Answers
SOURCE: SMEG FAB28
Check the seal is tight all around the door - clean it to within an inch of it's life.
Then make sure the drain hole (inside at the bottom of the fridge) isn't blocked (a long handled screwdriver with kitchen roll wrapped around it will suffice). You can tell the drain hole is blocked as it's characterised by the door being difficult to open in quick succession (plus - you can see it's blocked).
Next, defrost the fridge completely: Power off, open door on freezer compartment & fridge and mop up the damp. When totally dry, turn back on (without food - let it cool properly before putting food back).
I had the condensation problem and it's now sorted. Not sure which cause was responsible, but the 'solution' is worth a try.
David W.
Posted on May 22, 2008
  • 3 Answers
SOURCE: Smeg FA561X trips RCD section
Monica - I also have the exact same problem (although different model Smeg), did you find anything to fix it? Kathryn
Posted on Feb 13, 2011
sodeep
  • 3267 Answers
SOURCE: Smeg FA561X ice maker not
ice maker stopped making ice. For this problem you have check few things. First thing, is the water filling in the ice maker chamber and then ice maker not making ice? Or, the water is not filling in the ice maker chamber so it's not making ice. If the water is not filling in the ice maker chamber then it's clear that ice is not getting made due to no water in the chamber. For no water filling, the problem is either water supply valve turned off so water is not filling. Turn on the water supply and it will fill. But if the water supply is turned on then the other possibility is ice blockage in the water fill tube. There is a tube from which the water runs and enters the ice maker chamber. If this tube is blocked then water will not enter the chamber. The tube needs to be defrosted, by using hair dryer. This procedure melts the ice collected in the tube and water starts running again. But if water fill tube is completely clear and no ice blockage or any other blockage. Then other possibility is water valve at the back of ice maker unit. This water valve is for letting the water in the ice maker. The water valve open only for 7 seconds and in this time the water fills in the ice maker chamber and then water valve closes and the same procedure runs again in the next water filling cycle.------- In most of the cases the fault is water valve at the back of ice maker section, on some refrigerators the valve is at the lower section. ------------- The above possibilities which I gave you is water not filling in ice-maker chamber so it's not making ice. But now consider that water is filling in ice maker chamber but it's still not making ice. Then the problem is ice maker unit itself. This unit is controlled by main board. But in most cases if water is filling the ice maker but it's not making ice then its faulty ice maker unit. So see if the problem is water not entering the ice maker then the water fill tube is frosted by ice or the water valve at the back of ice maker is faulty. Replace the valve. ------------
You can get required parts from sears part direct online site or from repairclinic.com site.
Posted on Jun 29, 2011
heatman101
  • 43501 Answers
SOURCE: Smeg CR330SE fridge/freezer hi there fridge
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jul 03, 2011
My freezer has a different code number;ZFT710FW.I put quite a lot of food into the freezer yesterday and the alarm now keeps sounding,I have put the temperature up but the red light is still flashing...
Red Alarm Indicator Light
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
Dado
Apr 26, 2013 | Zanussi ZFT710W Freezer
SMEG Fridge Freezer FA561XF - the frame of the fridge/freezer gets very hot and freezer isn't freezing stuff in bottom tray
That is a very bad sign, but before you unplug it pull the machine out from the wall and check to see if it feels hot back there as well. Then remove the lower cover and find the condersor fan motor. Its the only fan back there. I'd willing to bet that the fan is not running. The purpose of the the fan is draw air across the compressor and blow it through the condensor therefore lowering the temperature on both parts. When its not working/ running, the heat from the compressor and the condensor is pass onward to the machine and the machine then acts as a heat sink.
Also, if the machine is too close to the wall or the condensor coils are dirty you'll get the same effect, so be sure to check those things out as well
Jun 21, 2012 | Smeg FA561X Side by Side Refrigerator
Alarm is going off how do I stop it
The best temperature is the midpoint. Typically 3 or 4. The alarm will go off once the temperature goes down to the freezing point.
May 05, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Our Smeg SR640XA side by side refrigerator is making strange puffing noises at the bottom section of the freezer. It puffs four or five times and then it sounds like something is dribbling in the back of...
It is the defrosting heating elements and sensors that has gone bad.
Check for glowing light at bottom of the back panel. Turn the freezer section off and contact Smeg!
Mar 14, 2010 | Smeg FA561X Side by Side Refrigerator
Water runs intermittently out of water line located on the freezer door getting the entire floor wet
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip.
Sep 03, 2009 | Smeg FA561X Side by Side Refrigerator
Ice maker not working, please can you send instructions or telephone no
Is the bail arm in the down position? Is the ice maker connected to its power supply? check to see that the harness is plugged in all the way. Check the temperature of the freezer. Freezer temp must come down to 5°F for the ice maker to make ice.
May 26, 2008 | Smeg FA561X Side by Side Refrigerator
FRIDGE NOT WORKING
Most side by side and other models of refrigerator freezer combinations are of one basic design. The freezer section does the cooling for both compartments. The refrigerator section gets it cold air from the freezer compartment. Therefore check for frost on the back wall of the freezer compartment. If frost is present there you have a defrost problem and it is cutting off the air that cools the refrigerator section.
I think this problem may already be resolved in some manor because of the date of post. Posts should expire after an unreasonable time period.
Mar 19, 2008 | Smeg FA561X Side by Side Refrigerator
SMEG FA550X
Its not possible for water to get in your pump, its a sealed unit, and runs in oil/gas mixture I would look for water in any motor relays, and wiring junction boxes.
Aug 12, 2007 | Smeg FA561X Side by Side Refrigerator
Smeg FA561X Side by Side Refrigerator Logo
185 people viewed this question
Top Smeg Refrigerators Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
ashburton
Are you a Smeg Refrigerator Expert? Answer questions, earn points and help others
