Question about Haier Heating & Cooling
Fan sprays water. water gurgling sound - Haier Heating & Cooling
  • 828 Answers
Drainage is plugged on the air conditioner and backing up into the fan housing. Try tipping it to the outside a little to give it more drain flow toward the outside. If the back of the A/C is higher then the front you can have this problem.
Posted on Jun 06, 2008
Why does my montero cooing system makes gurgling noise
In many cases of gurgling cooling system, you have a possible head gasket problem starting and the combustion from the engine is pressurizing the cooling system. Check your cooling system thoroughly for evidence of a possible blown head gasket.
Are you loosing cooling system water?
Is your radiator overflow tank being pressurized excessively by the engine. Headgasket problems can sometimes put some much pressure in that overflow tank that it begins to bulge outward.
Check the oil and look for any white/greyish milk shake consistency fluid on the oil fill cap or on the radiator cap. Keep a close eye on your oil and water levels if your gurgling sound continues. This is not normal and again, usually is a sign that there is a possible leak between the headgasket and a water jacket on the head.
Did you overheat the vehicle anytime soon? This will many times breech a head gasket between water jackets and begin spraying water in small amounts right into the engine cylinders, while it pressurizes the cooling system and makes gurgling noises.
Aug 13, 2014 | 2002 Mitsubishi Montero Sport
Freezer gurgles
    • Give it mouth wash lol
      Check the water valve on the back of the refrigerator if it has an ice maker. Make sure the valve is turned completely on and not constricting the flow of water to the refrigerator via the water supply line. You might also hear a simultaneous buzzing sound when the gurgling noise occurs. In some refrigerator models, this filling process is on a timer, and you might hear the buzzing and/or gurgling every 15 minutes or so.
    • Check the water supply line for leaks or damage. You might see a puddle of liquid on the floor. If air is pulled into the water line as the refrigerator is pulling in water, that can create a gurgling noise. Replace the damaged hose yourself, or contact an appliance repair technician for assistance
      • f he refrigerator to feel a slight vibration. This is probably the compressor processing the refrigerant, which is a liquid. This flow of refrigerant can produce a gurgling sound, and it is normal. However, a simple way to reduce this noise is to make fewer trips to the fridge. When you open the door, you let hot air in, which means the compressor has to work harder (and gurgle the refrigerant more) to cool things back down.
    • Wait while the refrigerator completes its defrosting cycle if you hear water dripping and gurgling in the freezer area. When the heating coil turns on, the melted water from the frost flows down to a drain pan for evaporation to take place. The defrost process usually takes about 30 minutes. This is automatic and cannot be prevented in most refrigerators. Keep the closed to try to prevent unnecessary frost buildup.
    • Wait while the water equalizes in the refrigerator if you hear a gurgling sound when shutting the door. This is normal and is a result of air being forced through the drain tube. The gurgling can last several seconds but should eventually dissipate this usually happens with old fridges upgrade its a good investment
Dec 10, 2013 | Freezers
Maytag 5000 btu air conditioner, model # m3x05f2a-c, is making gurgling sounds and spraying water, please help?
I could not find that model number listed, but no matter. It sounds like your drain line is plugged with something and you need to clear the line. What has always worked best for me is a guitar string because it is flexible enough not to damage anything but rigid enough to work on cloggs.
Jun 19, 2011 | Maytag Heating & Cooling
I couldn't find my model so I just picked one. I have a Kenmore Coldspot side by side. Model 405.58404800. I have been getting a gurgling sound the last couple of days when I close the freezer. It...
not a motor just the fan the defrost drain tube gurgling when you opening the door their is so much vacum that its sucking air ththrew the defrost water drain located in back of refrigerator their is a kit you can order drain gurgle kit
Jan 27, 2011 | Kenmore 52282 / 52284 Side by Side...
Gurggeling sound. while running canhear water
I'm unsure what you mean by the gurgling sound but its normal for water to splash on the outdoor fan blade. It has a slinger ring built onto the tips of the blades to "sling" water onto the outdoor coil in order to make it work better by keeping it cooler.
Jun 15, 2010 | Heating & Cooling
My culligan water filter makes a gurgle sound
The reverse osmosis faucet you have incorporates an AIR GAP to prevent cross contamination to the RO system. The waste water first goes up the to RO faucet AIR GAP and then goes to drain. The "gurgling noise" is the waste water going to drain. Some of these are much noisier than others.
RJ
Jun 10, 2010 | Culligan Under Sink Water Filter
Our pool is gurgling and the water level seems low. what should we do.
Add enough water to bring the level halfway up the skimmer. Sounds like it's sucking in some air with water and that's what is causing the gurgling sounds.
Mar 26, 2010 | Pool & Spa
Toilet bowl gurgles after flushing cycle
Sounds like your toilet is not vented properly. Possilbly something caught in the trap is causing it to syphon
Jan 23, 2010 | Toto Aquia II Dual Flush Toilet
Rattle and Gurgling noises
It's the fan bouncing off the fan-motor housing. The best way to stop this is to shim the motor mount so the fan will ride with the motor shaft "out" preventing it from bouncing. When you raise the fridge on one corner you are doing the same thing the shim will accomplish.
The draining gurgling sound is probaby freezer defrost water being pushed down the drain tube into the drip pan at the bottom. The door action pushes/pulls air in the tube and pushes out water.
May 27, 2009 | Refrigerators
Suddenly no filtered water comes out, but there are gurgling sounds inside
I guess make sure the filter didn't unseat itself first, also check the O-rings, etc. to make sure they didn't roll off their position on the filter. If that's all OK, you really need to find that gurgle sound cause that's likely the water you are missing going "somewhere" it's not supposed to go. Look all over for water leaks even if you have to pull the unit out from the wall... keep looking!
Dec 21, 2006 | Amana ARB1905C Bottom Freezer Refrigerator
Heating & Cooling Logo
194 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Edd
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
