Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Panasonic MODLE PT53TW53G led code flashes 3 times convergence problem
I need help!!!!!! I got up and pushed the on button and the TV would not come on and the red led flashed 3 times and stops and then repeats the steps. What could the problem be? I heard that it could be the ic`s in front of the heat sinks so I took out the board but nothing appears to be burnt. But some one said this is a common failure. I also checked the surrounding resistors .and everything appears to be ok there is no discolor on the board except around some diodes and they seam to check out ok. What do you think the problem is?
  • mmemon Jun 08, 2008
    My panasonic pt-56rw53g does not powerupm power light on front flashes 5 times and keep repearing this
  • crocky76 Oct 27, 2008
    same as above
I replaced the ic's and still have the same problem.
Posted on Sep 11, 2008
  • Panasonic Master
  • 8,617 Answers
3 blinks is an error code for the convergence ICs being bad. You will have to replace both the convergence ICs they should be STK392-110 for your model. You can get new replacement ICs at the following link with free instalation instructions with pics so you can do the repair yourself. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Jun 08, 2008
The same happened with mine, and i fixed myself., probably your have the same problem according with what you described.
there's a ceramic resistor close to the power supply cord that burn and it is difficult to know until you take it out, if that is the problem just buy a resistor of 1.5 k ohms and solder it across the burned ceramic resistor and put it back in place.
you can find resistors with the same value at radio shack for less than $5.00 bucks.
that solved my problem.
good luck!!
Posted on Sep 30, 2010
My tv won't turn on when the on button is pushed, but the power light blinks 5 times
5 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Jan 28, 2013 | Panasonic PT-56TW53 56" Rear Projection...
PT54DL50
MOST LIKELY problem is the convergence amps but.....
It might be your vertical or horizontal circuit...those initiate a 3 blink failure code too....
Dec 01, 2007 | Panasonic PT-50DL54 50" Rear Projection...
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic projuction screen tv.
3 blinks is the error code for the convergence ICs. You need to replace both STK392-110 convergence ICs. You can get replacement ICs at the following link and they provide installation instructions with pictures.
Oct 12, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Led flashing 3 times,
Please post the make and model as each has their own blink code. I can provide more detailed info once I know the make and model.
Thanks,
Dan
Jun 18, 2008 | Panasonic Televison & Video
you need to replace both STK392-110 convergence ICs you can get replacement ICs at the following link and they will send free instalation instructions so you can do the repair yourself. heres the link.
Jun 05, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-51HX43G no power, red light flashes
I have a Panasonic PT53TW53G projection tv that had the same problem for power .A terrific person gave us wonderful advice and it fixed our tv! We were told to replace the IC conversion amplifiers. On our model they are STK392-110 (your's may be different). We ordered the parts from www.electronix.com and they were only $12. for the two parts. We also had to purchase a soldering iron and de-soldering vac for removal/replacement of parts. Good Luck!
Feb 04, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
819 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
