Question about Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television
WD-52327 Red Light Problem
I Have been reading about the Red Light Problems and Light Engines on the Mitsubishi WD-52327 TV's.
I have a new light and replaced it. and the tv did not want to start up.
I took the cover off and pushed the plug in unit and heard a click.
Then the tv came on.
Now it seems every time I try to turn on the tv.
It starts up then shuts down and give's me the red light two or three times in a row before it starts up and stays on.
I'am afraid some day it just will not start up.
I have had the tv for three years and I know the Light bulb is not the problem now!
I just want it fixed with out giving an arm or leg!!!!
  • ramanach Dec 30, 2008
    WD 52327: When I turn on the powe, the timer comes on for a minute and then the green light blinks for a min or two and then shuts down. There is no significant sound or picture. Technician came and said it is a problem with the light and or the ballast. Cost around $600.
    What should I do?
  • J4PROUCTION May 11, 2010
    I have the same problem and pushed the input and menu button. The error code I am getting is 44. Does anyone know what that means?
  • Mitsubishi Master
  • 8,617 Answers
Try pushing input and menu buttons in together on the front TV panel and hold in for 8 seconds to see if the set blinks a two digit code as it may have bad capacitors if it blinks a 3 4 code.
Posted on Jul 16, 2008
What is the cause tv turns on about half hour turns off red flash
most likely the lamp. pt# 915P020010
Recommend Phillips, OSRAM, or Mitsubishi original, as others may not work at all or have a very short life.
https://www.shopjimmy.com/dlplamps?tv_brands_select=Mitsubishi&tv_models=Mitsubishi+WD-52327
Mar 17, 2015 | Mitsubishi WD-52327 52" Rear Projection...
Recently my wd-52327 said it needed new bulb(steady orange light). i had replaced the bulb 7 months earlier and didn't want to see the light so i reset the lamp timer. well the bulb blew the next time i...
If you have a voltage meter you can pull the bulb out and check for continuity by placing the probes on the power plugs of the bulb. If you have continuity the bulb should be good, and it may be the lamp ballast.
Nov 21, 2009 | Mitsubishi WD-52327 52" Rear Projection...
When turning on the TV the green light on the front does not come on. You hear a click and then about ten seconds later you hear another click but the tv never comes on.
What light do you get, green blinking, red blinking, yellow steady light or yellow blinking light. The led lights will tell what is wrong with your tv.
Jun 12, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Have problems with mitsu wd-52327
check the current maybe high voltage occur or due to loose connection high amper occur.
Jun 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Buzzing noise from Mitsubishi DLP WD-52327 after replacing bulb
Did your replace lamp come on the screen or did you lose picture? Just because the LED indicator suggest replace lamp it doesn't mean it needs it. If your pix was dull or loss of brightness then replace it, if not then just reset your lamp timer, check your owners manual for instructions.
Feb 14, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Red light front of tv
If you still have a good picture, then NO, just reset your lamp timer. The instructions should be in your owners manual.
Feb 01, 2009 | Mitsubishi WD-52327 52" Rear Projection...
WD-52631 Red Light-No Picture, still have Sound
unplug it from the wall, wait 30 seconds, then plug it back in. i had the same problem and this simple solution worked for me. Good Luck!!!!
Dec 13, 2008 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi WD-52327 52 in. Rear Projection DLP
I have a 2 year old Mitsubishi Rear Projection 52" model WD-52525. I recently experienced the same problem as you. My TV quit without any warning and the red lamp light came on. I bought a replacement lamp just like you did, did everything you did too, but it still didn't work either. Since it's past the 1 yr warranty (of course), I took it in to an authorized service center for an estimate. They determined the light engine failed and it will cost me $816.35 to repair. I already shelled out $240+ for a lamp, $48 for the repair estimate and I said "hell" no, I'm not going to fix it for another $800+ and bought a new TV. I'm writing a letter to Mitsubishi expressing my deep dissatisfaction (to put it mildly) with this faulty product and will be requesting reimbursement, which I probably won't get. I sincerely hope this is not the same problem your TV has, but if it is be prepared for a costly fix.
Aug 06, 2007 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television Logo
388 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
