Question about Kodak EasyShare Z1275 Digital Camera
Kodak Easy Share Z1275 stuck lens
I turn it on the green light blinks for a second then it turns off. The lens is stuck out and wont go back in. Before it got stuck out it would turn on for a second and the lens came out a little bit then shut off until the lens was all the way out now it wont do anything but blink the green light and shut off.
  • 8 more comments
  • Melissa1212 Jun 11, 2008
  • chrisbinpara Jun 17, 2008
    I have the same exact problem. No grinding noises, no error messages. Press on button, blue light comes on briefly, then turns off. Lens stuck in extended position and doesn't move. Willing to open up if someone tells me what to look for and fix.
    Thanks,
    Chris
  • StephCamp Jun 18, 2008
    When I press the power button on my Z1275, the lens extends and the green light blinks. No picture or message on the screen. The only way to turn it off is to take the batteries out, but the lens stay extended. When I put new batteries in and press the power button, the lens goes back in then extends again and the green light flashes again.
    I sent it in for warranty repair and it worked for a while (took pictures and downloaded fine two times). However, before I sent it in, it was doing all of the above and after a while of trying and pressing buttons, I couldn't get it to power up at all. The camera repair person replaced a fuse, as far as I could tell from the receipt. Maybe the two problems were unrelated? We got the camera in January.
  • Anonymous Jul 16, 2008
    When I take a picture flash goes off but camera switches off and screen goes black although blue light stays on. Lens stays out. I have to switch off and on again then lens retracts.
  • Anonymous Jul 20, 2008
    Same issue here. I even sent it for warranty repair twice, and got it back working the same (or worse).
  • Anonymous Jul 28, 2008
    I have the same problem. I just got this today and it worked for about 30 mins. I put new batteries in and the same problem. The green light blinks and then it shuts down.
  • Citizen Mike Jan 23, 2009
    Camera lens came out and then the camera shut down. Several new batteries with no change. Blue light comes on, green light flashes and lens will not retract.HELP!
  • bud842 Apr 05, 2009
  • tckadmin Apr 16, 2009
    I turned on the camera, lens popped out, light blinked and camera went off. Every time I try to turn it on the light blinks and I get nothing. The lens is stuck in the out position.
  • Anonymous May 16, 2009
    This camera was a waste of my money...
I have a Kodak 1275. Green light would go on the off and lens was stuck open. Now for solution that worked for me. Get a can of compressed air, like what you use for computer keyboards. Blow the compressed air all around your stuck open lens, not to fast and switch directions of where you blow air around stuck opened lens. Make sure batteries are fresh and fully charged. Tap your camera against the palm of your hand twice, not to hard or you may damage instead of jarring lens lose. Next lay your camera on a table lens facing up, push power button on so camera will try to auto focus and lens should reseat itself and lens should move freely. It doesn`t have to look dirty or dusty, little tiny particles can cause the lens to get stuck and shut off fast because it is a safety feature. If this does not work try plugging your camera into computer so the lcd screen does not try to go on , thus giving even more power to get your lens moving . Do not try to force it closed by pushing or twisting with your hand or you may cause damage that will cost as much as the camera to fix.
Posted on May 04, 2009
I took the back off with 7 screws. moved the lens back slightly and moved everything forward nice and tight.. gor a small safety clip cleaned around above the lens not touching it,, took the memory card out and powered it on.. it showed the picture through the view and the lens went back in.. good luck ! like my bizzness page :) page. www.facebook.com/diamondinkoc if it worked!!!
Posted on Mar 18, 2012
  • Ruben Flores
    Ruben Flores Apr 13, 2016
    Www.facebook.com/diamondink714
My Z1275 was off with the lens open. When I turned it on, the lens moved a little, the screen came on
for an instant, and then the camera off.
Here is what I did to "fix" it.
I turned it on and helped the lens (gently) close while it was moving. It closed and the camera came on.
It must have been dropped and slightly bent in such a way where the lens could not close.
Good Luck!
Posted on Apr 14, 2009
I have the same problem with my z1275. If your camera's on warranty, don't fool around.
I just went to the Kodak web site, filled out a form, quickly got an email reply with painless instructions of where and how to mail the camera. They mention a 2 week turn around from the time they receive the camera - not bad.
Posted on Jun 21, 2008
I dropped my camera and it won't turn on!
OoW repair: 48,44 pounds
Alternative Trade up: Where you trade your old camera to a new camera for 25-30% less than market price.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 01, 2009 | Kodak Easyshare 1725043 M893Is Digital...
I am able to transfer images to my computer, but when I try to turn the M893 camera on when it's not connected to my laptop, the screen comes on for a second or two, lens comes out, green light is on and...
It has problem on the lens. Lens doesn't extend when transferring pictures that's why it works. Kodak cameras are designed to automatically shut-off when the lens is struggling to go in or out.
Follow step-by-step solution and repair on www.kodak.com/go/stepbystep if the guide did not resolve the issue proceed processing the camera for repair under the same website if it is still under in-warranty otherwise call Kodak @ 1800-235-6325 extn 1-12-2
1-English
12-Camera Dept.
2-Hardware and service dept.
Lester
Kodak Technical Support
Oct 04, 2009 | Kodak Easyshare M893 Digital Camera
STUCK LENS WONT WORK AT ALL
I just jostled it around and it came unstuck. however, there are now horizontal lines running across the frame...
Sep 07, 2009 | Kodak EasyShare Z1275 Digital Camera
Camera wont Turn On
Fixing your problem could be as simple as cleaning the battery contacts in the camera, or the solution could be a lot more complex and expensive. Here's a link to the Kodak Help Center - it provides a simple Q&A format to diagnose the problem and propose a solution.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Aug 02, 2009 | Kodak EASYSHARE M763 Digital Camera
**** a very common problem with most cameras. There hasn't been much of a solution for this problem except to try to wiggle the lens zoom while pushing and holding the power button.
Also make sure you have brand new batteries installed. Even the slightest dead battery will cause a problem.
Jun 02, 2009 | Kodak EasyShare Z1275 Digital Camera
KODAK M863 LENS STUCK
Here's what I did...Mine had the lens stuck out and would not power on. Just a green blinking for a second or two. Well, I tried twisting the lens ring closest to the camera while hitting the power button. It's kinda tricky to do...BUT, just keep at it. Mine was a $1 resale shop "find" and now it works. This worked for me. Maybe it will help you!
Apr 18, 2009 | Kodak EasyShare M863 Digital Camera
Kodak easyshare c533 lens is stuck
after 4 seconds view screen pic melts and goes blurry
Oct 19, 2008 | Kodak EasyShare C533 Digital Camera
My kodak easy share Z1275 won't come on
I used mine for 1 month & took 300+ pictures, loaded them to my PC. Took 10 pictures over a weeks time & while reviewing them, the camera powered off. I replaced the batteries, tried the "charged" recharchable set & the thing wont power up.WTF!!! .....the **** part is, we're broke & have a baby due any day.....we won't get pictures of our newborn.......signed - upset with Kodak....
Mar 15, 2008 | Kodak EasyShare Z1275 Digital Camera
Kodak EasyShare Z1275 Digital Camera Logo
1,457 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
