Question about SanDisk Sansa e250 MP3 Player
White screen every time  put on my sandisk e250 it show the sandisk sigh then it shows a white screen then it goes back to showing the sandisk sighn what do i do i miss my mp3
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jun 11, 2008
Sansa crashed have white screen
I have a e250 also and it white screened. I could'nt shut it off. I just left it on overnight and 1/2 of the next day until the battery went dead. Then pluged it in. It Worked!!!!
Jan 19, 2009 | SanDisk Sansa e250 MP3 Player
Sansa e250 white screen
did they send a recovery programme.
Sep 02, 2008 | SanDisk Sansa e260 MP3 Player
Broken screen
What do you mean,it show a broken screen,dose it say broken screen or is the screen broken?
Jul 09, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 MP3 Player starting problem
Do a Firmware upgrade first - http://www.sandisk.com/sansa/#/support-0/
Enter Sansa e200 series
If this does not work, try the other methods I suggest in my Sansa player "Tips and Tricks" - click on My Profile if you do not see the article in the solutions section (no offense to Fixya, but your website is not yet user-friendly - needs some work).
Jun 11, 2008 | SanDisk Sansa e250 MP3 Player
White sreen and wouln't charge
I would recommend you to try to reset the player and then get a firmware upgrade...to reset the player you need to hold down the power buttom for 15 to 25 secs...
to get to the firmware upgrade go to
http://www.sandisk.com/Retail/Default.aspx?CatID=1532
If for some reason after you have reset the device and get the firmware upgrade your device is not working you can try to use the recovery tools...
I hope this help...
Thank you
Computerrep
**Please rate accordingly**
Jan 28, 2008 | SanDisk Sansa e250 MP3 Player
It shows Sandisk logo and freezes there
Remove the SD card and try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Nov 13, 2007 | SanDisk Sansa e250 MP3 Player
Blank White Screen - No Menu Showing
My Sansa has a similar problem. Sometimes when the Sansa turns on (after the Sandisk logo) the screen will either turn black, blue, or black and white stripes. The player still works, but it is hard to navigate without the screen, obviously. What I end up doing is letting the backlight turn off and then pressing any button. Sometimes when the screen comes back, the display is allright again. But sometimes it takes more than a few tries. Turning it off and on again seems to work a little better, but it is more time consuming.
Apr 01, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
41 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
