Question about HP Deskjet F335 All-In-One InkJet Printer
Refilling ink cartrige 22
I need to know where to put the ink in what holes on the cartride
Black on the right color on the left
Posted on Jul 14, 2008
Canon mx330 how to change ink cartridges
Use the thumb drill to literally drill a hole into the side of the old cartridge. Make sure to chose a location that's closer to the top of the ink cartridge to avoid over spillage when you add the new ink. Once you have the hole just squeeze in some ink of corresponding color into the hole. Not a huge amount, but enough to get some use out of it before the next refill. I highly recommend covering the hole afterward with a sticker or something so that you don't dry out the cartride. Reinsert the cartridge into the printer and use. (: All set!
*Note: You may have to reset the count on the cartridge to avoid getting messages that the ink need to be changed. From here on in, use your eyes to determine if the cartridge needs a refill (:
Dec 07, 2014 | Apple Nano 69472169 4X130Ml Premium Refill...
I put a new ink cartrige in and the printer says no cartrige in any solution
your ink refill is the problemm,you need to clean de sensor of the cartridge
Feb 25, 2011 | Brother MFC 240C All-In-One InkJet Printer
Black ink does not work
A, Did u use a refilled one or a new one
B, Did u check that the black cartrige is touching the plate
C, Did u check that after putting in the cartrige the lock is put on
Nov 14, 2010 | Brother MFC-990CW COLOR INK-JET MFC Ink...
Problem with canon printer pixma M130 it displays
Ok you need to know this secret with canon and epson printers:
They do not allow any remanufatured or refilled cartriges to work on their printers. Sometimes their printers make sure that such ink will not work (just keep that in mind)
However, if you have been using refilled cartriges before, and it worked, then you may have a defective cartrige. Where ever you got this refilled go back and tell them that you need a newly refilled one because the one they gave you is defective.
If that does not work go to Cartrige world (hopefully they are around where you live) or someplace that will take your cartrige in and give you another refilled cartrige and hopefully its not defective.
I hope this helps let me know ok?
Mar 19, 2010 | Office Equipment & Supplies
Ink refill
You can do a search on Google using "Epson C84 Refill Instructions" which will produce plenty of hits. However, this one gives very clear instructions:
http://www.refillinkcartridges.co.uk/news/2008/10/16/epson-c84-ink-cartridge-refill-instructions/
If you only bought refill ink rather than a refill kit, and don't have rubber plugs, you can successfuly re-seal the filling hole using a small amount of epoxy resin e.g. araldite. This is easy to remove with a sharp knife the next time you want to fill it. Note the need for a cartridge re-setting tool - these can be purchased very cheaply on E-Bay.
Apr 07, 2009 | Epson Stylus C84 InkJet Printer
Refill the container
I have tried this by cracking open the case, drilling through a suggested spot (can't remember more than that), inserting ink suitable for the cartride, and then plugging the drilled hole with wax dripped from a candle.
It worked for a while, but then I got a terrible leak and made a mess of the table below the printer.
I'm thinking of taking my empty cartridges to a cartride-refill place (like Cartridge World here in Ontario Canada), but I haven't tried that yet....
Steve
Jan 23, 2009 | Brother Multi-Function Center MFC-240C...
Some print lines fade out making a poor copy
If you are seeing lines it is the cartridge and it's bad.
Refilled cartridges usually only work about one time and then the cartridges run into problems. They either leak or the cause lines in the copies.
If you can return and get a non refilled one, that should work.
May 20, 2008 | HP DeskJet 5550 InkJet Printer
Refilling an ink cartridge
The holes are under the top label - I'm not sure which hole is for which colour.
Apr 11, 2008 | Office Equipment & Supplies
Cannon IP1800 Ink Refill
need to know how to refill the cartridges. I don't see a place to refill them. It is cheaper for me to buy a brand new printer than it is to buy the new cartridges when the ink runs out. Thats crazy.
Nov 27, 2007 | Canon PIXMA iP1800 InkJet Photo Printer
HP Deskjet F335 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
