Question about Philips 50P8341 50" Rear Projection Television
I have a Philips 50 inch TV.
When I turn the power button on the remote or TV, nothing happens. Hit the power button again....and it flashes on for a split second and then goes right back off...
Any suggestions??
  • Philips Master
  • 3,459 Answers
May be related to a faulty IC. Check www.magnavoxhelp.com for a fix.
Posted on Jun 26, 2008
Philips 52pfl5704 no screen image
Sounds like main board fault. Contact the authorized service center for Philips. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 28, 2014 | Philips 42PFL3704D LCD TV
My 50 inch Philips Plasma TV is normally connected to a Virgin Media HD Box in order to watch TV programmes. Tonight my TV is showing a box that is called Information, and it has the wording No signal or...
Unplug both the set and box from power for a while--either may have caused a glitch---power both back with everything already connected and see if the reboot that will happen helps or not--a lot of times the box causes this by confusing the set it is connected to.
Nov 06, 2012 | Philips Televison & Video
My 50 inch is dead. Will not respond to remote or manual turn on Button. Not a thing no red light nothing.. ..
Philips televisions have been known to do this, this is because of its power source inside the tv, i would recommend replacing the part.
Jun 19, 2010 | Philips 50PFP5332D 50 in. Plasma...
I do not have a manual and need to know how to set it up and the code for a vizio tv.
On your remote you will find a setup botton and what i want you to do is hit set up then hit the tv botton and hit channal up and do that untell it turns off your tv are the channal if that works it tv botton again and your remote will work other wise in the back of your remote it well tell you a code number and go on line to philips and they will give your your codes for you.
Dec 09, 2009 | Philips Magnavox Learning Universal Remote
How do i search for an unlisted code for my universal remote?
This is the web site where I found the codes for mine, http://www.remote-codes.com/universalcodes.htm
Hope this helps, if not, let me knoe the model # and I can assist further...
Sep 17, 2009 | Philips Universal PH301S Remote Control
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Insignia 42 inch TV won't turn on
The power supply is in the protect mode. There are many things in the set that can cuase this. Most likely there is a short on one of the circuit boards, or the power supply itself has failed.
You will have to have the set serviced in order to get it going again.
Jerry G.
Jun 03, 2008 | Televison & Video
Philips 29PT8419-79R
the problem in power supply. if its output is ok than you will have to check horizontal section.
Sep 15, 2007 | Philips 27PT8420 27" TV
Philips 50P8341 50" Rear Projection Television Logo
85 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
