JVC tv i'art blinking timer
On timer light (green light) blinks on/off , power button can't turn it on or off. after it was reset-ed (5 min) Tv turns on for a few seconds and goes back on timer blinking again . Even after it was reset-ed for a day same thing happens.Thanks
  • oatkinson Aug 16, 2008
    My jvc tv model AV-27D502 started blinking the timer led and won't turn on for more than a few seconds. And that was only after I unplugged it for a while. It seems anything over 5 min of being unplugged does the same thing. It comes on for a few seconds and then turns off and the timer led starts blinking again. Note: before this happened the tv had a piculiar picture that seemed to be several of the top most lines of the screen were being interlaced back down into the picture. I thought it might be because the picture was drifting up too high and the lines were going off the top.
2 Suggested Answers
freetek
  • 5568 Answers
SOURCE: JVC tv i'art blinking timer
It is protecting you and itself with high probability.
Power supplies in modern electronic devices are designed to cycle if there is a fault in circuitry they are servicing and because of the design, also will not turn on completely if they are failing.
The older style of power supply was 'dumb' and unable to do this so could cause fires if the failure wasn't teh 'right' kind to blow the main fuse.
I agree with the manual; this is a job for a tech.
Posted on Aug 23, 2008
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Green LIght Blinking
Does the led ever stop blinking? No ..well in that case generally this indicates a standby voltage problem...if all those voltages ok then the cuircit known as digital module is at fault. also make sure the lockout has not been activiated. i really dont think it could but to unlock hold menu button down for 10 seconds. After all that i believe it would be a bad digital module
Willie@fordtv.com
Jan 08, 2008 | Mitsubishi WS-55813 55" Rear Projection...
Tv will not turn on,just has the flashing green light.after reseting the tv via the reset button the same problem persits
try hitting the sleep button over and over it reset my timer and I have had no more blinking green light problems
Nov 15, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Green light flikering
Replace all 7 capacitors in the DM Module on the DM Power Supply Board. If it is similar to the WS-65869 and WS-65513 it will have a metal enclosed DM Module at far left of chassis, looking from rear. About 4 or 5 connectors, screws, and Module slides out. Take top shield off. Take good notes or use digital camera or video recorder to make re-assembly easy. These capacitors are 1000uf@16 volts. They always check good, just replace them! After re-assembly plug AC in and wait 90 seconds or more (green Timer LED will stop blinking), then press Power button. If Timer LED doesn't stop, look for small pinhole (System Reset) and press switch with pen or small screwdriver, then wait for green LED to stop blinking. Then Power On TV.
Feb 08, 2009 | Mitsubishi WS-65809 65" Rear Projection...
JVC HD-52G787 52-Inch HDILA Rear Projection won't turn on
My tv wont turn on. It tries to turn on the green light lights up 3 times then nothing. what is wrong?
Dec 23, 2008 | JVC HD-52G787 52" Projection Television
Timer light blinks on and off and tv wont turn on
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
If ever resetting is no effect then the problem is in the "DM board"
The constant blinking green light means that the TV is not booting up. This is a common problem on this set. Hope it may help you; Regards, VOTIT
Sep 25, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Aug 23, 2008 | JVC AV-32260 32" TV
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Televison & Video Logo
251 people viewed this question
Top Televison & Video Experts
Electro Med Services...
