Question about Kitchen Ranges
Tappan Millenium 316065306
Range top works, the broiler works, but I cant get the stove to work. I took the bottom level off and then the lower baffle and I do not see a flame. How do I light this thing and where? It doesnt look anything like the manual...
Please help.
catriver
  • 878 Answers
SOURCE: Oven/Broiler Igniters for KitchenAid range KGST307
Guy, your missing some letters at the end of the model but I compared 4 different gas slide in's starting with KGST307 and the part numbers are bake ignitor 9751123 and broil 9751784. Catriver..post back
Posted on Apr 02, 2007
  • 109 Answers
SOURCE: old tappan in counter gas stove/range
sorry, misinformation, no such child lock existed in those days, either your spark module is bad or your switches are bad, (unusual for all switches to fail simultaneously)
Posted on Apr 03, 2008
duby1990
  • 367 Answers
SOURCE: Older Tappan range oven not lighting.
There is no way to light the oven manually. The gas valve will not open until the oven ignitor draws enough current. But replacing the ignitor will fix ya up.
Posted on Nov 19, 2008
  • 6 Answers
SOURCE: oven produces soot when running, broiler ok, stove top ok
Al, you need to seat the needle valve on the bake. Remove the bottom drawer, right below the bake burner you will see the nut just below the air shutter adjustment. Turn this nut clockwise a few times, it might seem hard but just do it. Then try the bake again, you should have a nice bluel flame. Tenbears.
Posted on Dec 20, 2008
  • 28 Answers
SOURCE: kenmore range broiler burns orange not blue and leake gas
The only real important thing is blue flame with a orange tip,
also ranges have different nozzles for Natural Gas (NG) or propane(LPG)
he can check for leaks with soapy water at the flex line connection
Posted on Jan 05, 2009
Indesit oven keeps heating
Tappan gas range, TGF334BCWB. I can NOT stop the broiler burner from lighting. I have unplugged the 110 power and I light top burner with a striker. However when stove is plugged in to the power the broiler burner lights and continues to burn. The oven knob is turned OFF. The only way to stop the broiler is to unplug the power.
Mar 11, 2014 | Whirlpool Accubake SF362LXTS Kitchen Range
Oven/Broiler doesn't work. Stove top works
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Jun 03, 2010 | Tappan TGFS26C Gas Kitchen Range
Ive got a tappan gas oven that wont light. The stove top burners light, but the oven or broiler wont. There is a ''glow plug'' that turns orange but the gas never ignites. What is wrong?
heatman101
gfgshg
Mar 13, 2010 | Tappan TGF320 Gas Kitchen Range
I have a frigidaire GAS stove. Oven doesn't work.
Even though the ignitor glows it does not mean that it is working...sounds crazy but it is true... the ignitor needs to pull a certain amperage to let the gas valve open and as they get older they stop pulling enough current...
Check out this tip I wrote about this problem...
Heatman101
Mar 04, 2010 | Frigidaire FGF316 Gas Kitchen Range
heatman101
ssgs
Feb 25, 2010 | Tappan TGF320 Gas Kitchen Range
Kitchenaid Gas convection range lower burner will
whirlpool oven wont turn on top burner work.
model #SF315PPQ2
Sep 04, 2009 | KitchenAid KGRT607HBS Gas Kitchen Range
Tappan electric range, brand new - top heats up
Call the manufacturer and ask them what to do, they can advise you as to what to expect when unit operates and possible cause. Most ranges on broiler will have some heat transfer to top, but this sounds extreme
Apr 25, 2009 | Tappan TEF242 Electric Kitchen Range
TAPPAN MILLENIUM GAS RANGE
hi thanks for the question so in your onen you are saying that the top broiler works but not the bake there is a igniter in the bottom of the oven ita an igniter same as the top replace it
Sep 15, 2008 | Kitchen Ranges
Tappan gas stove,oven not lighting
yes replace the lower oven ig nighter you can do this from inside the oven pull the racks out then locate two screws in the bottom oven pan take the out pull the bottom plate then pull the flame spredder pan and you will see the glow bar replace that most common for you compliant
Jun 03, 2008 | Ovens
Kitchen Ranges Logo
254 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
