Crack Dell Laptop Password U can search the above words via search engine and get ideal suggestion from search results!
Then, there will be solutions supported:
Step 1. Access other PC which isn't locked, download the
Windows Password Recovery Tool 3.0, install and run it.
Step 2. Burn a password reset disk. You can choose CD/DVD or USB.
Step 3. Connect the nearly created disk with the locked Dell laptop, config bios setting to make sure it boot from the password reset disk, reboot the computer.
Step 4. Choose the user that you forgot its password, click "reset" button to begin crack its password.
Step 5. A message box will pop up, just click "Yes", then the user's password will be cracked to blank.
Step 6. Disconnect the password reset disk, and restart Dell laptop. You will login Windows with a blank password.
Hope it helps you!
Where are you getting these OS discs at? Did the old HDD have a recovery partition? If it does...put that ****** back in there and upon booting press Ctrl + F11...it may take a couple times of doing this but you should still be able to get to the recovery screen to do a full system restore. **hope you didn't delete the recovery partition while trying to install all those OS's**
Does not have a recovery part. However i do have the os recovery disk shipped for this cpu from dell it does the same thing
Sounds like something could be overheating, but it doesn't make sense that it would install W98...unless it was much less of a load for it to take on. Could it be anything in BIOS keeping it from completing the install?
Apparently this is a pretty common issue...This might help
FROM DEHART @http://forums.techarena.in/vista-setup-i...
I borrowed this fix from another posting and it worked for me! I tried
for 3 days to fix this issue until I found this. I was using a Dell
Inspiron 1720. The drivers on Dell's site gave me what I needed during
the install process. I do not know how originally posted the fix below
but they are a life saver!
REAL SOLUTION FOUND
Your solution was an inventive one, however understanding why the error
is happening might shed some light.
The problem is caused because you need to load your correct sata diver
during the installation proccess. But there is a glitch here that traps
alot of people:
After you load the driver from the setup, Vista continues to install,
but later it needs to go back to the installation disk to get the
drivers again (for whatever reason), it will *NOT* prompt you when it
tries to do this, instead it just hangs, especially because people load
the driver from the same DVDROM that they are loading Vista from.
After Vista copies files and reboots, put the Driver disk back in the
DVDROM and during the "Completing Installation" It will search it
automatically and get the drivers and continue with the install.
If you used a floppy (for whatever reason) for the drivers, after
rebooting from the initial coping files part, put the floppy back in.
It is regrettable that MS doesn't handle this better, but alas that is
the case. Follow this and your error will disapear.
I have seen many posts about this on the internet and people suggesting
all sorts of crazy solutions. I feel sorry for the people that have
tried them all and have become so frustrated at Vista over such an easy
(yet unintuitive) resolution.
I thought about that so i removed the bios bat and normal bat and unplugged for 4 days i would think that would reset the bios? I seen the problems with the overheating so i paced a fan under ( its a small 110v fan that i set up because i was running in to the vista overheating thing controlling when the fan comes on) not luck still freezing on anything but 98. I just dont see how the board could be bad if it installed 98.
It is a intel chip set dual 2 with 3 gigs of ram. I ran diagnostics out of the bios and everything passed. I hate dells. I even tried installing 7 and got to the windows is starting and froze.
Do you think it could be that for some reason it will not or can not read the ntsf files but can read the fat32? Could it be a virus in bios i have never seen one but have heard of it.
ok that sound good, but 98 does not even have a sata drive on the disk. any ideas
Seems like you've put quite a bit of time into this...I'm not too fond of Dell either, but can't be any worse than an HP "Code Purple" I just got today...either way, I would try my last suggestion and see where that goes. The mobo is always suspect but I don't think it's the problem in this case. I think it's that SATA driver that needs to be loaded. I'll run it by a couple guys at work tomorrow and see what suggestions they have...I'll get back to you.
I see where you're going with that...doesn't quite make sense to me either but maybe the 98 install had everything it needed...I'd try it with the vista disc again to see if it works. I'm confident you'll figure it out.
thanks pnky_14 i will try it but at this point i am at a loss right now its a 5 lbs paper weight(lol)
I was thinkin the same thing about the paperweight...if you have MSN just add me... [email protected]
i have not i left the computer at the shop last night and have not been in yet today being lazy but i will let you know but it my work i have noticed that when it freezes up the hdd read light does not come on. so if it is trying to read the sata drive with out the driver ? the only thing is that i have the bios set to ide mode. but its a dell and we both how hard they are to work on?
I dont have Msn but my emai is [email protected] guess i should get it
