Question about Admiral AW22 Top Load Washer
Admiral LNC6760B71 when goes in to spin cycle the water come out the top over flow. It dosn't mater what water level you but it on..Carmon
  • rorochef Dec 31, 2008
    No matter what size load /i have the button on the water fills and overflows, flooded mt basement 3 times during this holiday. Help please.
    Scholar:
  • 116 Answers
Probably the pump or filter is blocked, remove the pump and filter and remove any debris
Posted on Jun 18, 2008
It won't turn on
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com Troubleshoot your Admiral Top Load Washer that has these following ... The machine will not complete cycle (fills but won'twash or agitate) I recalibrate it and it ... my washer will not startbecause of lid latch it is an admiral.
Sep 29, 2015 | Admiral Washer Control Panel Frame 35-5733...
Admiral washer model AW20N2V making a clicking sound...
call manufacturer. heard there was a recall... for dangers of fire.
Oct 02, 2012 | Admiral Washer Control Panel Frame 35-5733...
Admiral washing machine keeps filling up and will not stop till I turned my water valves off, and then it will not wash the clothes but will spin them .
The water level sensor is faulty. After the inlet valve is opened the program controller needs the signal fromt he water level sensor. Thi is normally a pressure switch and as the water builds up the tub through a small opening the water flows through a tube to trigger the switch. So find out the pressure switch and replace. Only once the sensor clicks will the program proceed to wash . Otherwise you can spin becasue the water level sensor need not work for spinning as the level is down.
Sep 17, 2010 | Admiral Washing Machines
Wash machine will not stop filling/no matter what setting the level is set.it will spin out. How do I fix this. It is an admiral capacity plus. model # LNC6760B71 serial # 20672581CL
Most probably an inlet valve fault. Could be the water level sensor hose has diconnected, or the drain hose is too low, and is allowing water to flow through into the drain.....Check drain hose......If water flow is not stopped when you unplug the machine, it's probably a valve.....Not a big job........Good luck......Nomess
Mar 24, 2010 | Admiral Washing Machines
Admiral Top Load Washer Model LNC6762B71 overflowed
Remove the control console cover. Find the water level switch.
It has a small tube attached to it.
Remove the tube and blow air through it. It is probably stopped up. Reattach it to the water level switch.
Look over the length of the tube and may sure it is not pinched.
Set the washer to spin and run spin for about 1 minute.
Then run water on a lower level and see if it shuts off.
If not replace the water level switch.
Feb 28, 2009 | Admiral AW22 Top Load Washer
WON'T SPIN DRY
You need to check if there is power to the motor. If so the motor is defective.If not, the timer may be the problem. There should be a wiring diagram on the back of the unit. Using a voltmeter, trace the power.
Ray
Dec 17, 2008 | Admiral AW22 Top Load Washer
Admiral Washing Machine not spinning
y Admiral washing Machine modle # lnc6760b71 will fill with water and agitate. But when it come time for the spin cycle it wont spin. I can hear the motor making noise. and now stop and it does not work, does not smell to burned What should I do??
Jan 06, 2008 | Admiral AW22 Top Load Washer
Admiral mod#lnc6760b71
Water runs out, but does not spin, nor dry the clothes. Motor is good.
Dec 08, 2007 | Admiral AW22 Top Load Washer
Admiral AAV8000AWW washer - clothes are wet after spin cycle...
may be a loose belt or a partial blockage somwhere.
Nov 09, 2007 | Admiral AAV7000A
Washer spins agitates, but will not drain
Possible your outlet filter is blocked; find out where it is from your manual, clean it out and re-fit. Also try the spin only function to see if it drains.
Jun 13, 2007 | Admiral AW22 Top Load Washer
Admiral AW22 Top Load Washer Logo
190 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De GO PATS
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
