Question about XM Radio (XMP6000)
Delphi roady 2 won't power up
First symptom: unit would turn off when channel "0" button pushed; then unit began not staying powered up when power button was pushed. checked cig. lighter - all ok. put unit into a home unit (ac to dc power transformer) - powered up a couple of times, then turned itself off; now won't power up at all. unit is approx. 2+ years old. thanks, rr
  • Anonymous Apr 14, 2009
    Noticed my unit would not power up again.
You have a bad power plug on the unit. The solder connection are loose. The one have is doing the same thing. The power plug pins have came lose and need to be resolder. Working on how to take the unit apart to solder the connection.
Posted on Dec 09, 2008
My radio just recently goes up to 119 and several of the channels i listen too come up as updating....and won't play.
Give XM a call, since they merged the channel lineup has changed. Have them push a new activation signal to the unit, which should unlock the rest of the channels. However, the roady XT isn't exactly known for its reliability, so the receiver itself might be dead.
Sep 12, 2011 | Delphi Roady XT XM Radio Receiver
When I press the power button the screen flashes once & then goes blank again. Some times I see a quick flash of "XM-Radio" This started happening overnight one night-nochanges on our part.
I had exactly the same problem with my Roady XT. The power supply gradually failed, with the symptom that the reception kept getting weaker and more spotty. Finally, the Roady would not turn on. The screen flashed as you describe. I happened to have another 5VDC, 2A power supply in the closet from some other electronic gismo from the past (I save the power supplies just in case). the connector on the old power supply was not correct for the Roady XT, but a little surgery put the new plug on the old supply... (verified by a volt meter). When I plugged it in the Roady quickly turned on and showed full signal strength. This had never happened in 2 years of use. Apparently this radio needs more power than the stock power supply can provide. Now it "loads" stations in 2-3 seconds and never fades.
Jul 12, 2009 | Delphi Roady XT XM Radio Receiver
My xm roady will only turn to certain preset stations
Turn the unit off and on with the power button and you should be able to get channel 1. Can you get Channel 1? If so, then call XM and ask them to send you a 'refresh' signal to reactivate your subscription on the radio. okay?
Mar 14, 2009 | Delphi Roady SA10035 XM Radio Receiver
Delphi roady home kit won't change channels
Solved my own problem! Press the Preset/Direct button located just above the 5and 6 on the bottom of the receiver. You should now have" Direct" displayed in the top left corner of the display.You are now good to go.
Oct 26, 2008 | Delphi Roady Xt Home Kit Sa1017611p1
Roady xt
i figured it out with help from a delphi service rep.! you need to go into the menu and reset to factory default.this will erase everything you have changed from the factory settings,but once done you can reprogram your settings and they will stay. step 1-enter menu step 2-reset factory default settings step 3-reprogram your preset stations,FM freq. colors etc. step 4-use power button on the roady to turn it off.once the roady shuts down turn it back on with the power button. step 4-now you should be able to turn the key off without erasing your presets.
Apr 25, 2008 | Delphi Roady XT XM Radio Receiver
It turns on, but that is it
Won't turn on just flashes, tried a sister unit from truck and it works fine.
Apr 11, 2008 | Delphi Roady XT XM Radio Receiver
Delphi Roady XT Radio won't turn on
You need to replace the transformer that plugs into the wall.
Dec 17, 2007 | Delphi Roady XT XM Radio Receiver
Delphi Roady XT won't turn on
Same here, it's nice to know I'm not the only one with this issue at least; but as to a way of solving this, I've found nothing.
Dec 07, 2007 | Delphi Roady XT XM Radio Receiver
Power Problem
I had same problem - tried reciever in my car and no problem. I suspect the power supply and have ordered another.
Dec 07, 2006 | Delphi Roady XT XM Radio Receiver
Car Audio & Video Logo
284 people viewed this question
Top XM Radio Car Audio & Video Experts
xxxxxx xxx
Electro Med Services...
Are you a XM Radio Car Audio and Video Expert? Answer questions, earn points and help others
