Question about Lexmark Office Equipment & Supplies
Need the number of this?they tell me i have to install a new driver when i change cartridge is this true?
    Guru:
  • 1,463 Answers
Hello edward
which printer do you have .
(they tell me i have to install a new driver when i change cartridge is this true?)
never heard the above before who said that you need a new driver.?
is the printer all running ok as should be ,can you print anything ?
do you need the driver ?
if you req driver can you post back your windows o/s and printer model.
riz.
Posted on Jun 05, 2008
Installed new cartridges in Canon i850 and printer seems as though it is printing but does not grab the paper from paper feeder and gives an error (no number). Instructs me to press REsume button and power...
I changed the USB port that the printer was connected to and... VOILA...works like a charm with the new cartridges installed. Not sure what the problem was as windows recognized the printer and the drivers were correctly installed before the new cartridges even came into the picture.
Nov 25, 2009 | Canon i850 InkJet Photo Printer
I just installed a new color cartridge in my 8650 Lexmark printer. The ink cartridge acts as if it is empty. Printer keeps telling me to align cargridge. Worked perfectly before the new ink installed. Not...
  1. On your computer, go to "Start," "Programs," "Lexmark Series." Click "Lexmark Control Program."
  2. Step 2 Select the "Cartridges" tab. Click "Change Cartridges." The Change Cartridges screen appears, displaying the animated instructions for installing or changing cartridges. When you have finished viewing the animation, click the "Finished" button.
  3. Step 3 Remove the tape covering the print head of the new print cartridge. Insert the new print cartridge as shown in the animation.
  4. Step 4 When the "Choose Cartridges" screen appears, select the cartridge(s) you installed in your printer from the list boxes. Click the appropriate box to reset the ink levels to full. Click "OK."
  5. Step 5 The Automatic Alignment screen appears. Click "Align" to align the print cartridges for best print quality. The printer prints a page with a bi-directional alignment pattern. On the printed test page, locate the number that comes closest to forming a straight line under the bi-directional alignment pattern. Enter that number as the bi-directional alignment setting in the Alignment Cartridge dialog box. Click "OK."
Nov 25, 2009 | Lexmark All-in-One Printer with PictBridge
My lexmark x6690 wont print after i refilled the cartridges,it tells me the cartridges needs re placement,how can i overide this ?
if you are using cartridges number 36 and 37 (or 14,15/ 23,24/ 28,29/ 41,42), you can only override it by buying new cartridges. But they need to have a letter A after the number, i.e. 36A and 37A- those cartridges can be refilled, the ones you get with the printer can't. They are, as Lexmark calls them, "return program cartridges", which means they can be used only once. "Return program" means you can send them back to Lexmark and they will refill them for you (not sure if that is true, but that's what Lexmark says on their website)
Hope that helps!
Nov 01, 2009 | Lexmark All-in-One Printer with PictBridge
Installed a new Lexmark ink cart and got an incorrect message
take out the cartridge , turn off your printer and take out all the cables behind your printer and wait for 5 minutes and put everything back in.. if the same error shows.. im sorry but your printer needs to be replaced.
Aug 15, 2009 | Lexmark X2500 All-In-One InkJet Printer
Lexmark X2530 won't accept re-inking of cartridges
This is a trick that is used on some of the HP printers. Try this, you will need at least 3 maybe 4 cartridges. The printer stores the chip ID in memory for the last 2 or 3 cartridges installed, so, take an old cartridge number 1 and install in the printer, reset power. Next step, take old cartridge 1 out and install old cartridge 2 in, let it come to ready or tell you to replace empty, then install your refilled cartridge. You just have to remove from its memory the chip ID of the refilled cartridge. You can fool it by doing this each time you refill. Can't guarantee this will work with lexmark, but it does work with HP.
Hope this helps,
Printdoctor
Dec 20, 2008 | Lexmark X8350 All-In-One InkJet Printer
Region settings for HP Photosmart D7160
You can try this, but I still thing you need HP tech support to tell you which numbers you should enter, because they vary from printer to printer.
  1. You should have your printer connected to a windows PC with a USB cable even if it is a network printer.
  2. Press * and # keys to bring up the "Mfg Commands" screen. I assume this is only used by HP service staff.
  3. The "Mfg Commands" screen asks you to "Enter special key combo" which is 123 then press ok.
  4. Use the right arrow key to step through the menus until you find the "Special Reports" menu then press ok.
  5. Use the right arrow key again to find the "Print Cartridges" menu and press ok
  6. This will print out a page with numbers ranging from 11. to 74. This page will print regardless of the print cartridges in the printer and whether they are valid print cartridges.
  7. The numbers of interest to HP support will be 11,21,25,52,62
  8. They will use the above information to generate a new set of five lots of 4 numbers.
  9. You will need to enter the 5 lots of 4 numbers onto a windows PC which has the HP drivers installed.
  10. On a windows PC with HP drivers installed open notepad and select print to bring up the printer dialog .
  11. Click on "preferences" in the print dialog window to open the HP preferences dialogue.
  12. Holding down the control key double click the HP icon in the bottom left corner of the preferences dialogue to open a service maintenance menu which will allow you to enter 5 lots of 4 digit numbers which HP staff will provide.
  13. Once you have entered the 5 lots of 4 numbers and press ok a data file is sent to the printer which changes its region settings.
  14. You then have to switch the printer off for about 1 minute then back on again and your new cartridges should now be valid.
Or try this, but I'm not sure if it works:
  1. press *# together
  2. press 127
  3. change from user to mfg mode
  4. shut down restart
  5. press power button after a graphic screen
  6. see rainbow screen
  7. press power button again
Dec 12, 2008 | HP PhotoSmart C4180 All-in-One Color...
Dell A960 cartridge problem
Does the black cartridge print? If not did you take the tape off of it? Error 50 is a generalized error reading relating to a number of cartridge problems. If the color cartridge is empty, it may be theproblem although I have not found this to be true on Dell printers. If you remove the color cartridge and reinstall it the reading will indicate its full (even though it isn't. This may solve the problem.
Sep 19, 2008 | Dell A960 All-In-One InkJet Printer
How to install lexmark print cartridge
open up the top, the cartridges should center, pull the holders up, remove cartridges..be mindful to clean and re calibrate them after installing new ones.
if you need new drivers you'll find them here
Mar 11, 2008 | Lexmark X2470 All-In-One InkJet Printer
29 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
