Question about Saeco Talea Giro Espresso Machine
Water from steam nozzle
I purchased the machine in october last year and have had no problems till now.....when i start to make the coffee, water pours out of the steam nozzle at the same time the coffee is brewing, making less coffee each time. a friend who had the same machine had this fault right from the start.
  • 1 more comment
  • Anonymous Jun 10, 2008
    same problem
  • Anonymous Oct 19, 2008
    Same prob here, after only a year's use...
  • Anonymous May 24, 2009
    We've had the Talea Giro for almost a year. Best of 3 espresso machines we've had. Just started leaking water from the steam nozzle during brweing cycle. seems like a seal or o-ring. Their Service Center said it's covered under warranty, but we need to pack it up and pay shipping to & fro. Could be 2-3 weeks ! back to the manual method for a little while. How spoiled am I ?? Great machine !!
Mine needed a new "O" ring. This is not a user fix, needs to be sent to an engineer under warranty
Posted on Jul 06, 2008
I purchased a Talea Ring in February this year and have exactly the same problem
Posted on Jun 10, 2008
  • 515 Answers
You have to send it to Saeco service center so they can fix it, it is the gasket in the steam valve that is leaking.
Posted on Jul 11, 2008
Eam3500 steam nozzle o rings need replacing
The nozzle should screw out anti clockwise allowing access to o rings, persevere anything can be repaired.
Nov 21, 2013 | DeLonghi EAM3500 Espresso Machine/Coffee...
Steam nozzle not working
Check the end of the steam valve, if that is not blocked, check where the wand connects to the valve, on some models they inserted a teflon piece that was supposed to hep the machine with steaming but that gets blocked, remove and throw away.
Apr 16, 2010 | Saeco Royal Professional Espresso Machine
Gaggia Coffee Delux Steam pressure probem
1: do you pres the switch for steam and wait until it is ready? 2: how long time machine needs to be ready for steaming?
solution 1 = if you don't press the steam switch on you will have very small amount of steam. solution 2 = if the machine gets ready only for few seconds to steam, than you must change your steaming thermostat attached in boiler(there are 3 of them: 1 security 2 coffee brewing 3 steam
i hope you fix it soon and enjoy in perfect espresso
Apr 04, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
I have saeco incanto deluxe coffee machine,ventilate msg appears
Check the end of the steam nozzle, make sure it is not blocked. If not then with the knob open for hot water cycle push in on the knob if that works then the tap rod assemble or the steam valve needs to be replaced.
Feb 20, 2010 | Saeco INCANTO DELUXE Espresso Machine
My Miele CVA620 machine announces 'Expel Air,' and
I'm probably to late for this answer, but I will share it anyway.
I got this problem after buying a used CVA620, that had not been used for a while.
To solve the problem i used a breast pump :-)
My wife had this doublepump after the last kid. And I used the hoses that comes with this unit (rubber-like) and connecting them to the hot-water and the steam-nozzles. I started pumping, and pushed the hotwaterbutton. After 5min of pumping and swearing, the job was done. No my CVA works as a charm again :-)
Jul 05, 2009 | Miele Coffee Makers & Espresso Machines
Maxkon SK 201A Coffee machine only has one rubber pipe
hi - had same prob= found out modern maxcon machine has only one tube in water tank- other is internal. turn steam knob to off position- anti clock - and wait till water / coffee light is green- then water will come out from filter . when wanting the steam- turn the steam knob clockwise - hope this helps - susan
Jun 27, 2009 | Coffee Makers & Espresso Machines
Water not getting through
If you look under that white nozzle you will notice a small hole that leads to the drain tray, clean out hole and the area or small enclosure around the white nozzle (clogged with coffee grounds), and make sure that if you pour a little water in that enclosure it goes to the drain tray. That will solve the water under machine problem.
For the amount of water from the coffee nozzle, check brew unit, you will have to remove the shower screen and clean, make sure that the unit is not clogged in one of the tubes.
May 19, 2009 | Solis Master 5000 Espresso Machine
No steam coming out of heating nozzle for Wega
Remove the nozzle on the end of the steam wand, them open valve to see if the steam wand works, if yes use a paper clip to clear holes on nozzle, if no remove steam wand where it is connected to the valve then open wand(steam will be spraying be careful). If you have steam there then clean wand and nozzle.
Dec 16, 2008 | Wega Mininova EPU Espresso Machine
Part 2 -Flashing water light - will drain water but will not make coffee
Blinking light often means pump is not delivering water. Possible blockage from corrosion. Can also mean a valve blocked.
Do you hear the pump run?
Dec 11, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco Talea Giro Espresso Machine Logo
674 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
