Question about Carrier 38CKC042 Air Conditioner
Carrier 38YRA-O24 compressor tries to start 3-4 times before finally starting. Any ideas?
  • 828 Answers
Does this happen just when you shut it off and try to restart it immediately? If so it is trying to start against pressure that has not been given time to balance out. If this happens at any time the unit tries to start it could be low voltage or a hard starting compressor. They make hard starting kits for this purpose.
Posted on Jun 06, 2008
Carrier 38YRA 042 Fan Motor Problem?
plz check if there is anything obstructing the fan movement.if not then the motor is the culprit.
It will be better if you leave it for professional
Jun 07, 2008 | Carrier 38CKC042 Air Conditioner
Replace compacitor on Carrier 5 ton 3 phase AC
Your 3 phase unit should not have a capacitor. I'm guessing it's single phase. If it's a single capacitor than the compressor should not be going to it also. To test the motor, common to start plus common to run should equal the ohms you get between start and run. For instance, 1.2 ohms+ 2.2 ohms= 3.4 ohms. Follow the wiring diagram on the inside of the door, send model number!!
Aug 29, 2017 | Carrier Heating & Cooling
Carrier ac model 38ckc does not cool properly. Outside unit runs but air coming out of the top is cooler than the other units that we have. Just had a service replacing all the filters and coolant checked...
Air conditioner compressor will not start. When power is applied to the air conditioning outdoor unit the fan starts, but you hear a sound like the compressor is trying to start, "UGGG"..., for about 5 to 10 seconds and then all you hear is the outdoor condenser fan run. The compressor is locked and will not start. What is happening is the compressor is trying to start, but because the compressor motor is locked it tries to start for a few seconds and then because of the high amperage being drawn goes off on internal overload. The internal overload protects the compressor windings from overheating and burning up. I see this many times during the start of the air conditioning season. Some compressors just have a hard time starting after sitting all winter long. Some compressors are locked up so bad that I can not start them and must tell my customer that they need a new compressor . Many times I can get the compressor started again without having to buy a new compressor by using the device called, "Super-Boost." I keep two or three of these on the truck. They have saved many of my customers from having to buy new compressor
Jun 20, 2011 | Carrier 38CKC036 Air Conditioner
Unit keeps trying to run, but stops, then trys again. this happens 2 or 3 times until unit finally starts.
Hi, The compressor is taking a few tries to start...the capacitor is probably bad...this does not give the compressor the kick it needs to get started...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 28, 2010 | Haier 45-Pint Dehumidifier
24ABR348A0031010 compressor starts then stops. Carrier 4 ton R22 unit. Worked great, then fan runs all the time. Compressor will start for less than a minute, then stop. Basically compressor will not stay...
Hello RR Hard start can't hurt BUT dosen't sound like the problem.Do you have a scroll compressor?They don't need a kit.Does it start every time?It could be short cycling on LOW PRESSURE SWITCH.If the unit is (pumping down) during the run time you have a restriction in the system.Make sure the service valves are open ,do you have a filter dryer colgging up or a bad TXV valve also could cause short run times.20-30 PSI the switch cuts out.
Jul 15, 2010 | Carrier 38BRC036 Air Conditioner
When unit starts the condensor fan only comes, not compressor
You need a new fan motor and the correct capacitors for your sydtem I think they are 35 or 45 5 cap. Try a hard start kit on compressor. Are you sure you have the cap wired correctly?Russ
Jul 16, 2009 | Carrier 38CKC036 Air Conditioner
My Carrier compressor model 38BRC060360 is getting loud. Does that mean it is going to fail? Thank you.
when you say "getting loud" is this only on start up or when the unit is operating? If it is on start up it could be a problem with the starting components, or with the time delay not allowing enough time to equalize on the off cycle. during operation it could be that the charge is incorrect, as the compressors are cooled by the suction gasses returning to the compressor, over or undercharge could cause excessive noise. It could be your mounts that hold the compressor to the case as well, there is not sure way to tell if it is getting ready to "go out" without performing regular megaohmmeter checks, and this process must be started when the unit is new, and checked periodically over its life.
Jul 12, 2009 | Carrier 38BRC060 Air Conditioner
Very hot outside. blower comes on but outside fan
Check the voltage source for the fan and compressor
Check the start capacitor for the compressor.If its over heating :bad compressor
Jul 05, 2009 | Carrier 38BRC036 Air Conditioner
Carrier A/C Unit
Be sure that the starting capacitor is good. If the compressor is stuck up the starter power pack may help but sometimes it fail.
Sep 08, 2008 | Carrier 36KCARMS Air Conditioner
Carrier 38CKC042 Air Conditioner Logo
160 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
