Question about Hitachi 43UWX10B 43" Rear Projection Television
Hitachi 43FDX28B
Hello
I am trying to hook up a vcr to my tv and need help can you help me? Does this tv have a RF or AV connection on the back.
    Novelist:
    Scholar:
  • 100 Answers
Greetings southyank39,
The closest I could find to this model is a 43FDX20B, you can find the owners manual at:
https://merchant.satisfusion.com/sf/WarrantyCenter/registration/secure/Hitachi/Manuals/ModelNumberManualLinks.jsp?ma
According to the manual you should have two RF or coaxial connections, and five AV connections.
There should be a really good diagram on how to connect several pieces of equipment on page 12 of your manual.
I hope this helps.
Jon
Go Ahead. Use Us.
Posted on Jun 05, 2008
I need instructions for hooking my VCR to my TV set,
using a scart cable, connect the tv socket on the vcr to the scart - in socket on the tv.
good luck.
May 10, 2011 | Philips Televison & Video
We have no manual - need instructions on how to hook it to the TV.
Nintendo 64 Hookups
Quick Tip! If your system is connected using AV cables and you cannot see the game on your screen, it is likely all you need to find is the input select on your TV or VCR. Link here for help.
The Stereo Audio/Video Cable that is included with the Nintendo 64 will allow you to connect the Control Deck to most televisions or video cassette recorders (VCR). First, look at the back of your television AND your VCR and see if you have Audio/Video inputs . Though your TV may not have them, almost all VCRs do.
If you DO have AV inputs, choose where you want to connect to:
Audio/Video Cable to a TV
Audio/Video Cable to a VCR
If you do NOT have AV inputs, you will need to use an RF Switch and RF Modulator for your hookup. The RF Switch and Modulator are sold separately. (Where to buy):
Connecting the RF Switch to a TV
Connecting the RF Switch to a VCR
Other Hookups
Feb 24, 2011 | Nintendo 64 Console
How can i hook up a cd player, there is only one hookup in the back and that is for the cable.
Does the TV has AV? IF it has, then you would have to look at the back of the TV again, there should be a 20 pin connector if you don't see the place where the yellow, white and red wire will fit into.
If the TV does not have AV, then follow the steps below;
  1. Get a Video cassette recorder (VCR)
  2. Use an RF wire to connect the TV to the VCR.
  3. Search the TV station to get the VCR displayed on the TV
  4. Connect an antenna to the VCR
  5. connect your CD Player to the "in" of the VCR
  6. Press the AV on the VCR and your Cd player would display
  7. By now it should be ready for use.
If you miss any step, let me know so that I can direct you further.
Best wishes.
Dec 22, 2009 | Orion STV2763 27" TV
Magnavox dv220mw9 does not have a ant. in,or ant. out. How do I hook up to my direct tv satellite rcvr. My original hook up is from a DTV d10-300 RCVR to a Sylvania vcr/dvd SR2900,which has a antenna in...
have this model..was trying to hook it up to a directv hughes receiver.After a day of trying and many curse words I found that using thishookup works . Hook up your satellite connection to you tv asusual...Now plug rca cables(red,yellow white) into the corresponding holes on the BACK of the Directvreceiver ..now plug the rca cables into the FRONT of the Magnavoxplayer...you will only use find holes for the white and yellow(that'sok) Now hook up up the dvd player2.gifto the tv using the rca connection back of dvd/vcr player..or if yourtv only has a coax connection you will need a rf modulator available atwalmart etc. You will run the dvd/vcr on L2. The key is the connectionsto the FRONT of the dvd/vcr player..I hope this helps..:)
Jun 04, 2009 | Philips Magnavox DVD/VCR Dual Player
Recorded play back is fuzzy
MOST LIKELY the RF out put signal is the same as a local tv chanel 1) try menue change rf output suggest rf 68! OR connect av leads (red white yellow)from the output of your vcr and connect the other end to an Av input eg AV1 on your TV use tv remote to select the AV input
Apr 21, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Hitatchi 42HDF52 only receives channel 5 and 6 on analog RF input
If you have tried autoprogramming and have found nothing it may be a bad tuner. Is your VCR is hooked up via coax or into a video input? If it is hooked up via video and is working but the coax connection direct isnt it will be a bad TV tuner. Easiest cheapest fix is to use you VCR to change channels or get a Digital Cable Terminal from you cable provider and hook it into video or compnent.
Jan 29, 2009 | Hitachi 42HDF52 Television
CONNECTING DVD/VCR TO CABLE BOX & TV ETC
moz-screenshot.jpgHI-
Check this site for Info's how to connect your device, click HERE
keep me posted for inquiries, thanks!
Jun 30, 2008 | Philips Magnavox DVD/VCR Dual Player
Problems hooking up a VCRplayer
Hello..try to turn on the test signal generator switch it is marked test at rear of vcr...and chose av¨rf channel on your tv i.e the 0 or 9 channel than search for the vcr and memorize on tv...alt you can playback a tape ..pre-recorded without the test signal and make the search...alt 2...use a direct av-cable between vcr and tv..which is best and put tv in av mode...good luck...Ron
Mar 11, 2008 | Televison & Video
Trying to Install
Do you have the red, white and yellow hookups on the back of your TV????? If you don't then you need to get an RF Modulator. You can buy one at Walmart. Older TVs don't have the red, white and yellow hookups. You hook up the RF modulator with a short cable to the cable outlet on your TV. Then you plug in your DVD player to the RF modulator. You also plug your cable for the TV into the RF modulator. It really is very simple. Directions are included with the RF modulator. You will need a short piece of cable also.
Feb 04, 2008 | Panasonic DVD-RV41 DVD Player
Zenith xbr716
ALL cable is digital.
What type of TV do you have? Does it have any scart conections on it? If not connect the Cable box with a scart lead to your VCR select the AV channel on your VCR, connect your VCR to your TV via the RF connection, (if it has not got one, its not a TV, its a monitor). Tune your TV in to the video channel.
You do not need an RF modulator for a home TV setup, whoever told you that is a fool.
Dec 28, 2007 | Zenith XBR716
Hitachi 43UWX10B 43" Rear Projection Television Logo
67 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
