Question about Whirlpool Calypso GVW9959K Top Load Washer
Caylpso washer hey master tech you around im trying to help a guy with a caylpso washer its a drain spin promblem it drains and spins for a few secs stops starts for a few stops etc he says it does like its supposed to in test mode its not displaying any codes we have ohmed all the wires motors etc got 120volts from p1 to motor controller so he replaced motor controller still same promblem any ideas
  • 2 more comments
  • helpnanni Jun 07, 2008
    My washer is about 5 years old and is now doing the same as described. It will start to wash and then when it goes to drain it cuts out then back on etc. I have turned it off and waited over night then did rinse-spin and it worked fine. Tried to do a small load and after awhile it started cutting out again. Tried to do rinse-spin or just extra spin, kept cutting in and out. Waited over night and it went through the rinse- spin. Repair person said it is either the pump or some kind of cellinoid valve. He said he fixed another machine that was doing the same thing. He is suppose to come on Monday. Will let you know what happens.
  • robert samples Jun 09, 2008
    we replaced the controller master tech i have the manuel wouldnt bother if it was simple
  • robert samples Jun 11, 2008
    I put a new machine controller board in it last night as you
    recommended and it has washed many loads flawlessly since. My wife
    says it runs smoother. Considering that it is not a standard drive
    motor, but is controlled with speed and direction, I suppose that is
    possible --anyway she thinks it's as good as new.
    Something I noticed on the new version of the machine controller is
    that the flood switch is no longer used. There is a jumper on the
    board in place where the connector used to be. That sensor must have
    been more trouble than it was worth.
    As far as thinking that the problem was the motor controller board, I
    was totally in agreement with you that it should have been the faulty
    part. In other words, no hard feelings here. And it will be going back
    shortly for a refund.
    Thank you so very much for your help with the calypso. I hope to have
    it for another 7 years of good service.
    My highest regards to your trouble shooting abilities and also your
    patience. And my wife also sends her thanks --that's really special.
    Doug Olsen
    (DougInSachse)
  • helpnanni May 11, 2010
    To Master_Tech,
    I am new to this and hope I am posting this right. The repair person came and replaced the inlet valve assembly. Each valve had a selenoid switch attached to it. He put it on the Normal cycle and said to let it run through the cycle and left. At 24 min it started to go on and off. There was no water in the tub and none would come in. He came back and worked on it while having a Whirlpool tech on the phone. They could not get it to work. They said they would get back to him in about 5 days! My email is chse63@yahoo.com. Any help you can give me would be much appreciated. Thanks
  • 770 Answers
Sounds like a motor controller issue i have the manual post your email if you want it
Posted on Jun 09, 2008
My the front load washer model gcvh6900jww has the red lock on the display. I accidentally held the start button for a few seconds and it locked. I tried holding the start button again for up to 20 seconds...
  1. Found This HelpfulSometimes something will go wrong in your washing machine that will cause it to lock up or stall. An overloaded washer or a brief power surge can cause this. The washer may not drain or spin properly, or it may stop the cycle in the middle of the wash. Another cause may be that the washer was stopped before the cycle was able to complete. In this case, the washer will spin and drain over the next 24 hours, but it will stall before reaching the final spin. GE has two simple methods to reset the controls
For Newer Washers:
    • 1 Unplug the washer.
    • 2 Twist the control dial around the cycle settings.
    • 3 Place the dial on any setting other than the final spin.
    • 4 Ensure that the water line is securely attached to the washer.
    • 5 Plug the washer back into the wall (making sure it has gone at least 30 seconds without power).
Nov 11, 2014 | Washing Machines
Fisher & Paykel GW612 won't spin
you want to check the drain pump if there is nothing stuck there sometimes a drain restriction will cause the machine to stop
Jan 27, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
Will not drain and spin....stops ..will only start wash and stop.
check the lid switch if is clicking if not try to by pass the switch
Jun 18, 2009 | Washing Machines
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Hi, my switch keeps going around and around without stopping
Hi I fixed the problem by removing the filter at the bottom right hand corner of the washing machine and removing 2 x £1 coins that had got stuck there
regards
Michelle
Jan 24, 2009 | Indesit W 123 Front Load Washer
GE washer (WHDRR418GWW)(14 MO. OLD)HAS STOPPED AGITATING.WHERE TO LOOK? WHAT TO TRY?
My washer would fill/drain ok but would not agitate or spin. I unplugged the washer and listened for the motor to click. When the motor clicked I plugged the washer back in. Then I opened and closed the lid 10 times. I turned the washer to the drain/spin position and turned it on. The belt moved back and forth several times and then went into a fast spin.
Sep 26, 2008 | Washing Machines
Kenmore he2 front load washer
remove bottom panel open pump port and ck for foreign objects lean washer toward rear wall this will help help keep water toward rear and reduce flooding floor might try opening door first and dipping out as much water as possible with bottom panel removed reach up to lock area there is a tear shaped plastic peace pull it down to release door
Jun 02, 2008 | Washing Machines
Please help
it is the timer or, it may be a short of some kind
Apr 19, 2008 | GE WDSR2080D Top Load Washer
Kenmore model #110.22802100 drains but no spin
If it is draining, then the motor is ok.
If it is agitating properly, then the motor coupler is ok.
This leaves the gearcase, clutch, basketdrive(brake), basket drive block, or timer.
Raise the lid and hold the lid switch down. Start a rinse cycle and let it go through the cycle. It should drain the water, then stop the motor for a split second then kick the motor back in and start spinning. If it doesn't drop out that split second then the timer is holding it in neutral drain. You can recreate this by letting it start draining, then let off the lid switch, then depressing it again. The basket should start spinning. If not,
Raise the lid and hold the lid switch closed. Start it in spin and see if you can get it started spinning by hand. If so you probably have a slipping clutch.
Post back with any questions.
You can go to sears.com, click on parts, and enter your model number and see parts diagrams of the washer. This can be helpful.
Nov 25, 2007 | Zanussi F1045W Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
125 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
