Question about Whirlpool Calypso GVW9959K Top Load Washer
Ob error, out of balance?
4 year old calypso washer, with no problems up til now, will not complete a cycle, out of balance error thrown. It is level.
  • Anonymous Jun 06, 2008
    I have the same problem, my washer stops right before the final rinse with a ob signal even when empty. Help.
    Genius:
  • 1,028 Answers
May be bad basket drive ..main control detects out of balance by currect draw on motor had a basket drive cause same sympton .. after replaceing control bds and motor changed basket drive and solved problem
Posted on Jun 07, 2008
What does error code ob mean on a Whirlpool Calypso washer? The washer stops in mid cycle with the error code ob. I restart it and after a few minutes it shows the same error code again.
The OB indicates and out of balance condition has been detected by the motor control. You say this happens when the washer is empty also. One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
If the OB error was cleared and the OB occurs with an empty load then the motor control has failed.
The drain pump must work. The image below shows how to run a diagnostic test to check the drain pump. Follow the instructions in the image below and check the drain pump operation. If the pump runs and the water does not drain then the sump is clogged. If the pump hums but does not run then the pump needs to be replaced.
http://media.fotki.com/1_p,wkktswgwqtqrbwfxgtqsskgwtqkq,vi/gftrgbbtfxfffgqskfk/1/1303472/5961857/image48348img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question*@^%
May 29, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Machine is about 7 years old and gets stuck in one cycle, will not drain. Recieved code CA, LD and OB. Machine is stuck and won't drain!
Jan 11, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I have a calypso washer, it makes a grinding sound and the water will not drain out. it also keep boping up ob code, i have trye to balance it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$%@
Dec 27, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My calypso washer keeps giving teh OB error, but it's completely leved and I've even tried removing all the cloths from it and it still keeps doing it.
Sep 24, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso washer error codes
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$^@#%
Aug 31, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso washer machine
Off Balance. From the service manual (you can google error codes for these machines), if the motor controller detects an unrecoverable off-balance condition, the machine controller will shut down and display an "ob" for off balance. The lid switch must be opened at least once before restarting the cycle, if this condition occurs. Opening the lid will allow you to view and redistribute the load. Press STOP/CANCEL to clear the display.
Feb 27, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso GVW9959K washer with OB code
This is a common problem with the Calypso washers. The problem that you are having is related to the pump. There is something in the pump that is causing the error code to occur. Since the pump isn't working right all of the water isn't draining out thus causing it to be out of balance. If you can get down to the pump and check it out chances are you will find something in it. It might just be some fabric or string from clothing caught around the pump motor. Just make sure you clamp off the hoses or you will flood your laundry room. Once you clear out the pump unplug the washer and wait a few minutes before plugging it back in. Let me know if you have any other questions and let me know if this was helpful. Good luck and glad I could help.
Jan 22, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso Washer troubleshooting
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^#@#$%
Jan 21, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
"OB" Code error
Nov 15, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Calypso kemore elite washer
May 01, 2008 | Kenmore 15864/15862 Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
138 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
