Question about Amana RCS 10D 1000 Watts Microwave Oven
Possible fuse -- no power
At issue is an Amana Commercial microwave ..... Model RCS 10D.
Nothing works. No lights, no motion, no enthusiasm.
We think it might be the fuse but can't locate the fuse. A few forays into the search/rroubleshooting sites suggest it looks like a tall 2-inch white 'H'. The specs say 20 amp.
Are we on the right track?
  • revis70230 Dec 18, 2008
    have a panasonic microwave no power to any part
    Problem Solver:
  • 7 Answers
Replacing a fuse Locate your fuse. Most microwave fuses look like the one pictured to the left. They are usually an inch or two long. Each end is metallic and the center is either ceramic or glass.
To get to the fuse, remove the outer cabinet of the unit, which is usually held in place with a few screws. Once the outer cabinet is removed, follow the power cord into the unit. It will take you to the fuse holder, where the fuse sits. The fuse holder is located two or three inches into the unit, and may be attached to a power board.
Decide if your fuse is blown. A blown glass fuse will produce flash burn marks on nearby surfaces, or it will be completely black on the inside. The internal fuse wire (filament) will be melted and blackened. Ceramic fuses give no outward signs of having blown. To determine if a ceramic fuse is blown, test it with an ohmmeter. If the ohmmeter reads zero ohms, your fuse is fine. A reading of infinite ohms means your fuse is blown.
Replace the blown fuse. Pop it out of its holder and snap in a new one. You can squeeze the fuse clips together with your fingers in order to tighten their grip. Replace the unit's outer cabinet, plug it back in, and test to see if it is running properly. DO NOT run the microwave with nothing in it.
NOTE: Fuses do not usually blow on their own. A fuse may blow because of problems with the interlock switches or with high voltage circuitry. It is also possible, though rare, that a power surge will cause a fuse to blow.
Posted on Jul 04, 2008
  • 868 Answers
THE FUSE WILL BE IN-CASED IN A PLASTIC COVER THAT UNSNAPS TO OPEN IT.IT IS VERY EASY TO SPOT IT.
Posted on Jun 06, 2008
I have the same problem with the black&decker microwave. its seem like i cant find the fuse at all, its a 5kv 0.75A fuse. can any one help me to find out where to get it.
Posted on Sep 21, 2008
Amana microwave reset button?
Does the power panel have anything on it?? If not. it probably has a burnt fuse inside the unit, one year old should have a warranty on it Check out places that work on microwaves.
Mar 05, 2015 | Amana Commercial Microwave RMS10TS Touch...
Lights not working
follow this steps and fix it God bless you
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#6#ixzz2gPpzp9iL
Sep 30, 2013 | Amana Microwave Ovens
My amana model number amv1150vas is not working after a power outage
Unplug for 60 seconds to see if it will reset, if no! the fuse in the microwave has opened/ or if the model is the new type, it is the keypad control board or smart board.
Apr 05, 2012 | Amana Microwave Ovens
Microwave shut off completely
Microwaves have an inline fuse inside that fatigues over time.Take the cover off,follow the power cord after it enters the housing to locate the fuse.
Mar 14, 2012 | Amana MVH220W Microwave Oven
Our commercial amana microwave model number rcs 10 mpa 1000 watt is not heating/cooking food. The power, lights, fans , display and everything else works fine. I would like to fix this myself. What part...
can be many problems. a defetive magnetron. worn door switches and its bracket/levers. circuit board issues. oven cavity thermofuse. etc.. good luck.
Aug 03, 2011 | Amana RCS10MP Microwave Oven
My microwave started to make a loud "rotating"
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ';
Apr 16, 2011 | Amana RCS 10D 1000 Watts Microwave Oven
No heat
The service manual is here.
Jan 29, 2010 | Amana RFS12MPS Microwave Oven
Amana Microwave, MVH320E Popped
This is usually caused by a blown high voltage rectifier diode.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
line-height:normal">mso-fareast-font-family:"Times New Roman""> http://www.microtechfactoryservice.com/diode.html
line-height:normal">mso-fareast-font-family:"Times New Roman""> http://www.microtechfactoryservice.com/mag_test.html
line-height:normal">mso-fareast-font-family:"Times New Roman""> http://www.microtechfactoryservice.com/xformer.html
Normal
0
false
false
false
EN-US
X-NONE
X-NONE
DefSemiHidden="true" DefQFormat="false" DefPriority="99"
LatentStyleCount="267">
UnhideWhenUsed="false" QFormat="true" Name="Normal"/>
UnhideWhenUsed="false" QFormat="true" Name="heading 1"/>
UnhideWhenUsed="false" QFormat="true" Name="Title"/>
UnhideWhenUsed="false" QFormat="true" Name="Subtitle"/>
UnhideWhenUsed="false" QFormat="true" Name="Strong"/>
UnhideWhenUsed="false" QFormat="true" Name="Emphasis"/>
UnhideWhenUsed="false" Name="Table Grid"/>
UnhideWhenUsed="false" QFormat="true" Name="No Spacing"/>
UnhideWhenUsed="false" Name="Light Shading"/>
UnhideWhenUsed="false" Name="Light List"/>
UnhideWhenUsed="false" Name="Light Grid"/>
UnhideWhenUsed="false" Name="Medium Shading 1"/>
UnhideWhenUsed="false" Name="Medium Shading 2"/>
UnhideWhenUsed="false" Name="Medium List 1"/>
UnhideWhenUsed="false" Name="Medium List 2"/>
UnhideWhenUsed="false" Name="Medium Grid 1"/>
UnhideWhenUsed="false" Name="Medium Grid 2"/>
UnhideWhenUsed="false" Name="Medium Grid 3"/>
UnhideWhenUsed="false" Name="Dark List"/>
UnhideWhenUsed="false" Name="Colorful Shading"/>
UnhideWhenUsed="false" Name="Colorful List"/>
UnhideWhenUsed="false" Name="Colorful Grid"/>
UnhideWhenUsed="false" Name="Light Shading Accent 1"/>
UnhideWhenUsed="false" Name="Light List Accent 1"/>
UnhideWhenUsed="false" Name="Light Grid Accent 1"/>
UnhideWhenUsed="false" Name="Medium Shading 1 Accent 1"/>
UnhideWhenUsed="false" Name="Medium Shading 2 Accent 1"/>
UnhideWhenUsed="false" Name="Medium List 1 Accent 1"/>
UnhideWhenUsed="false" QFormat="true" Name="List Paragraph"/>
UnhideWhenUsed="false" QFormat="true" Name="Quote"/>
UnhideWhenUsed="false" QFormat="true" Name="Intense Quote"/>
UnhideWhenUsed="false" Name="Medium List 2 Accent 1"/>
UnhideWhenUsed="false" Name="Medium Grid 1 Accent 1"/>
UnhideWhenUsed="false" Name="Medium Grid 2 Accent 1"/>
UnhideWhenUsed="false" Name="Medium Grid 3 Accent 1"/>
UnhideWhenUsed="false" Name="Dark List Accent 1"/>
UnhideWhenUsed="false" Name="Colorful Shading Accent 1"/>
UnhideWhenUsed="false" Name="Colorful List Accent 1"/>
UnhideWhenUsed="false" Name="Colorful Grid Accent 1"/>
UnhideWhenUsed="false" Name="Light Shading Accent 2"/>
UnhideWhenUsed="false" Name="Light List Accent 2"/>
UnhideWhenUsed="false" Name="Light Grid Accent 2"/>
UnhideWhenUsed="false" Name="Medium Shading 1 Accent 2"/>
UnhideWhenUsed="false" Name="Medium Shading 2 Accent 2"/>
UnhideWhenUsed="false" Name="Medium List 1 Accent 2"/>
UnhideWhenUsed="false" Name="Medium List 2 Accent 2"/>
UnhideWhenUsed="false" Name="Medium Grid 1 Accent 2"/>
UnhideWhenUsed="false" Name="Medium Grid 2 Accent 2"/>
UnhideWhenUsed="false" Name="Medium Grid 3 Accent 2"/>
UnhideWhenUsed="false" Name="Dark List Accent 2"/>
UnhideWhenUsed="false" Name="Colorful Shading Accent 2"/>
UnhideWhenUsed="false" Name="Colorful List Accent 2"/>
UnhideWhenUsed="false" Name="Colorful Grid Accent 2"/>
UnhideWhenUsed="false" Name="Light Shading Accent 3"/>
UnhideWhenUsed="false" Name="Light List Accent 3"/>
UnhideWhenUsed="false" Name="Light Grid Accent 3"/>
UnhideWhenUsed="false" Name="Medium Shading 1 Accent 3"/>
UnhideWhenUsed="false" Name="Medium Shading 2 Accent 3"/>
UnhideWhenUsed="false" Name="Medium List 1 Accent 3"/>
UnhideWhenUsed="false" Name="Medium List 2 Accent 3"/>
UnhideWhenUsed="false" Name="Medium Grid 1 Accent 3"/>
UnhideWhenUsed="false" Name="Medium Grid 2 Accent 3"/>
UnhideWhenUsed="false" Name="Medium Grid 3 Accent 3"/>
UnhideWhenUsed="false" Name="Dark List Accent 3"/>
UnhideWhenUsed="false" Name="Colorful Shading Accent 3"/>
UnhideWhenUsed="false" Name="Colorful List Accent 3"/>
UnhideWhenUsed="false" Name="Colorful Grid Accent 3"/>
UnhideWhenUsed="false" Name="Light Shading Accent 4"/>
UnhideWhenUsed="false" Name="Light List Accent 4"/>
UnhideWhenUsed="false" Name="Light Grid Accent 4"/>
UnhideWhenUsed="false" Name="Medium Shading 1 Accent 4"/>
UnhideWhenUsed="false" Name="Medium Shading 2 Accent 4"/>
UnhideWhenUsed="false" Name="Medium List 1 Accent 4"/>
UnhideWhenUsed="false" Name="Medium List 2 Accent 4"/>
UnhideWhenUsed="false" Name="Medium Grid 1 Accent 4"/>
UnhideWhenUsed="false" Name="Medium Grid 2 Accent 4"/>
UnhideWhenUsed="false" Name="Medium Grid 3 Accent 4"/>
UnhideWhenUsed="false" Name="Dark List Accent 4"/>
UnhideWhenUsed="false" Name="Colorful Shading Accent 4"/>
UnhideWhenUsed="false" Name="Colorful List Accent 4"/>
UnhideWhenUsed="false" Name="Colorful Grid Accent 4"/>
UnhideWhenUsed="false" Name="Light Shading Accent 5"/>
UnhideWhenUsed="false" Name="Light List Accent 5"/>
UnhideWhenUsed="false" Name="Light Grid Accent 5"/>
UnhideWhenUsed="false" Name="Medium Shading 1 Accent 5"/>
UnhideWhenUsed="false" Name="Medium Shading 2 Accent 5"/>
UnhideWhenUsed="false" Name="Medium List 1 Accent 5"/>
UnhideWhenUsed="false" Name="Medium List 2 Accent 5"/>
UnhideWhenUsed="false" Name="Medium Grid 1 Accent 5"/>
UnhideWhenUsed="false" Name="Medium Grid 2 Accent 5"/>
UnhideWhenUsed="false" Name="Medium Grid 3 Accent 5"/>
UnhideWhenUsed="false" Name="Dark List Accent 5"/>
UnhideWhenUsed="false" Name="Colorful Shading Accent 5"/>
UnhideWhenUsed="false" Name="Colorful List Accent 5"/>
UnhideWhenUsed="false" Name="Colorful Grid Accent 5"/>
UnhideWhenUsed="false" Name="Light Shading Accent 6"/>
UnhideWhenUsed="false" Name="Light List Accent 6"/>
UnhideWhenUsed="false" Name="Light Grid Accent 6"/>
UnhideWhenUsed="false" Name="Medium Shading 1 Accent 6"/>
UnhideWhenUsed="false" Name="Medium Shading 2 Accent 6"/>
UnhideWhenUsed="false" Name="Medium List 1 Accent 6"/>
UnhideWhenUsed="false" Name="Medium List 2 Accent 6"/>
UnhideWhenUsed="false" Name="Medium Grid 1 Accent 6"/>
UnhideWhenUsed="false" Name="Medium Grid 2 Accent 6"/>
UnhideWhenUsed="false" Name="Medium Grid 3 Accent 6"/>
UnhideWhenUsed="false" Name="Dark List Accent 6"/>
UnhideWhenUsed="false" Name="Colorful Shading Accent 6"/>
UnhideWhenUsed="false" Name="Colorful List Accent 6"/>
UnhideWhenUsed="false" Name="Colorful Grid Accent 6"/>
UnhideWhenUsed="false" QFormat="true" Name="Subtle Emphasis"/>
UnhideWhenUsed="false" QFormat="true" Name="Intense Emphasis"/>
UnhideWhenUsed="false" QFormat="true" Name="Subtle Reference"/>
UnhideWhenUsed="false" QFormat="true" Name="Intense Reference"/>
UnhideWhenUsed="false" QFormat="true" Name="Book Title"/>
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-priority:99;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin-top:0in;
mso-para-margin-right:0in;
mso-para-margin-bottom:10.0pt;
mso-para-margin-left:0in;
line-height:115%;
mso-pagination:widow-orphan;
font-size:11.0pt;
font-family:"Calibri","sans-serif";
mso-ascii-font-family:Calibri;
mso-ascii-theme-font:minor-latin;
mso-hansi-font-family:Calibri;
mso-hansi-theme-font:minor-latin;
mso-bidi-font-family:"Times New Roman";
mso-bidi-theme-font:minor-bidi;}
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We\'re happy to help and we appreciate your thoughtful rating of our answer.
Jul 01, 2008 | Amana AMV1162 Microwave Oven
Repair an Amana microwave
My amana micro just went dead. No lights nothing ,almost like a fuse blew.Its an over the stove model . The outlet works fine.#mvh210w
Dec 21, 2007 | Amana AMC6158B 1000 Watts Convection /...
Amana RCS 10D 1000 Watts Microwave Oven Logo
1,485 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
