Question about Bosch 24 in. SHU43 Built-in Dishwasher
No pressure during wash cycle
Model SHU43C02UC/17 fills and drains fine but during the wash and rinse cycle the water just dribbles out of the spray arms. I checked the water flow to the machine and found it to be fine. I removed the filter in the basin and made certain it was clean. I also removed the arms and checked for clogs, none were found. Remove cover of the impeller in the basin and checked for clogs and found nothing. What next?
  • 1 more comment
  • jern1949 Jun 10, 2008
    Thanks for the suggestion. The motor seems to be running fine, and there are no error codes. There is just no water pressure during the wash phase.
  • tharsh980
    tharsh980 Jan 23, 2013
    my water jets plugged up, had to clean them manually, started working again
  • tharsh980
    I had to manually clean the jets in the washer arms
Check capacitor on motor. possibly not turning at correct speed
Posted on Jun 10, 2008
Not getting enough water during rinse cycle
In the rinse cycle it will use cold only to rinse with.
You need to see how fast the water is going into the machine on rinse
Things that can effect slow fill, low water pressure, Faulty cold valve
water hose & valve filters clogged, Kinked hose
Feb 21, 2012 | Fisher and Paykel IWL12 Top Load Washer
The washer only fills halfway up during rinse cycle only, even on high water setting. it fill completely during the wash cycle.
Has it always done this or just recently? Some washers have lower rinse fills then spray the water on the clothes as it goes through its cycle.
Sep 24, 2011 | Estate Washing Machines
I have a Miele W1918 washer which has worked perfectly for a decade. Now there is not enough water to fill the tub during the first 'rinse' phase of normal cycles or the 'separate rinse' cycle. The machine...
I have exactly the same problem. I am currently getting around the issue by letting the machine do the washing then at the end of that cycle do a manual rinse cycle.
Jun 04, 2010 | Miele Novotronic W1918A Front Load Washer
I have a GE washing machine the model number is WHDSR209DZWW. It will not agitate during the wash cycle. It will also not stop filling with water during this time. The water leaks out of the bottom. The...
You need to check to see if the pressure tube and switch are ok this is how the machine detects it;s water level. Eg the tube may have just popped off or there could be a hole in the Pressure tube. Any questions feel free to ask Cheers
May 15, 2009 | GE WDSR2080D Top Load Washer
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Quiet Partner 2
More likely: the solenoid which directs the water to either the drain or the spray arm is clogged/jammed. Located underneath near the drain line.
Jun 13, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Motor pump has gone out. pump needs replacing. the unit needs to be pulled out inorder to access the pump. the sides of the d/w must come off.
Jun 09, 2008 | Dishwashers
Water Pressure Woes
It's not a solution, but the water on our washer here 'trickles down', too...I guess that is normal...But if you have the same brand, you should know those three gray...things...with the black balls in them? They have holes, forming a wavelike pattern...I don't know if that's supposed to Spray, or Drain....Mehh....I stink at solutions...The water level...hmm...just like..a little bit touching the end? :)
Feb 16, 2007 | LG WM-2277HW Front Load Washer
No pressure to drive swing arm.
Check first that no debris is blocking the holes in the spray arm where the water comes out, and clean out the holes. In case it will not solve your problem, it's look like a pump problem (the pump has two functions : drive water to the spray arms and to drain water out the washer). Open the rear panel and listen if the pump works during the wash cycle. In case it doesn't work, it should be replaced. Good luck !
Jun 20, 2006 | Danby 22 in. DDW399 Free-standing...
Bosch 24 in. SHU43 Built-in Dishwasher Logo
283 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
