Question about Motion Computing M1400 Notebook
How to replace a glass protective layer for the view anywhere display ?
Glass protective layer is cracked. I'd like to find a replacement part of that very glass protective layer and illustrated instructions on how to release the bezel and replace the glass... (not the display).
  • Anonymous Dec 15, 2008
    how can i replace the glass on my laptop
  • phida1969 Mar 26, 2009
    my laptop screen crack vertically it started to spread on the right corner and i'm afraid one day it might just fall and because my laptop is a touch screen i cant even use it anymore its a hp window vista wireless mobility with a twist. please help.... tell me where to go locally i'm near brandsmart, office depot, phida1969@yahoo.com
  • 458 Answers
Broken glass on touch screen display for epson workforce 845
The touchscreen is sold as one part, you can't buy or replace just the glass. There is a capacitive layer glued to the glass that is probably damaged.
Feb 03, 2013 | Epson Office Equipment & Supplies
How do you repair a cracked screen?
I don't own one, but I'm guessing it has a glass-like layer over an LCD display. The first step would be to figure out if it is the glass that is cracked, which I'm assuming is the case, or if the LCD is what is broken. In either case you will need to find a replacement part. I've had good luck using http://froogle.google.com or eBay to find similar replacement parts. Just search for your devices model number plus screen. After you have the part you need it should be a simple disassemble, replace, reassemble procedure. Hope this helps.
May 10, 2011 | PANDIGITAL Digital Book 843967071153...
Vtech Mobigo screen cracked can it be repaired?
If this device is still working however the crack is small or not deep enough to affect the picture quality of the device, buy a cheap glass repair kit. This will not only fill the crack but ensure the glass stays protected and will look new. Also, after using the repair kit, be sure to use a anti-glare shied to further protect the screen.
If the screen is cracked to a point where the image is blurred, distorted or the colours are not accuratly displayed, unfortunately the glass will not be able to fix without speacialty parts specific to that device. If this is the case, I suggest you visit the site provided at the bottom and follow the steps indicated on the page.
Glass repair kit and demo:
http://www.youtube.com/watch?v=1FwIC7-bttk
http://www.amazon.com/Fix-Flat-Windshield-Do-Yourself/dp/B000EA5WLS
Replacement Parts:
http://www.vtechkids.com/support_replacement.cfm
Hope this helps. Good Luck!
Mar 13, 2011 | Vtech MobiGo Touch Learning System - Blue
My 2006 toyota matrix has a 2.5 foot horizontal crack about 4 inches above the bottom edge of the glass. The crack has turned down to the bottom edge to the glass on both ends about a 1.5 feet from the...
It should be replaced. The windshield actually will provide protection in a roll over crash, keeping the roof from caving in and crushing occupants. So you want it to be crack free for the strength to be there to protect you. The only repairs that can be made are much smaller than what you describe, and in hot and cold weather the glass will continue to expand and contract, and crack further.
Dec 21, 2009 | Toyota Matrix Cars & Trucks
Is a cracked windshield to dangerous to leave unrepaired ?
just leave it. A windshield is made of 2 pieces of glass with a plastic laminate layer in between the glass. The plastic laminate is what keeps you in the car in an accident. the crack is in the outside layer.
don't worry about it. It is not tempered glass and will not shatter like side and back glass.
Dec 21, 2009 | NRS Car Dash / Windshield Combo Mount...
I have an aqualand duplex and the protective glass is
HI
So is the glass cracked? or do you have an watch protector on it which is broken (usually a rubbery type protector which slips on over the glass)?
Kind Regards
Shenlun
Jul 12, 2009 | Citizen Aqualand Duplex JP104009E Wrist...
Cracked screen can it be fixed
No..the Glass Display Panel ... If cracked... Cannot be repaired.. it is not just a piece of glass, it is a layered panel with pixel grid panels along the top and sides that show color to the grid on the screen panel and go all throughout the display ..
If the Crack ocured behind the display panel on the plexiglass protective panel, that can be replaced... but No Not The Front LCD Display Panel.
Nov 19, 2008 | Acer Aspire 5100 Notebook
Black spots on the lcd display
I also have a brand new canon powershot sd750, with the SAME PROBLEM!! what IS THIS?!?
Apr 18, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Panasonic HDTV 1080i Screen
Usualy Panasonic have 3 layers on the screen. From inside to outside is: fresnel, lenticular and protective. If only the one from outside is broken don't wory. It;s just protective and the film it's just a filter to improve the black level. You can use it like that but be carrefull because the lenticular it's not protected anymore and if you scrach it ... And do not try to clean it with anything else just dry rag.
Dec 10, 2007 | Draper Replacement Surface ONLY for...
Cracked While Cleaning
I did that to a Toshiba laptop long ago, happens to the best of us. I think they?re referring to the LCD panel itself not a piece of glass you can replace. Usually the outer layer you can touch is a plastic/vinyl layer that covers the outer glass layer. Behind that is another sheet of glass and sandwiched in-between is the liquid crystal material. All of this is bound together as one unit and not repairable.
Dec 31, 2006 | LG L1915S 19" LCD Monitor
Motion Computing M1400 Notebook Logo
607 people viewed this question
Top Motion Computing Computers & Internet Experts
David Payne
David Payne
Are you a Motion Computing Computer and Internet Expert? Answer questions, earn points and help others
