Memory stick i cannot format memory stick or delete stuff off it..it say write protected
  • 101 Answers
Depending on what kind of mem stick u have, there should be a tiny switch on the side slide it
now it should work u can now format
connect stick to computer right click go to format dave
Posted on Jul 04, 2009
  • 165 Answers
Check mfr's web site, varies by model, try a different usb port.
Posted on Jun 06, 2008
My pen drive is not showing file system ( fat 32 etc..), what can i do? and how can I format the my Kingston 64 GB and 40 GB drives
Sometimes when a flash memory stick or USB external hard drive fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory USB hard drive device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the flash or external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs) also between XP/Vista and earlier versions of Windows.
Insert the flash or external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Health.
Dec 08, 2009 | Kingston Televison & Video
Formatting sd memory card ,usb memory
The easiest way is to format the drive and then convert to ntfs. Format again and convert to fat32, then format again. This will ensure that any data that may be left on the card is completely destroyed.
Sep 30, 2009 | Posiflex SD 100 (SD1008012) Magnetic Card...
Memory stick duo reads full but it is not really that full
There is a reserved amount of unused space that is required for files used to run it.
Think of it this way,A blank disk will show nothing.Add a one word document and write protect the disk,It will show the disk is full,Even though you know it only has one word written to it.
Please rate this a fixya
Jan 30, 2009 | Koutech Systems Koutech KW-2103MS Memory...
How can i delete movies recorded from compro dtv4 Large files I says it is too large to send to recyle bin when trying to delete folder says it is right protected
First try deleting file without sending to recycle bin.
To do this you must hold down the "shift" key on your
keyboard while clicking the "delete" item on the menu..
If that does not work, you may try to enlarge the recycle bin,
Look up how to do that on H E L P screens.
If you do not have enough room on that drive you might
redefine the recycle bi on a larger drive, and try again.
Removing the protection might be more difficult. Get help elsewhere..
Or try changing the properties of the file..
Possibly search the contents of the REGISTERY file for the title you
have for this file and remove references ..
Sep 28, 2008 | Televison & Video
Usb memoey stick
You can usually reformat it and make it work,I have done this to my son's many times.Just try formating it a few times
Sep 21, 2008 | Koutech Systems Koutech KW-2103MS Memory...
Usb Memory stick
If it isn't working on three different computers, it's probably corrupted.  If you can't see it on you drive listing under computer, then it's going to be tough to retrieve to documents.
Sep 10, 2008 | Koutech Systems Koutech KW-2103MS Memory...
My U3 smart stick is not recognised on any computer
power surges ? try another memory stick in the usb if you have one.
May 04, 2008 | Televison & Video
Usb doesnt work
take the stick out,
Windows_xp
goto the control panel >hardware>device manager
see if the device is listed, usually as a h/d
uninstall it [right mouse click device, menu=uninstal]
unplug the stick!
REBOOT
after reboot, replug stick, cpu should " see " it and should act normal
Apr 29, 2008 | Televison & Video
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
Electro Med Services...
