Question about Rival CZF530 Deep Fryer
Setting up the Deep Fryer
Does the oil reserve go on top of the control panel heaters, or does the iron rings of the control panel sit inside of the oil reserve? This is for the Professional Cool Touch Deep Fryer CZF530
The heaters go inside the oil reservoir.By the way these seem to have an overheating problem see this forum for discussion on that subject
Posted on Jun 24, 2008
How to remove heating element
In order to remove the heating element of a Cuisinart deep fryer you need to do the following:
1. Unplug the fryer.
2. Tip the fryer and put the oil into a container.
3. Put the fryer on its side, with the open top over the sink and a bowl in the sink beneath it. Leave it this way so most of the rest of the oil can drain.
4. Wipe the inside of the fryer with a paper towel.
5. Put several layers of newspaper on the counter and stand the electric deep fryer upside down on top of the paper. You will see that there are rubber feet under the base held in by screws.
6. Remove the feet and screws and you will be able to take off the base to expose the electrical workings inside.
7. Locate the heating element which has wires leading to it. Start by removing the wires leading to it and then loosen up and remove the heating element itself.
May 24, 2015 | Cuisinart Kitchen Appliances - Others
How much oil should i use
Your fryer should have a fill line in the pot that you would use as a guide and not fill beyond that line....It should be at the back wall of the inside pot of the fryer....It's going to be alot lower than you would think, as the oil will bubble up and rise when you drop a basket of frozen product in the hot oil, but you don't want it to come over the top, so use the line inside the pot as your guideline. Also, you can look at the container your oil comes in too. When American Range says a 45 lb fryer, what they mean is it will cook approx 45 lbs of product, that's not 45 lbs of oil.... but it does end up being close anyway. I'd buy 2-3 of the commercial containers of oil, like 20# or so, and use what you need, save the rest.... Susan REO
Dec 12, 2011 | American Range AF45LP Deep Fryer
Just got a deep fryer and never used one before. I assume I use vegtable oil... How much. Then I want to cook onion rings
Look on the inside of the oil pan itself, should be marks to indicate the proper amount. I have had 3 fryers so far, and they all took a gallon of oil. After you try the onion rings, throw some tators thru a mandalin, and make your own chips.
Mar 20, 2011 | Vacuums
Pump sounds like it is kicking on but will not pump oil back into fryer
Drain the oil, clean the vat completely of any food residue. Let it dry out completely. Refill with oil and turn heater on.
If your screen is plugged, (in the pump housing,) It will not pump oil.
Nov 16, 2010 | Pitco Frialator SG14 Deep Fryer
My fryer is leaking oil from the tube inside I have a Master Dean fryers
If you are leaking oil by one of the burner tubes you can replace the tank or get a new fryer. new tanks usually cost around 400 plus installation. Usually better to replace the fryer.
Tom
Jul 23, 2010 | Frymaster Dean SR42G Deep Fryer
I need to know the best wayto clean the inside of an IFS40 deep f
Mr. Muscle Commercial oven cleaner, a good brush, a stainless steel scrubbie. Boil out the pot in accordance with Mr. Muscle directions. If all else fails, find "SWELL" oven cleaner in Restaurant supply, use rubber gloves. Spray on, let sit, Use brush and Scrubbie to remove. RINSE WELL!
Apr 27, 2010 | Imperial IFS40 Deep Fryer
I have a mdl CZF725 rival deep fryer and the lid will not stay down.
The problem is that the heating element and front control panel is not sitting in correctly. Remove the heating element/front control panel. Grab the heating element and gently pull it away from the control panel. Use care as you can break the elements off of the control panel. Reinsert and attempt to close the lid. If it does not close, then repeat this process being careful to not over bend the elements. The lid uses two plastic extensions to latch to the control panel and if the control panel is extended away from the fryer front, the lid will not latch. Also the fryer will not work as there are sensors in the control panel to sense if it is close enough to the fryer.
Jul 18, 2009 | Rival Kitchen Appliances - Others
Presto fry baby
I just got one of these w/Instructions, Says fill oil to fill level line inside. Cooking oil or shortening. Never use more than (2) - 8 ounces cups of cooking oil or (1) pound of shortening. Hope this helps!
Dec 12, 2008 | Presto 05430 FryBaby Deep Fryer
Deep fryer wont heat up
I have the exact same deep fryer and it was doing the same thing if you take out all of the oil and clean it realy good it should work again
Jan 11, 2008 | Black & Decker DF250 Cool Touch Deep Fryer
Rival CZF530 Deep Fryer Logo
111 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Ric Shull
Ric Shull
Level 1 Expert
Craig Butler
Craig Butler
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
