Question about HP OfficeJet 6210 All-In-One InkJet Printer
HP 6210xi does not copy, scan or fax.
My HP 6210xi only prints from the computer.
It does not copy, the automatic document feeder doesn't feed. I have cleaned the rollers as instructed, it still does not feed.
My HP does not fax or scan. I have performed the fax test and it says all is working.
  • 1 more comment
  • bubbarosa1 Oct 25, 2008
    My Scanner is inop also. It will print from the computer just fine. But when ever you try to use the scanner it comes up with a message that the scanner has a problem. I have tried turning off and on, unplugging, and smashing with a 3lb sledge... not really.. haha... I guess it is going back to Best Buy on their extended warrenty
  • hoevel Jan 06, 2009
    I have the same problem but could´t find a solution jet.
  • Anonymous Mar 29, 2014
    when powered on copy,fax,scan lights flash
  • 26 Answers
Is your printer is copying from scanner
Posted on Jun 11, 2008
The scanner and printer works good except when tring to instant print from glass
Posted on Sep 30, 2011
What is adf
An automatic document feeder or ADF is a feature which takes several pages and feeds the paper one page at a time into a scanner or copier, allowing the user to scan, and thereby copy, print, or fax, multiple-page documents without having to manually replace each page.
Aug 15, 2017 | Office Equipment & Supplies
4215 all in one office yet. When making a copy
Sounds like you're having a problem with the automatic document feeder. The scanner is continuing to scan but the paper is not advancing as it should during the first part of the infeed. Check to see if something is inside retarding the path of the scanned document. Or it could be worn rollers in the ADF.
Jul 18, 2011 | HP Officejet 4215 All-in-One Color Photo...
Blank line down left side of outgoing fax or feeder copy
The most common cause of blank (void) lines on a scanned document is from whiteout on the glass where the page is scanned when using the document feeder.
If there is a clear mylar sheet on the bottom of the document feeder, the whiteout may be there instead.
If there was dirt or a dark smudge on the glass (or mylar), it would show up as a black line, but whiteout is white, and shows up as a void (blank) line.
Mar 11, 2010 | HP Officejet Pro L7680 All-In-One Printer
When faxing does paper face uup or down
You load the originals print side uo on the document feeder tray or print side down on the glass.
To send a single page fax you can either load the original on document feeder tray or on the glass; to send a multi-page fax you must use the document feeder tray.
The position of the paper is the same either you copy, fax or scan.
All this is clearly explained in the user's manual, that you should read and you can download from HP support pages for you printer:
Aug 09, 2009 | HP Officejet 6310 All-In-One InkJet...
Vertical line from document feeder
there is probably a dirt spot on the scanner glass where the document feeds in. try cleaning the thin glass under the document feed cover.
Apr 24, 2009 | HP Officejet J5780 All-In-One Printer
Muratec F-520
It could have something to do with the automatic document feeder. There could be something in there that is blocking the paper from feeding in there correctly. It could be the feed tires or the belt as well in the document feeder.
It should be looked at by a technician in your area in case there are some parts that need to be replaced.
Jun 26, 2008 | Muratec F360 Plain Paper Laser Fax
HP OfficeJet 6210 All-In-One InkJet Printer Logo
340 people viewed this question
Ben Johnson
