Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Wireless Router I am looking for a router which will support as many as 5 computers using it at once. We have cable internet and live in a two story building. What would you recommend
    Problem Solver:
  • 18 Answers
Belkin G plus or equivalent. With so many computers connected to it, possibly at the same time, you need the fastest transfer speed possible from the router to the computers. Additionally, if any of the comps are incompatible with high speed transfer, the router will automatically adjust.
N.B NEVER use WEP to secure, always use WPA-PSK 2 if possible
:0) x
Posted on Jun 05, 2008
Hi I have the Motorola SBV 5120 cable modem and it is currently connected to my PC with Cat 5 cable and my internet works fine. I want to make a wireless connection to my laptop which is 802.11 a/b/g/n...
The SBV5120 is simply a device that converts your cable internet signal to a RJ45 computer output that connects to your single PC
It also has two RJ11 phone jacks if you use the modem as your home phone as well. It has no wireless function,
For you to have a wireless connection, you will need to purchase a Wifi Router. These can easily be got at any local computer store or a big box retailer like Best Buy, Staples, Computer City etc,
Most come as a 4 or 8 port wifi router, your choice will be the number of wired connections. In your case it looks like one.
Once you have your router, connect the Modem RJ45 to the WAN input on the router and your PC to one of the LAN ports on the router. In its default state, it should connect you to the internet as normal.
The router will have setup instructions which you can use after you connect the modem and PC.
Nov 05, 2017 | Arris SURFboard SB5120 Modem
HOW TO USE INTERNET IN MORE THAN ONE PC FROM LINKSYS WIRELESS G B
You have two ways on how you can get other computer online through this router. First, you can wired them (using an Ethernet cable) to one of the Ethernet ports on the back of the router. They are the ones labeled 1, 2, 3, and 4.
Second is through wireless, but those computers that will connect through wireless must also have a wireless adapter to be able to pick up the signal that this router is broadcasting.
Feb 12, 2010 | Linksys Wireless-G WRT54G Router
Start up and Signal problems. need to download WGT624 set up
.chk files are normally those produced by the system after a hard drive repair or some such, and shows lost clusters on your drive.
Your Broadband modem feeds the router (your problem device), which in turn connects to the computer's Network Card, the one with the RJ45 connector. The smaller connector goes to your modem, for use with Dial-up signals, not broadband. Cable modem feeds router, router routs signals to various computers, via RJ45 cables. Your router is probably for 802.11g signals, used by the majority of networked computers. The 311 in your computer plugs in to the 624 router. They work together to get you on the Internet.
Nov 07, 2009 | NetGear WGT624 Wireless Router
Trying to install netgear 108 mbps wireless firewal router WGT624
you need to configure the router,
usually by connecting to it at the address 192.168.1.1
but you should download the manual to make sure.
once your connected, you need to set the cable modem setting (if any) or just set it to Automatic or DHCP for it to automatically connect to the cable modem, and then send out the signal on the wireless.
Aug 25, 2009 | NetGear WGT624 Wireless Router
2nd Computer in basement cannot access Internet
if your signal is low in there the best work around would be to lay a cat-5 cable up to the router, the wired connection would be faster and more reliable then a wireless, or buy another wireless router and put it closer to the basement than the first and wire the 2 routers togher with cat5 using the second router as a fancy switch.
Jul 02, 2009 | NetGear WGR614 Wireless Router
Cd won't load on computer
You may configure your router without using the cd.
Using an ethernet cable, connect the router and the laptop so that you can configure it for internet connection.
1. check physical connection. modem to internet port of router. laptop to numbered port of the router.
2. check lights.
3. on your laptop go to the command prompt. (type cmd on the run window)
4. type ipconfig/all on the black screen
5. look for ip address. IP address should be in this range 192.168.0.*
6. open your internet explorer browser then type http://192.168.0.1
7. type admin on the username then password or 1234 on the password box.
8. configure the router for dsl or cable connection. don't forget to save
9. check if you have internet connection. if not, power cycle the modem and router.
10. once you're online, go to wireless tab. set your ssid (any name you want). set your encryption (either wep or wpa) don't forget to save
11. unplug the ethernet cable from the laptop and the router.
12. if the wireless card of the laptop is configured, you may click the wireless connection icon at the system tray (near the clock). enter your ssid and encryption.
13. you should have internet connection.
Nov 02, 2008 | NetGear WGR614 Wireless Router
How to set up the wireless-G 2.4 ghz 54mbps LINKSYS
I have moved and lost my CD to my Cisco "Linksys" wireless-G model WRT54GS please tell me how I can download the disk from somewhere???
Joyce
Jul 11, 2008 | Linksys Wireless-G Broadband Router
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
51 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
