My gps rino 530 dont start navigate at the reel place where i am and it dont fullow the map stree, only the principal roads of the original basse map not the charged map The system date on my Rino 120 is stuck on "04-Sep-12", does not matter if I remove the batteries or not, I cannot find any place to set the system clock or date... because the date is set as 2012, it wont find sat's... anyone know how to set the system date and time? or reset the thing?
To do full reset of all user data , turn unit off then press at the same time the power button, the toggle stick straight in and the page button. page button is below talk button. it may take several tries then choose yes at the prompt.
Hello Rahooty,
There is no way to set the date and time becayse the system clock in your Garmin Rhino 120 should be updating based on the information it receives from the GPS satellites. The radio should auto locate itself within about five minutes of being turned on providing it has a clear view of the sky. Once it sucessfully auto locates the radio's clock and position should reset. There does not appear to be any other reset built into the device.
Try taking the batteries out for at least 5 minutes. Then, reinstall the batteries, turn the unit on, and give the unit 5-10 minutes to auto locate. If it doesn't, you may need to contact Garmin support for additional sevice.
Best Regards,
Ken
"Go Ahead. Use Us."
