Question about Linksys PAP2
Voip problems lots of time voip device needs to restart to call
  • 33 Answers
Hello, there are several reasons too this, but the most common ones is:
- You have maxed out your bandwith.
Solution: Limit download and upload from filesharing. (need 256kBs free both ways to perform a good qualtiy voip call). Turn of web radios, webcams, video streaming. Encrypt wireless network
- Your Voip service provider cant keep alive registrasion link between their server and your voip device.
Solution: assuming you have both a modem and router, try to connect voip device directly to modem, if problem is solved you should try to upgrade firmware in router or by a new one (pref: Linksys). If problem still occures you should try to contact your broadband provider and get them to do a 24hr scan for datapackage loss on your connection (if they find datapackage loss, then its their job to fix the problem). If none of this works conntact your voip service provider and get them to send you a new voip device.
This is not a final solution, but it shold be a good guide to start with. i can give you much more detailed support on this issue, but then i need more details to analyse the problem further.
greetings
Posted on Feb 07, 2009
Fax machine does not receive FAX
The problem is that the codecs used by VoIP IADs are designed to compress voice, not the analog signals sent and received by modems.
In a VoIP Internet world, voice is first converted into packets and then they are sent over the connections that make up our our vast Internet. They may take slightly different times to arrive at their destination. In doing so some packets may be discarded, but the end result is that the receiving VoIP device has enough packets to make a clear and understandable conversation.
We suggest these settings on a fax machine for faxing over VoIP; slowing the transmission rate down and allowing the machine to continue receiving the transmission even though a few bits of data were lost, then faxing over VoIP can become more consistent. Our suggestions in many cases can resolve issues that prevent faxing over a VoIP connection, but not in all cases. If after trying and making all the VoIP fax changes we suggest you still cannot fax over your connection then try a Internet Fax service.
Aug 10, 2011 | HP Office Equipment & Supplies
Hello, I have x-lite on my computer, i can make VOIP cal for a limited time only, then I loose the DSL connection, and the dlink modem require restart (internet status went off). any support please
Does this problem (internet status off) happen even when you are not using x-lite?
It's very unlikely that it's the software disturbing the connection. I suspect your VoIP calls are interrupted because the connection is dropping, and not the contrary.
May 09, 2011 | Westell Wirespeed LiteLine 6100...
Hi, I need to connect my comSwitch 5500 to the Cable/internet/VOIP. Command Communications ComSwitch 5500 is a Telephone Line Sharing system- (automatic phone/Fax Switch) sold under the following...
I'm not one hundred percent sure on this, but it does look like you need a separate phone line since VOIP revolves around using your internet as a gateway for making phone calls. And since majority of VOIP uses ethernet connections, or wireless, there is no phone line to use.
Feb 28, 2011 | Computers & Internet
Cant call out local or long distance.Phone number dialed want ring.WHY!!!
I assume you are talking about using a VOIP device such as vonage to make the calls? There are a fw things that will stop it from working. One is that the setup on the voip unit is wrong. It needs to know the gateway number which is just the ip number of the normal router connected to the cable or dsl modem. It can also be a port setting in your router. To see if this is the problem you can try connecting the voip device directly to the modem. Then try to make a call. If it works then you know it is a port or an ip setting. If it doesn't you could have a faulty voip device or it isn't being authorized by the company.
Oct 10, 2010 | Computers & Internet
Hi..i have a linksys voip 2pt adapter. My phone set keeps on going silent (i hear no tone). I tried going to the config menu but thewebpage never opens and it keeps on prompting me for user and pass (which...
If you are losing audio during a call, there is almost certainly a configuration issue. You are going to have to access the web GUI and correct the incorrect settings. If you plug an analog phone into one of the ports and dial ****, you will hear "configuration menu". Enter 73738#. It will tell you to enter 1 to confirm. Press 1. The unit will restart and you will be able to access the web utility using the default login/password. Do this only if you know what your settings need to be and you are capable of provisioning the device. This procedure will return the device to its factory default configuration. This will work assuming you have an unlocked voip adapter. If yours is locked by a service provider, there is a good chance you will not be able to default the adapter using this method.
May 28, 2010 | Linksys IP TELEPHONY - VOIP RTR W/ 2 PHONE...
We need PPTP, L2TP Solution for VoIP
You can establish small tunnel with low cost firewall from linksys and do the VoIP with ADSL, lease line etc. You can use Linksys SPA 9000 IP PBX and SPA9XX phones. I have done a project and still expanding - UAE - OMAN
Sep 24, 2009 | Computers & Internet
How would fax run on VOIP? what requirment it needs?
typically faxing doesn't work on VOIP. i tried many times and sometimes it would go through although it said it didn't. other times it didn't work at all. VOIP has a limited bandwidth and the fax needs to send more info over the line than VOIP makes room for.
to have the best luck, stop all downloads and other network traffic while attempting to fax, so that there are no other programs or devices using the internet. the fax will have its best chance of working that way, although it probably still won't
here are some very good tips as well:
http://chris.pirillo.com/how-to-fax-over-voip-on-the-internet/
Feb 18, 2009 | Lexmark X4270 All-In-One InkJet Printer
Nikkai VoIP funky internet phone - software problem?
I installed a U.S. Robotics VoIP phone on a Vista Laptop and had exactly the same problem.
The reason why it happens is because a VoIP phone contains a microphone and speaker. Windows Vista/XP senses the microphone and speaker as two seperate entities. It then sets them both as the default microphone and speaker. You won't notice this being done until you get the 'Index out of bounds (1)' error.
Simply go to the control panel, and look for the sound/speaker/audio device option, then the sound and audio devices, click on the audio tab and make sure the 'sound playback' and 'sound recording' default devices are that of the laptop/pc and not of the VoIP phone.
Hopefully that should solve the problem.
Dan
Sep 29, 2008 | Lands Phones
Bluetooth device ID
 Plantronics Tech Support Phone Number: 1-800-544-4660
Jan 17, 2008 | Plantronics 510 Voyager Headset - PLN-510...
Computers & Internet Logo
260 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
