Question about Technics SL-1200MK5 Turntable
Leveling Turntable I recently tried to level my turntables with a circular spirit level to get a better sound from them and it seems that the table that supports them is bowing a bit. I tried adjusting the feet on the turntables to level them but the feet come off before the turntables are level. Is it okay to use shims underneath the feet of the turntables to level them?
  • 515 Answers
Yes, shims are fine, but just remember, shims are prone to movement. Why don't you bring all the feet to their maximum setting, then adjust from there. Perhaps the table it is sitting on needs the shims?
- Davis
DIGITAL ANALOG THERAPY
Posted on Jul 02, 2008
How do I turn my turn table on. POWER button is on. What other button do I push. I have phono, mono/st, cd, tape, tuner??
Phono button is turntable selector. May be the turntable switches on when you move the arm to the edge of the record.
Dec 17, 2014 | RCA Spirit Of St. Louis Radio/Cassette/CD...
Califone 1875 turntable
Ask them what the part is they can't get and report it back here. Fixya experts like myself sometimes can track them down.
Feb 26, 2014 | Califone International Audio Players &...
Turn table in microwave wont turn
Repairs are expensive. New microwaves are cheap. But you don't have to spend a dime on either. If your microwave turntable stopped spinning, here's an easy way to try and fix it. And all you need is some warm, soapy water and your own two hands. You don't have to be an appliance expert to troubleshoot a seemingly broken microwave turntable. You might find that all your little Zappy needs is a checkup and a good, thorough cleaning. If you follow these steps and find that your microwave still isn't turning, it probably means the motor has spun it's last spin. Then it's time to retire old Zappy. Unplug the microwave. Safety first, kids. Remove the glass tray and the circular turntable guide. Wash them both in warm, soapy water to get rid of anything stuck. Pay special attention to the rollers on your turntable guide, making sure they're able to spin freely. Clean the internal cavity. Make sure to check your microwave's center cavity to make sure it's free of movement-hindering (and gross) leftover food. Check that the drive bushing is working. Make sure that the drive bushing, the plastic mechanism in the bottom of the microwave's interior that the glass tray turns on, isn't worn out or split in two. If it is, you'll need to have it replaced. Put it back together. Put the turntable guide back into the circular groove. Place the glass tray turntable over the turntable guide and onto the drive bushing. Adjust until the drive bushing should fits perfectly into the grooves of the glass tray. Test it out. Zap a mug of water for a short bit to see if you fixed the problem. Do not run the microwave without anything in it.
Aug 05, 2012 | Microwave Ovens
I recently bought a Pioneer VSX-52 receiver, and tried hooking my Stanton turntable up to it, no sound came through. There is no grounding point that I have found on the receiver, is the not grounding the...
so you have a pre-amp otherwise you aint trying to use otherbinputs
, but the ground cable goes with your sungle phono soursce to the PHONO-preamp and the output is a Line-level , which you should here
Jul 17, 2012 | Stanton STR8-100 Turntable
Hooked my turntable to my compaq desktop computer. Turntable plays, but I have no sound.
I would be very surprised if you have a phono input on your sound card.What you need is a phono preamp because the signal level coming from your t.table is too low for the line input,You can find it in any electronic supplier like radio shack. Have fun
Nov 16, 2009 | Sony PS-LX300USB Turntable
Ryobi Miter Saw turntable hard to move and grinds when moving.
Hi Bob take the table back off get you some white lub put it on the center body of the table and if all posable get you a plaste over size washer to put where the bolt gose this will work now dont forget to take a look at your knob on the front it is tight you going to get the same thing.... Good Luck
Aug 16, 2009 | Ryobi Circular Saw W/Dual Laser
One of my DJ turntables = only left side stereo sound
need to narrow it down, using 1 turn table ONLY with the mixer on channel 1 (the chanel that is working) to test reciever is working properly and sound working on both side of the speakers, this eliminate the first turn table. Next, disconnect the working turn table (1) and connect your second turn table to the same chanel and see if you getting the sound coming chanel 1 just as your first turn table did. If you getting sound coming out from turn table on ch1 than is not the turn table issue. It will be you mixer having problems. You cant solve the problems having everything connected. Testing one turn table at a time using working chanel on the mixer to see if both turn table working properly. If you use the same chanel testing both turn table and the second one does not work than it will be one of your turn table is faulty. Note: if you find and test both of your turn table is working properly than it will be your mixer. good luck and hope that help..
Aug 06, 2009 | Technics SL-1200MK2 Turntable
Thump or thud coming from speakers when turntable is tapped
Just wondering how close your speakers are to your tables.Could be the tables pick up the low from the speakers.
Feb 23, 2009 | Technics SL-1200MK5 Turntable
Sony ps-lx2 turntable clicks when spinning
It seems something may have come loose over time or history, but you will have to delve inside to see what it is. It sounds as though the fault should be obvious.
If you do not want to do this, a repair shop should have no problem. I assume that the deck is working ok otherwise.
Jan 01, 2009 | Audio Players & Recorders
Turntable Issues
Check to make sure that your voltage setting is set correctly. Look under the turntable platter. You'll see a voltage selector. Make sure it's properly set for your area (115V or 220V).
If this does not solve the problem, or you have a turntable that does not have the voltage setting feature, then you might have a faulty turntable drive issue or an issue with the power, which means something is wrong on the main board (located underneath the turntable platter).
- DJ PRO AUDIO
www.DJPROLAB.com
Mar 17, 2008 | Technics SL-1200MK2 Turntable
Technics SL-1200MK5 Turntable Logo
597 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
