Question about Hoover Washing Machines
My Hoover VHD8142 stops whilst draining then the timer saver light and the 1200 lights flash. The machine does not drain away all the water. I cannot find what these lights flashing means in the manual, nor on the web. Any ideas?
  • Anonymous Mar 25, 2014
    Door not locking power light just flashing
I've just had exactly the same problem with the same model. Unlikely as it may sound, it's the heating element. Mine has just been replaced and everything is now working perfectly.
Posted on Jul 22, 2009
Machine sticks and 'timer saver' flashes. When turned off and onto 'drain' the lights shown on the video flash.
Switch off machine for an hour, press down all the panel buttons to drain any residual voltage to the board. Now when the power is reconnected and the machine is switched on, press down Start/Stop/Pause buttons.
If the fault does not clear, then check for dirt in the inlet and outlet , check flow and drain without water accumulating within. If not the control board is a suspect
Jan 04, 2013 | Washing Machines
Timer saver and 1200 lights flashing and machine doesnt finish cycle -- clothes all wet
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jun 22, 2011 | Hoover Washing Machines
Hoover VHD842- About 10 mins into the wash, the washer stopped and the 'timer saver' light and 1200 spin speed lights start flashing at the same time, approximately flashes five times then goes blank, then...
I'm interested in how you manage to drain the water away- is it by the filter cover? If not may I suggest carrying out the following- if you have not done so already ;-0)
(If you have -sorry. This will not help)
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Feb 26, 2011 | Hoover Washing Machines
Hoover HED 6612/1-80 dishwasher all four lights flash and beep whilst the machine drains, after a couple of minutes the beeping stops but the four lights glow. Cannot reset to cancel. Also still makes...
Not sure if you have got a user manual for this dishwasher. You can download one from this site.
You have a flood situation inside the dishwasher. See page 12 of the manual. There may be no water at the bottom of the machine but there is some overfill occuring. Also see error codes on page 13. This can be either because the flood detection circuit is faulty and giving false trigger or there is water in the base of the dishwasher housing due to leaking door gasket or hoses.
Some things to try. Turn mains power off and back on and see if there is any difference.
If not, then turn power off and pull dishwasher out from the kitchen benchtop. Put a few towels on the floor and tilt the dishwasher side to side on the base and see if any water comes out. Wait 5-6 minutes and turn power back on. See if it makes any difference.
Dec 15, 2010 | Hoover Dishwashers
Hi i was wondering if you help.my hoover hd vision
my hover washer dryer 1200 spin will not spin water comes into the drum and will not spin
May 12, 2010 | Hoover H160E Front Load Washer
Hoover hpe 236. water not draining, stops mid cycle, lights flash
Have you checked the pump filter, and or that the pump is actually working. if it spins o/k with no water in, then I would suspect a draining problem.
If filter clean and pump o/k, then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Hope this is of some help to you.
Jan 16, 2010 | Hoover Washing Machines
Indesit washing machine not spinning - fault code timer and dor lock light flashing
my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
May 30, 2009 | Indesit W 123 Front Load Washer
Can't open the door timers saver & 1200 spin lights flash
There is a known problem with these washers whereby a small electrical current 'leak' from the heater element causes the machine to think it still has water in it.
Disconnect the wires on the heater (tape them up or otherwise make safe) then run a cycle to verify that part as the problem.
Jan 31, 2018 | Hoover H130E Front Load Washer
Washing Machines Logo
881 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
