Question about Bose in-ear headphones - Black with black/white cord
Bose in-ear headphone cord cut
I have a set of bose in-ear headphones and the cord is broken. The break is between the right in ear headphone and the place where the two wires become one. I stripped off wire from both sides and connected them. I get sound from the left phone (no break), but no sound from the right phone. Any ideas?
  • 2 more comments
  • becraft4 Feb 07, 2009
    I have bose around ear headphones and the covering of cord has been stripped away near the audio jack, exposing the wires, and I only receive sound out of one ear.
    What should I do?
  • Anonymous Feb 22, 2009
    I just bought the headphones and was trying out the different inserts when the sound started to fade. Then went out completely. I don't know what happened.
  • bose man Mar 17, 2009
    I purchased a new Bose in-ear headphones (black with black/white cord). The right ear piece wire detached from the in-ear earphone. How and/or where can I get this fixed?
  • Anonymous Mar 13, 2014
    what does the letters H. R. on the right ear piece of the headphone mean?
    Problem Solver:
  • 50 Answers
Most head phones there two wires. those are the two that you most likly put together. if there is any metel mesh covering the wires. that has to be connected also.
Posted on Jun 20, 2008
How to replace ear cushion on bose QC 3 headphone
The ear cushions are held on the earcup with six snap fasteners, three on each side. To remove the ear cushion, simply pull it away from the earcup carefully so that you do not break the plastic snap tabs.
It should not be necessary to pry the ear cushion off with a sharp object, but if you do, be careful. There is also a thin gasket seal between the earcup and the ear cushion, take care not to damage it.
If you need to replace the ear cushions with new ones, they are available from Bose for $35/pair.
QuietComfort 3 Acoustic Noise Cancelling Headphones Bose Product Support
They are also available aftermarket at for $16.99/pair
Replacement Earpad ear pad Cushions For Bose QuietComfort 3 QC3 Headphones...
or $5.69/pair.
Bluecell Pair of Replacement Earpad Ear Pad Cushion for Bose Quietcomfort...
Apr 02, 2013 | Bose QuietComfort 3 Acoustic Noise...
Bose quietcomfort15 headphones
Riley, it could be that the membrane on the cone of the speaker is damaged, if that were the case, then you will have to replace the headset with a new one; also check the wiring to the speaker there may be a bad connection to the speaker, if that is the problem, it can be solved by soldering the connection back to the the speaker. you can also squeeze the cord starting from the bottom and slide your fingers up the cord, listen through the headphones for any break inn signal, if that happens,cut the wire and re-splice the wire and tape the wiring with electrical tape. good luck.
Apr 30, 2012 | Bose QuietComfort 15 Headphones
The left side of my bose earphones is working perfectly but the right side just went completely dead is there any way to fix this?
in most cases this is a broken wire issue and it can not be fixed unless you know where the trouble is exactly ..The fix will be to locate the break ..and tide it back ..but if it is a fine wire piece you will not be able to do much ..
Oct 03, 2010 | Bose in-ear headphones - Black with...
The wiring in the inside of the headphones is messed up
the wire inside the cable has broken
are these headphones real? orginal bose?
if so i would contact bose because the wire shouldnt break (under normal use)
May 14, 2010 | Bose in-ear headphones - Black with...
It only works on on ear.
You may a poor mating of the jack and the plug. This could be an issue of size and shape or a bit of dirt or something making it not seat properly in the radio. A damaged wire would be also be a suspect; your hand would give a bit of conductivity around a break.
First, I'd check the audio device paperwork for the specs on the jack and make sure you have the right plug and try cleaning any dirt off/out of the jack. Since the Bose headphones do not have a swappable cord (at least the ones I have don't), if you suspect a broken cord, check if your unit is under warranty. If the headphones are out of warranty, you could consider opening up the unit and soldering in a new cord.
I hope this helps.
(the Bose headphones in my house came with a number of adapters. it was easy to pick up the wrong one at times once they got mixed up.)
Apr 14, 2010 | Bose On-Ear Headphones
Right headphone will not play music
sounds like a broken wire. have them exchanged.
Mar 22, 2010 | Bose in-ear headphones - Black with...
Bose on ear headphones
replace the jack,
cut the wire from the jack then replace it with new one.
remember that the
Tip - Left
Ring - Right
Sleeve - Ground
Jan 11, 2010 | Bose TriPort Consumer Headphones
Right Bose In-ear cord separated from headphone
i know that these are very exspencive headphones, they were 100 dollars, and they are great. unfortunitally, these cannot be fixed without getting new headphones, sorry!!!
Mar 17, 2009 | Bose in-ear headphones - Black with...
Can bose wires be splice?
My cat chewed my bose headphone wire in two. Can the wire be spliced back together?
Nov 09, 2008 | Bose in-ear headphones - Black with...
Bose headphone sound
try cutting your cord and reconnect it using electric tape...
Jun 19, 2008 | Bose on-ear TriPort Headphones
Bose  in-ear headphones - Black with black/white cord Logo
3,324 people viewed this question
Top Bose Audio Players & Recorders Experts
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
