Question about Vtech Lands Phones
VtechI6789, base set will not receive from any of the 4 handsets that have fully-charged batteries. Outside line call will cause the base to transmit the incoming call to the handsets. There is a 2.4 Ghz wireless router with an isolator connected on same line. Everything worked fine for 2 months. Un-hooking the deactivated router did not restore the phone system.
  • watermaps Jun 05, 2008
    Disconnecting everything from power and removing batteries, this DID reset everything back.
  • 19,396 Answers
Disconnect everything from power and remove batteries, this should reset everything back.
Posted on Jun 05, 2008
  • Ginko
    Ginko Jun 05, 2008
    Also ensure that you are synchronizing correctly the handsets when you try to connect them.
  • Ginko
    Ginko Jun 05, 2008
    I don't think the router can create any problem with the handset, it is probably a synchronization problem with the base, try resetting the whole system and see if it works.
3 of my 5 phones say "No Line"?
This sounds like a registration problem, the errant
handset(s) and the base have lost identification
with each other.
NOTE: the CS6429 works a maximum of 5
handsets, so you have a "fully populated system".
You will have to clear each handset ( I ) then clear
the base of all registrations ( II ) before re-registering
each handset ( III ).
( I ). First de-register each handset ---
0. Start by taking off the battery compartment cover.
1. press [menu]
2. scroll up/down to "Settings"
3. enter * 7 8 9 0 #
4. scroll down to "next page", press [select]
5. scroll down to "Register Clear?", press [select]
6. display asks "Confirm?" or "Register Clear??",
press [select]
7. display reads "Ok" and chirps, press [ off ]
8. UNPLUG THE HANDSET BATTERY
(this is why the cover was off)
9. Wait ~30 seconds, re-connect the battery &
replace the cover
10. display reads "Not Registered"
( II.) To clear the base of all handset registrations
1. press [Find Handset] on the base and hold
past ~4 sec when the "In Use" lamp lights, at
about 10 secs the "In Use" lamp will begin to
blink. 2. release the [Find Handset] button momentarily,
then briefly press it again. After a moment,
all handsets that were registered to the base
(if any) will display "Not Registered" and be
ready for fresh registration ===============================
( III.) To register each handset to the base:
1. press [Find Handset] on the base and hold for
~4 sec until the "In Use" lamp lights.
2. press # on the handset and set the handset into
the handset cradle on the base
3. within 30 seconds or so, the handset will either
chirp and display "Handset Registered", then
"Handset #x" or it will say "Registration Failed".
NOTE: the battery must be well charged prior to the
registration process, a weak battery may cause a
"Registration Failed". Charge the battery for a
few hours and try the registration ( III ) again.
Good luck !!
Apr 16, 2016 | Vtech Accessory Handset with Caller ID for...
Have a replacement handset, base is cs6729-2 handset is cs6729-3 how do i set up new handset to see base?
This sounds like a registration problem, the new
handset must be de-registered from its original
base and then registered to your base.
NOTE: the CS6729 handles a maximum of 5
handsets. If you have a handset displaying
"Handset #5" then you have a 'fully populated system'
even if you actually have only one or two handsets.
You will need to clear each handset ( I ) then clear
each handset ( III ) up to the maximum of five.
( I ). First, to de-register a handset ---
1. press [menu]
press [select]
replace the cover
( if needed, else skip ahead to ( III ). )
Good luck !!
Oct 29, 2015 | Vtech Lands Phones
Hand set says connecting even before it is reset with new base.
This sounds like a registration problem, each 'old'
base and then registered to the 'new' base.
NOTE: the CS6229 handles a maximum of 5
1. press [menu]
press [select]
replace the cover
Good luck !!
Jul 23, 2015 | Vtech Lands Phones
I have a vetch mod# CS6114 I checked the base unit and it gets power to charge phone but I can't get a dial tone. I even hooked up to another line and still won't work.
handset must be de-registered from wherever
it thinks it is and then registered to your base.
( I ). First, to de-register a cs6114 handset ---
1. press [menu]
4. scroll from "Test Base" to "Test Handset", press [select]
press [select]
replace the cover
( III.) To register the cs6114 handset to the base:
NOTE 2: Some cs6114 bases do not have the "In Use"
lamp indicator. To register the handset simply park it
displaying "Not Registered" in the base cradle and wait
for the registration to occur. Pressing # as above may
be required, maybe not.
Good luck !!
Feb 12, 2015 | Vtech DECT 6.0 Cordless Phone with Digital...
Vtech cs6649 will not register more than one handset
The errant handsets must be de-registered from their
original base and then registered to your base.
NOTE: the CS6649 handles a maximum of only five
In that case, you can clear each handset ( I ) then clear
1. press [menu]
press [select]
replace the cover
Good luck !!
Jan 09, 2015 | Vtech Lands Phones
Panasonic phone says check tel line
Check cable conections from phone box on wall to base unit, make sure that the conectors are fully inserted. If possible plug a different phone into box to make sure that line is working. Hope this helps
Jun 08, 2017 | Lands Phones
My phones are not working at says out of range.
When a cordless phone says "Out of Range" or "Searching for Signal", there are a number of possible issues (assuming you are close to the base). 1) The handset battery may be low and not taking a charge. If the battery is more than a year old (including time spent in storage), replace the batteries for both handsets.
2) The base may not have power or an incoming telephone line signal. Check that the power adapter is warm (power to the base). Use another phone cord (and a second phone (preferably corded) to check for a dial tone). If a second phone has no dial tone, see below for diagnosing a phone line.
3) The phone base has lost the registration information for the handsets. A way to reset the phone is to unplug the power cord (from both the wall outlet and the phone base) and the phone data line and unplug the batteries from all handsets. Wait several minutes then plug in the base power and data cords and then reconnect the phone batteries. You may want to re-register the handsets. This is done by putting the handset in the main charging base for 20 seconds when the handset is fully charged. (See your phone manual) The phone was made by Thomson Electronics for GE; the manual is available here: http://www.home-electronics.net/USER-GUIDES/25952_DOM_EN_CL_IB.pdf .
4) The phone base or handsets are not transmitting or receiving the signals properly. This means that the phone needs repair or replacement. If it is under warranty, contact the manufacturer. Otherwise decide if the phone is worth the repair costs.
If you have no dial tone at the jack where the base is connected, check another phone jack on that line. If you still have no dial tone, find where the phone service comes in. Then open the service box and if the service is fairly new, plug in the RJ-11 test phone and listen for a dial tone. If you can't plug in the phone cord or there is no dial tone, contact your service provider. They will test and fix any outside problem.
If the problem is inside, inspect the visible wires. If you have a DSL filter as part of the inside wiring, check/replace it. If only one jack has a problem, open the faceplate and fix any loose wires. There are two faceplate designs - screw terminals or keystone jacks. For the screw-type, the conductors must be stripped and secured under the screws. For the keystones, the conductors are not stripped but pressed into the terminals with a punch-down tool. This tool is available at many home improvement stores in the wiring aisle. See http://www.lanshack.com/wire_phone_jack.aspx for a diagram of the wiring.
If the problem is not in a visible part of your wiring, you may want a professional to find and fix the problem. Your telephone provider will be willing to do the work for a fee.
I hope this helps.
Jan 20, 2012 | GE 25952 Cordless Phone
It always losing the line during the cordless calls
* CHECK YOUR AC OUTLET WITH NO LOOSE CONNECTIONS.(remove multi adapters mostly caused problems)
* FULLY RECHARGE THE BATTERIES.
* CLEAN DE BATTERY CONTACTS IN & OUTSIDE THE HANDSET & THE BASE UNIT.
* IS THE BATTERIES DON'T GET CHARGED FULLY IN OVER NIGHT.PLEASE REPLACE THOSE.
* REPLACE WITH ONLY RECOMMENDED RECHARGEABLE BATT"S.
* PLACE THE BASE UNIT AT CENTRALIZED AREA FOR THE MAXIMUM HANDSET RADIATION.
* KEEP THE BASE UNIT AT SAME FLOOR.
Mar 30, 2009 | Panasonic KX-TG1100 Cordless Phone
CS60 ear peice with heavy static when in use
This may be caused by a few things.
1. Check the configuration dial on the left hand side of the base to see if another setting works better. The recommended setting for most phones is 1.
2. Make sure your speaking (transmit) level is not too high. First, try lowering the volume on the telephone. If you still hear distortion, adjust the volume of the headset. The master transmit controls are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting. You can fine tune this setting with the Plus (+) and minus (-) buttons on the back of the base that are above and below the picture of the microphone.
3. Double check the battery has a full charge.
The Amber Charge light on the base will flash while charging and will stay solid amber when fully charged.
3 hours = full charge
4. Make sure the headset has been paired to the base.
Jan 20, 2009 | Plantronics CS60 Professional Headset
Handset has message Out of Range even though it is fully charged on on the handset.
The handsets are reading out of range because they have lost connection with the base. This happens mostly during peak power demands or power outages, but can also happen when the phone is unplugged for any amount of time. This can also cause, at times, the answering machine to stop picking up calls. To remedy this issue, reset the phone system. Please follow the instructions below:
To reset the phone:
1. Disconnect the power adapter, phone line, and remove all batteries from the base and all handsets. Leave it disconnected for 30 seconds to reset the base.
2. Place the batteries in the handsets first and then plug in the power adapter and phone line. Do not place the batteries back in the base yet.
3. Put the handset in the charge cradle.
4. It may take up to 1 minute for the "Out of Range" to clear from the display.
5. Once the "Out of Range" is cleared from the handset place the back up batteries back into the base.
Sep 08, 2008 | Motorola Mobility SD4502 Cordless...
Lands Phones Logo
153 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
