Question about Sony KV-27V42 27" TV
UHF Tuner The TV had a bad H-Output transistor. After replacing it the TV functioned great receiving all channels perfectly, except the UHF channels are all off by 51 channels. Channel 20 comes in on channel 71, 24 on 75, 31 on 82, etc. I can't find anything causing the problem. No bad solder joints that I can find. Any Ideas?
  • Sony Master
  • 520 Answers
Check to see if the TV/CABLE setting is on CABLE.
Posted on Jun 05, 2008
What features does a apex tv gt3215 have?
GENERAL
  • TV typeCRT TV
  • Screen size
    32 in
  • Power Consumption Operational
    150 Watt
  • Timer Functions
    Sleep, wake
  • Video Interface
    Composite, S-Video
  • Manufacturer
    Apex Digital, Inc.
FEATURES
  • TV features
    auto volume adjustment
VIDEO
  • Technology
    CRT
  • Aspect ratio
    4:3
TV TUNER
  • TV tuner presence
    Yes
  • Analog TV tuner
    NTSC
  • Reception System
    NTSC-M
  • Secondary Audio Programme (SAP)
    Yes
  • Secondary Audio Program (SAP)
    Yes
  • Channel Coverage
    VHF:2-13, UHF:14-69, Cable:1-125
  • Stereo Reception System
    MTS
AUDIO
  • Speaker(s)
    2 x main channel speaker - built-in - 5 Watt
  • Output Power / Total
    10 Watt
  • Audio Controls
    sound mode
CONNECTIVITY
  • Video interface
    composite
REMOTE CONTROL
  • Type
    universal remote control
  • Supported Devices
    DVD player
CONVENIENCE
  • Closed Caption Capability
    Yes
  • Parental Channel Lock
    Yes
  • V-Chip Control
    Yes
  • Menu language
    Spanish
MANUFACTURER WARRANTY
  • Service & support
    1 year warranty
POWER
  • Nominal Voltage
    AC 120 V
  • Power consumption operational
    150 Watt
DIMENSIONS & WEIGHT
  • Weight
    156.5 lbs
DIMENSIONS & WEIGHT (SHIPPING)
  • Width
    38.7 in
  • Depth
    29.2 in
  • Height
    30.5 in
  • Width (Shipping)
    38.7 in
GENERAL
  • Manufacturer
    Apex Digital, Inc.
Mar 08, 2014 | Televison & Video
I have a mga tv 1988' model cs1946R. I only get 11 channels from comcast my cable provider, my other tv (newer) get all channels. How do I programe my old mga to get more channels( I know i won't get as...
Your old tv does not have more than 11 slots to store channel .
Thats why you are not able to get more than 11 channels .
But let me confirm it .
SAM ANDERSON
Sep 18, 2008 | Televison & Video
Tv stays on one channel,no color or picture just ghost or outline, i have a Sharp lc46sb 54u
Check the settings to see if it is locked on channel 3 for external tuner source to have an input from a cable box ant in that needs 3 to function or from some other externally decoded signal like a vcr. Does the TV have a Digital tuner or the old analog tuner? If it's digital you can hook up a rabbit ear antenna with the UHF output on it & should be able to tune in some stations. If it's the old style then you will need a converter box to get it to receive any stations.
Fist check the settings to see if it has it set to lock on channel 3 for external tuner source.
Apr 03, 2013 | Sharp Aquos Televison & Video
Sound ok but no picture
see the b. diagram and test the power supply ;transistor, fuse, filter, switch, c.breaker rectifier,IC regulator voltage.
measure the horizontal output =125vdc
all other circuit:12vdc
color:12vdc
Oct 17, 2012 | JVC Televison & Video
I just need to know how to link up my Allegro DVD/VCR REMOTE CONTROL to my Phllips Magnavox Television.
TUNING This DVD+VCR is equipped with a frequency synthe- sized tuner capable of receiving up to 181 channels. These include VHF channels 2-13, UHF channels 14-69 and CATV channels 1-125. Auto Channel Programming 1. Choose the SOURCE SELECT option, then use b / B to select TUNER. Use b / B to switch among TUNER, LINE1, and LINE2. 2. Choose the AUTO CHANNEL SET option, then use b / B to find channels. • The tuner will automatically cycle through all available channels (TV/CATV) in the area and place them in the tuner's memory. •After the AUTO CHANNEL SET is complete, the TUNING menu will hide and return to the TV screen automatically. 3. Make sure the TUNING BAND is set appropriately (TV or CATV). • TV : If you are using a standard antenna to receive channels. •CATV : If you are using basic cable to receive channels.
Oct 15, 2010 | Allegro DVD/VCR ABV511
Bad/No reception problem on older tube tv worked good yesterday
have your tuner check for any cold solder on pins.
Jul 29, 2009 | Televison & Video
My Onkyo TX-SR500 receiver stays in standy/on mode.
It may be your amplifier protection circuitry is being activated and shutting down automatically. This is usually caused by a faulty output transistor in one or more of the channels. I recently repaired my Onkyo TX-SR500 which had this problem.
Using a multimeter on ohms check between C and E on each of the ten output transistors. I found Q6051 and Q6061 to be short cct on all pins. Once you have located the faulty channels check the adjacent components for open or short cct.
I replaced the following components,
Q6051 (2SD1047)
Q6061 (2SB817)
R6091 (2.2ohm fusible)
R6081 (2.2ohm fusible)
R6101 2x 0.22ohm 2W
Q6031 (2SD2061)
The amplifier now works perfectly, cost of the parts is about $15-$20.
If you don't feel confident doing this yourself just find a friend or tech who can do it for you.
Jan 11, 2009 | Onkyo TX-SR500 Receiver
No channels above 47
That works great except I can get the tuner to program any channels above channel47. Is this a limitation of this older model TV yes there is limitation in old tv. is there some setting I can change in order to get more channels using the tv tuner? in INDIA what we do is put a remote control ckt which gives us about 250 channels. of course we replace tuner also called hyper tuner along with remote ckt or replace whole kit which are cheaply available.& serves the purpose. hope this will help
Oct 03, 2007 | Televison & Video
Can not pick up uhf frequencies and only 3 channels from vhf
Replace tuner, get number and order from MCM, or Bluestar-online, Tritronics.
Aug 22, 2007 | Zenith SY2031S TV
TV doesn't receive higher channels
Depending on the chassis, it could be the OBT has a bad componet or a parts bad in it or if theres a standup tuner it has to be replaced. You should take the set into a repair place for an estimate good Luck
Jul 28, 2006 | GE 25GT511 25" TV
Sony KV-27V42 27" TV Logo
56 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
