Question about Sharp EL-2192Rll Calculator
NEED TO SET TAX RATE
Can someone tell me how to set the tax rate on a Sharp EL-2192RII and a Sharp EL-2192P. It would be really nice to be abel to use these calculators to their full capacity. Thanks
Solution #1 has it backward..
(tax rate), STR, TAX+ (or TAX-)
Example- San Francisco sales tax = 9.5% you enter 9.5, STR, TAX+.
now it functions as (amount entered) plus tax. Example- find the total with tax for a purchase of $14.99 14.99, TAX+ Calculator will show 16.41
Posted on Apr 16, 2010
You press 5, press Tax +, and then press STR - and the same for Tax -
Posted on May 07, 2009
How do i change the tax increase rate on my sharp EL-1197pIII
Move 'GT' '.' 'RATE SET' selector to 'RATE SET'
Tax / discount rate: • Press the TOTAL key twice, enter the tax rate, followed by the TAX+ key. •
Press the TOTAL key twice, enter the discount rate, followed by then TAX- key • A maximum of 4 digits can be stored (decimal point is not counted as a digit). Note: • Be sure to set above noted selector to the "•" position after storing an each rate. • For the conversion rate and the tax / discount rate, a single value can be stored for each. If you enter a new rate, the previous rate will be clear
May 27, 2016 | Sharp El1197P111 Printing Calculator
HOW DO SET TAX RATE ON SHARP ELSI MATE EL-2125
Easy. Press M- key [has RATE SET] above it. This will shown your current setting say 17.5. Amend to 20.0 and Press M- key again. Rate should now be set at 20%.
Test by entering:
100 and pressing +TAX key - Answer should be 20.
100 and pressing -TAX Key - Answer should be 83.33
Jan 04, 2011 | Sharp EL-330AB Calculator
How do you set the tax rate
Example: setting 5% tax rate
1. move mode switch to 'rate set '
2. press 5 (for tax rate ) followed by TAX+ button
3. Move mode switch to GT
to add tax to e.g 200 type:
200 TAX+, the result is 210
Feb 16, 2009 | Sharp EL-1197PII Calculator
Setting tax %
I Finally figured it out after playing with it for almost 1/2 an hour!
Hit 2nd then Tax + (rate set) it will appear as 0.000 enter your tax rate... mine is 5% so I enter 5.0 then hit 2nd and Tax + (rate set again) And it will work!
It is glorious!!!
Answered By James Soltys from: Edmonton, Alberta Canada
Dec 18, 2008 | Sharp EL-1701C Calculator
TAX SET
Press +TAX
press the number you need to set it at
Press +TAX again then CA
worked for me!!
Hope this helps
Oct 21, 2008 | Sharp EL-1801P Calculator
Set Tax Rate
First clear all w/ ON/AC.
Enter the tax rate desired eg. 7 for 7% (can you tell I'm in PA)
Press RATE then TAX+
Press C/CE.
The next time you use TAX+ it will calculate and add the value that you set.
Do the same for TAX-, you can use a different value for each as they are separate memories.
May 30, 2008 | Office Equipment & Supplies
SETTING TAX RATE
On your Sharp press
CA
C.CE
C.CE
RATE SET(+TAX Key)
175(No decimals for they are not taken into consideration)
RATE SET(+TAX Key)
To check if all went well press
CA
C.CE
C.CE
RATE RECALL(-TAX Key)
It should read your tax rate.
May 01, 2008 | Sharp EL-330AB Calculator
Set tax
To set your tax rate:
1. Be sure to switch to "rate set" from GT
2. Enter the tax amount like so - if your tax rate is 7% type in 7%
3. Go back to the GT setting and it should work...at least that is how I fixed mine! I did the same thing last week & have no manual!
Hope this helps you
Mar 03, 2008 | Sharp EL-2196BL Calculator
Set tax rate for Sharp EL-1701C
It is glorious!!!
Jan 20, 2008 | Sharp EL-1701C Calculator
Need to change tax function on Sharp EL-334A
I had the same problem and finally figured it out. Here's what you do:
Press C-CE twice
Press +TAX (Rate set)
Key in your new tax rate as an integer (e.g. 5)
Press +Tax (Rate set) again
Press C-CE
Then you're ready to calculate with the new rate!
Now what's the GT button for?
Nov 19, 2007 | Sharp EL-334AB Calculator
Sharp EL-2192Rll Calculator Logo
1,963 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
