Question about Uniden 5.8GHz Expandable Cordless Phone System with Digital Answering System
I can here them but they can't hear me
Hello: I bought the uniden5.8 wireless and 2 of the handset have a problem. if I call someone from the uniden phone the person recieving the call cannot hear me but I can hear them. Volume is high and battery is charged. Do I need to buy 2 new handsets?
  • 1 more comment
  • Anonymous Jun 13, 2008
    same problem as above , only on the base hand set , this is the second unit with the same problem , we have had Telstra check things out and tried many other things , dissconected all other items ----- its as thought the handset is muted --even though it is not. will listen to any sensible solution ps the unit is two weeks old
    I was the Guest now logged in as haarky
  • Loretta_m95 Mar 16, 2009
    When i call someone i can hear them but they cant hear me? Its like it is muted but this phone doesnt seem to have a Mute Button on it ?
I have the TRU9585 with 4 hansets. We used them for about 3 months, worked great. One day, I can hear caller, caller can't hear me. Problem was a defective transistor in base unit. Part number C2120, small 3 legged device near bottom of unit. Replaced it with generic NPN transistor from Radio Shack. Caution...should only attempt repair if you have worked on electronics before and can solder...Also C2120 configuration is not standard, configured emitter-collector-base instead of emitter-base-collector...Good luck!!!
Posted on Oct 19, 2008
How do i add another handset "uniden 6.0" phone to an existing phone and base unit of the same brand.I need the step-by-step instructions please. thank you!
First make to get a compatible handset.
For the Uniden D1660-2, the compatible handsets are DCX160 and DWX337. Make sure that you have not exceeded the number of handsets that the phone can support. The D1660-2 can support 12 handsets unless you use any DWX337 handsets. Then the limit is 6. (If you have more handsets, you will need to deregister some of them first.) Then allow the handset to charge. If the handset is reading "not registered", then place it into the base unit. You should see "Handset Registering" for about 30 seconds; then it will read Registration Complete. The manual for the Uniden D1660-2 is available here: http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1660-2om.pdf . This is the most common Registration for Uniden phones; there are a few exceptions (depending on the base or the replacement handset). Check the appropriate manual (see below to find the manuals).
For the DECT4096, press Menu on the base and then navigate to Handset Register. When you see Handset Registering on the base display, press and hold # on the handset to be registered until you see Handset Registering. (It takes about 2 seconds.) After the display changes to Handset Registered, check for dial tone.
On a few Uniden phones, there is a Page/Handst Register button on the base. On those you navigate through the Handset menu to Handset Register (Menu > Handset menu > Handset Registration). Then press and hold the Page button until you hear a beep. Then wait for the registration to be completed.
Most Uniden manuals are available here: http://www.uniden.com/scat/cordlessphones_mnl . Select your type of Uniden phone and scroll through the list to your model or use the search box to directly search for your phone and the manual.
I hope this helps.
Jul 26, 2011 | Uniden D16602 Twin Cordless Phone
One handset is faulty
Bought a new handset.
Oct 20, 2009 | Uniden Cordless Phone
I have a Uniden DECT 6.0 phone set. I damaged one
On the base, open the menu and select Register Handset. The display should say Handset Registering.
On the handset you want to register, press and hold # until the handset display says Handset Registering (about 2 seconds).
1.
2.
DSL filterTelephone cordTelephone wall jack
45
In about 30 seconds, the handset display should say Registration Complete. Press Talk/fl ash and make sure you get a dial tone.
If...
Try...
you don't hear a dial tone
the display says Registration Failed --
Making sure the handset is fully charged, then start over at step 1.
Sep 07, 2009 | Uniden DECT 6.0 Cordless Telephone...
I have a Uniden 5.8 GHZ phone with 3 handsets. When I call someone on one of them, they can hear me but i cannot hear them.
SOUNDS TO BE A PROBLEM WITH THE EARPIECE ON THE HANDSET WHICH MEANS THE HANDSET NEEDS TO BE REPLACED.
Aug 15, 2009 | Uniden TCX905 5.8 GHz 1-Line Cordless...
Clicking on handsets, loss of signal strength.
We decided to remove each handset, one at a time, from the system to see if we could determine if any of them were defective and maybe the cause of our problems. We took handset #1 and removed its battery. We continued to have the clicking and other noise. We put the battery back in handset #1 and removed the battery of handset #2. Immediately we noticed we did not experience the noise and clicking problems. We have concluded that handset #2 is defective. To verify we will keep handset #2 out of service for a week. At the end of a week we will reinstall the battery and if we have noise and clicking we have verified handset #2 is defective, the cause of our noise and clicking and needs to be replaced. Just to be on the safe side we will continue testing each additional handset to verify if any others are defective.
Apr 14, 2009 | Uniden TRU9460 Phone
Calling party cannot here receiving party
This can be one of a couple of things. First of all, if this is a multi-handset phone, go off hook on two handsets at the same time and see if you can hear yourself in both phones (Speak into one while listening to the other) If it is only a single handset phone, do the same thing only with another phone. If you cannot hear anything coming from the uniden phone, it may have a bad mic in the handset and would need to be replaced. (the handset not the mic) If you bought it less then a year ago and still have the receipt, call uniden at 18002971023 and they will help you get it replaced.
Mar 22, 2009 | Uniden Cordless Phone
My voice is not heard on my Phone
Any kind of intermittent transmission problem, or solid transmission problems you mention are directly related to your phone. I'm not sure what kind of phone you have. If this is a typical home phone, it would either be the handset or the handset cord. If this is wireless, its the entire handset.
Oct 06, 2008 | Uniden DCT646-2 Cordless Phone
Having problems with phones
Na. Just remove the battery from all the phone and put them back in. Then do a factory reset on each handset...
Sep 03, 2008 | Uniden 2.4 GHz Cordless Phone System
Uniden phone
If this is a standard home phone, try another handset or handset cord. It it's wireless, it's the handset.
May 07, 2008 | Uniden DCT646-2 Cordless Phone
Uniden handset TCX905 with base unit TRU8866-if compatible?
I just successfully registered 4 TCX905s with my TRU8865 base - it's documented in the TCX905 manual.
Be sure the handset you want to register is fully charged.
Remove the handset you want to register from its charger.
Now unplug the AC for the main base, hold down the 'find handset' key on the base and plug the AC in again, when it beeps, you can let go of that button.
Hold down the '#' on the handset you want to register, it will show 'Registering Handset...' and when it beeps, it's done - registered, you're good to go :)
Oct 11, 2007 | Uniden TCX905 Cordless Expansion Handset
Uniden 5.8GHz Expandable Cordless Phone System with Digital Answering System Logo
368 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
