Question about Refrigerators
1999 Amana Refrigerator ( TN21V2W ) - running too warm
The refrigerator is still functioning, but even adjusting the temperature control does not make it cooler ... we have clean the coils underneath, but it has not appeared to help . There are not odd sounds and I head the compressor run, but basically it appears to run pretty hard and cool thr fridge and freezer down, then it waits too long to come back on again and things in the freezer start to defrost before it starts again.
Compressor on bottom back is hot and I noticed the vinyl flooring below appears burnt a little, that may have been like that for a long time though.
Temperature playing up going up not down
Refrigerator Not Cooling Enough - GE Appliances
If the refrigerator is running, but not cooling at all or is not cold enough, several ... To view a short video on adjusting the temperature on set point models: Play ...
How To Fix A Refrigerator and Freezer That's Too Warm ...
If your fridge and freezer is too warm, don't give up - we can help. ... The cold control is a temperature controlled switch that supplies power to the compressor ...
Nov 21, 2015 | Refrigerators
Where is the defrost timer / does my fridge even have one?
Most often the defrost thermostat fails there should be a diagram or small manual hidden under the kick panel or taped on the back of the refrigerator. I believe this model uses a computer to control all functions including defrost . There should be a way to run diagnostics on this to tell you your problem if you can find the hidden manual.
Aug 06, 2014 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
Amana tn21v2w
21 cubic feet
W=32 5/8
D=33 1/8
H=67 3/8
Sep 20, 2013 | Refrigerators
Refrigerator is too cold even when adjust the temperature
Too much freon? Or maybe you got the controls mixed up. My refrigerator used to freeze a gallon of milk over-night.
Nov 18, 2012 | GE Adora DSS25KSTSS Stainless Steel Side...
Fridge is warm
Adjust the cooling knob inside the fridge according to the outside temperature.
Oct 27, 2012 | Amana ABB1927DE Bottom Freezer...
Our Amana AF12538 AE Refrigerator is causing the vegetables in the vegetable bin to freeze. What could cause this? the Units is only 2 years old.
Refrigerator temperature control set too cold or faulty Fresh Food thermistor.
Adjust refrigerator temperature control or check thermistor.
1 Refrigerator section too cold
2 Refrigerator airflow not properly adjusted
3 Check air flow.
Just too much information for this page. If you would like the long version please let me know. I am a Technician and have the tools and the answers if you would like my assistance. I will go out of my way to help you and would rather tell you this first so please do not rate unless I assist you Thanks, Sea Breeze
Dec 30, 2010 | Amana AFI2538AE
The refrigerator is still functioning, but even adjusting the temperature control does not make it cooler ... we have clean the coils underneath, but it has not appeared to help . There are not odd sounds...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Aug 24, 2010 | Refrigerators
How do I adjust the cold control on my Amana refrigerator?
get a thermometer and adjust the control to the desired temperature
Nov 01, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana Bottom Freezer control knob
go here and scroll to the bottom of the page and click on "sitemap"
and you will find help information.
Mar 17, 2008 | Amana ARB8057CSL Bottom Freezer...
Refrigerators Logo
332 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
