Question about Dell OptiPlex GX260 PC Desktop
Keyboard not working
Whenever i press "L" on the keyboard its shuts down the computer
    Producer:
    Uploaded 30 video answers.
  • 95 Answers
Hi abcd_21 ,
You have a dell machine, therefore ...
Run a diagnostics
turn off your system
press and hold Fn key ,power on the system, leave fn key
it will start running a diagnostic
it will give you an option to press any key to continue
press any key and you will get 4 options
express test
custom test
extended test and
symptom tree
choose symptom tree
you will get list of devicec
choose keyboard run test
it will highlight some keys you have to press
if everything works fine here
hardware is working fine
then you have to take the system back to day one or use Operating system cd to reinstall the operating system.
GoodLuck :-)
Posted on Jun 05, 2008
Okay one day my compaq Presario F700 kept showing a message saying it needed to be restarted because something wasnt starting up when the computer turned on. So I restarted it and when it came back on the...
you disabled keyboard in fn mode press fn blue key and hold down and locate the little blue key on keyboard and press it release at same time if that dont work restore to earlier point using on screen keyboard and problem should be fixed
Mar 01, 2013 | Computers & Internet
Hp wireless keyboard not working
exact key board driver install then try
what keyboard model?
download load driver for keyboard
update keyboard driver
May 16, 2012 | HP Computers & Internet
Water damaged Laptop
Attaching an external keyboard does not help because the keyboard controller is damaged.
I recommend you put your money towards a new laptop as the cost of repair maybe too expensive or beyond repair. Most computer repair shop charge for a quote and may drop this charge if you go ahead with the repair.
If the hard disk is OK then I suggest you remove it from the laptop and insert it into an USB hard drive adapter case and use it as an external USB hard drive for backups and data transfer etc.
Mar 04, 2012 | Toshiba Satellite C650 series C655S9520D
When im typing on my keyboard it shutsdown my computer. For Example: I press the enter key and all the open programs close and the computer just shuts down. then im typing in an adress bar and get done...
It can be virus problem. Try to go in 'Safe mode with networking' (press few times F8 when computer start to get menu options). Download ESET (Nod32) Online Scanner:
http://go.eset.com/us/online-scanner
Scan your computer with repair option on.
After that update your Windows. If you can't do that from Microsoft, you can use AutoPatcher.exe utility:
http://www.autopatcher.com/downloads/
I don't think it is keyboard problem.
You have free AVG good antivirus for homeusers.
Aug 25, 2011 | Computers & Internet
When typing anything in either a search bar, email or word my PC starts to shut itself down. It happens often and is becoming a real problem. It's not the electrical plug in cable, there's no virus, it has...
Hello, i think the problem the pc is facing is from the keyboard, a key as been stuck down and whenever you press a certain key, it will give the command to shut down the pc. what you will have to do first is to restore the system by performing a system restore to the date the computer was working fine. if problem persist, you will have to do some clean up on your computer keyboard.If problem is still unsolved, you will have to reinstall another operating system,so as to troubleshoot the problem. i will want you to carry out the system restoration first.
Feb 16, 2011 | Dell Inspiron 1525 Notebook
Spilled liquid on keyboard, need to remove keyboard to try and clean up spillage. cant remove keyboard because of the power button
if the computer is on, u cannot remove keyboard for safe purposes. u can press cpu power button for a long time till the computer shuts down. this shuts down the pc safely. after the pc shuts down remove the keyboard. u can either clean it or replace with new one.
Feb 19, 2010 | Gateway M685-E Notebook
How do you lock/ unlock a keyboard
Press the "Windows logo key + U." This will open the ease of access center. Click on the "keyboard." It will say, "make the keyboard easier to use" next to it.
Select "turn on sticky keys" and "turn on filter keys." Select "save." Your computer will now only make sounds when the keyboard is hit.
Follow steps 1 and 2 to unlock your keyboard. Unselect the "sticky keys" and "filter keys" and click on "save
Lock your workstation. Press "Ctrl + Alt + Del." A blue screen or a box will pop up that has a variety of options, such as restart or shut down the computer. Click on "lock this computer
Lock your work station using the keyboard. Press the "windows key", it looks like a flag, and the "L" key at the same time. This will lock the computer. To unlock press the combination again.
Nov 10, 2009 | Computers & Internet
The keyboard works when it wants to.
the keyboard is bad since it has start malfuctioning. The best solution is to change the keyboard
Aug 10, 2009 | Ideazon MERC Stealth Keyboard
PC does not respond to mouse or keyboard
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Jan 05, 2009 | Computers & Internet
Stoped functioning
Normal 0 Turn the Keyboard over and locate the small reset/connect button on the back of the keyboard and press it. Then try to see if it is working. If not try pressing the button on the receiver and then on the keyboard.
If your having trouble with the mouse also,
turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps. Bud
Dec 03, 2008 | Microsoft K5100141 Keyboard
Dell OptiPlex GX260 PC Desktop Logo
71 people viewed this question
Alun Cox
