Question about JVC SR-DVM600
Final Cut does not recognize DVM600
Via firewire interface, I cannot capture mini-dv into Final Cut.
Has JVC resolved this problem? They don't answer my emails.
Thank you.
  • 3 more comments
  • cinema Aug 22, 2008
    Yes, I have the same problem, not only with Final Cut, also with Adobe Premiere Pro CS3, using both Windows XP and Windows Vista.
    I think JVC should refund our money or fix the problem.
  • PatH56uwar6h Nov 13, 2008
    We made the mistake of buying at least thirty of these decks for our broadcasting schools. They do not work with Mac, FCP or Adobe.
    I see everybody else is having the same problem as well.
    What a big JOKE!
    I have yet to read an answer or solution from JVC.
  • Anonymous Jan 26, 2009
    I have the same problem, final cut doesnt recognize the player, who has an answer out there?
  • Anonymous Feb 17, 2009
    Same thing here.
  • tloehr Mar 02, 2009
    We have 3 such decks and now two are not recognizing the JVC SR-DVM600.  They had been working; now, all of a sudden, they are not.  The third one seems to be working fine and has done so for several months.
This is supposedly the formula to fix the problem of getting Final Cut to communicate with the DVM600: http://usjvc.com/faq/index.php?action=artikel&cat=6&id=26&artlang=en
My friend had to do this on his machine, but now that I'm borrowing his DVM600, I can't get it to work on either of my Macs.
Posted on Jul 12, 2009
JVC SR-DVM600 not recognized by Adobe Premiere Elements 4.0...
I HAVE SAME PROBLEMS AS FLUING PUFFIN ANY SOLUTION EMAIL AT tahirpm@yahoo.com
Jun 01, 2009 | JVC SR-DVM600
My JVC GY-HD111E isn't located in final cut pro
Are you using HDV, make sure you set the signal to DV on the camera. Does it have a signal out option to switch from video to dv / firewire? Have you checked to see if it is supported? Also just keep trying, turn camera on and off, restart the computer with firewire connected then without. I had this problem with a deck and it randomly started working after my 5th try.
Mar 28, 2009 | JVC GY-HD111E Mini DV Digital Camcorder
Jvc hr-dvs2
SO you actually got the S/VHS to capture via firewire into your computer? I can only get the DV side to work. I have the same unit with manual. I think your initial problem is a refresh rate, are you using Premiere? and can you make the viewing window smaller?
Nov 03, 2008 | JVC HR-DVS2 Mini DV/S-VHS VCR
I have jvc GR d720 dv camcorder but unable to connect .. driver required ... i have firewire send me in khairnar.abhijeet@gmail.com
No driver required for Windows XP. I simply plugged in the camera via FireWire. Windows automatically recognizes it as a digital video device. Then I started up Windows Movie Maker and followed the wizard to capture the movie from my digital video device. It was really easy.
Oct 24, 2008 | JVC GR-D720 Mini DV Digital Camcorder
MY JVC GY-HD100 Wont capture properly in Final Cut Pro. Always shows time code breaks where there are none. Only capture a minute or two at a time. What can I Do?
Are you shooting 24p? Make sure you're using the correct capture presets. DV NTSC 48k 24Pa (presuming you're shooting 24p advanced)
if this doesn't help, close final cut and delete your com.apple.finalcutpro.plist file from library>preferences. This should solve additional cadence problems.
Apr 08, 2008 | JVC GY-HD100 Mini DV Digital Camcorder
Driver in windows XP
Use this guide:
http://www.jvcpro.co.uk/getResource2/install_sr-dvm70.pdf?id=6345
It's for a different model, but it works the same.
In a nutshell, when the "AV/C Tuner" driver request comes up, just cancel the install. Then, it will want an "AV/C Tape Recorder/Player" driver. It "should" install automatically and be instantly recognized. If not, follow the instructions in the guide.
There are also instructions in there for disabling the "Av/C Tuner" every time the deck gets connected. Hope this helps - worked for me! - cliffpro.com
Feb 20, 2008 | JVC SR-DVM600
Unable to
HHHhhhmmmm. I'd suggest the DV mode and if you camera has the option to output DV as letter box select this, as it is a faster version to edit with (due to compression of HDV). I don't know the camera but VTR is just the playing mode, so play the file you want while trying to connect. Is the signal coming from tape? If it is catured to the harddrive of the camera you will need to import not capture.
USB does not support video, USB2 maybe.
I
Jan 11, 2008 | JVC Everio GZ-HD7 Camcorder
Cannot find driver for jvc GR-D720 Mini Dv digital camera please help!
If it's a JVC GR-D72, then it's MiniDV. Connect the camcorder via firewire to your PC
Dec 23, 2007 | JVC GR-D720 Mini DV Digital Camcorder
JVC SR-DVM600 Logo
721 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
