Question about Dell OptiPlex GX260 PC Desktop
Monitor not coming up
Whenever i start my computer the lights on the monitor blink 5 times and it doesnt turn on
  • lillacia Jul 10, 2008
    I have tried different cables. The monitor cables work on another PC. Monitor is not detecting computer. Would it be a graphics card problem?
  • 191 Answers
Try unplugging the monitor cable from the computer and check if you get a power on self test displayed
if yes then the monitor is fine we have to troubleshoot the computer
and if nothing is displayed the monitor needs to be replaced.
Posted on Jun 05, 2008
Planar monitor works but doesnt.
Try Another Monitor---If OK--Problem Is With Your Monitor---If Does The Same Thing--Problem With Computer Video.
Mar 18, 2015 | Planar Computers & Internet
I have a lcd monitor problem, it wont turn on. the little light thats suppose to light up when you plug the monitor doesnt light up.. when i press the power button the green light appears for a sec and the...
sounds like a power issue with the monitor. try to remove and reconnect its power cord. If same thing happens, try using a confirmed working power cord like the one you use with the computer and make sure you test it out using a confirmed working power outket. If it has the same issue, would mean you need to get a replacement monitor. Refer to the vendor if it is still in warranty.
Aug 31, 2010 | Computers & Internet
I have a samsung syncmaster 204T monitor. Everything was fine until last night when i kept my system on standby for approx 5-6 hrs. Now whenever i start my system there is only a green led on front panel...
I just started having the same problem! The green light flashes, but the monitor is blank. None of the button work (menu, source, etc...) and nothing changes when I disconnect it from the computer. I was suspecting a bad graphics card at first, but now I'm thinking the monitor itself is bad?!
Jun 29, 2010 | Samsung SyncMaster 204T Monitor
Monitor not working after adding drivers
1. turn off your computer
2. turn off your monitor
3. Unhook the power and video cable from both
4. Reseat them both on both ends.
5. Turn on your monitor
6. Turn on your computer
If its still doesnt work after all 6 steps, your monitor is bad, sorry.
Apr 02, 2009 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
Sceptre LCD monitor blank screen, blinking power light
Something has failed or is failing in the monitor. It may be serviceable, but may not be cost effective to do so unless something has just come loose. I'm assuming you have no problems with the new monitor. Your time line is a little confusing.
Dec 13, 2008 | Sceptre Dragon Eye D219A (White) 21 in.CRT...
Monitor light blinks
have you tested the power supply connection feeds? test each connector I think you will find your power supply has failed on either the 5 volt or the 12 volt side more than likely 5 volts are down' the agp adapter needs 5 volts to run. since you have changed out every thing else I would replace that or test your dads power supply in your computer, that should do the trick
Apr 28, 2008 | Samsung Syncmaster 730B 17" Flat Panel LCD...
PC or monitor, signal problems
your monitor is telling you it's on it's last legs..either that or your compaq has a bad video section. either is more vital than a video cable being loose.
Mar 10, 2008 | Computers & Internet
LG Monitor not working
You really must provide more details if you want a solution.
Try putting on the monitor without pc.If it works it's video card related issue if not a hardware failure in the monitor.
Samir
Mar 05, 2008 | Computers & Internet
Blinking monitor first 15 minutes computer is on...
I have this same problem. Try to disable the service ATI Hotkey Poller in the windows (you can use the msconfig). It seems to be all right for me now.
Good luck !
Luiz
Oct 13, 2007 | ATI RADEON X1300 Pro 256MB PCIE Graphic...
Dell OptiPlex GX260 PC Desktop Logo
116 people viewed this question
Alun Cox
