Help me keep my job
The conter on my copy machine, a Gestetner 6002 has suddenly jumped over 6000 clicks! My boss is accusing me of stealing copies, and I know I have not! Do you know why the counter could be off? Are there any issues with this machine? Please help me!
  • 1,326 Answers
There is not a way two turn it off, it is like your milage on your car. If you try to disconnect it, you will get a error code. You may be able to have a pass code put on it to lock it up. But, once the pass code is passed around it is, as if it was not there.. Good Luck
Posted on Jun 06, 2008
What causes error 12 on a gestetner 6123 duplicator
6123 gestetner digital copy printer no salve problum single line on copy. cleane complete scanner and thermalhead,
May 15, 2012 | Gestetner - AO40 Wide Format Copier Copier
Gestetner DSC 232SP: I purchased this copier used and it had printing ok. My color copies are coming out horrible. they are displaying a white line in the same area on page after page. Even after I ran a...
The white line or lines are NOT caused by the fuser. A defect "line" in the fuser would cause the symtom of the print rubbing off the page but not blank lines on your copy. First we need to separate your copy quality issues. This machine uses 4 drums, 4 developer units and a transfer belt. Most copy quality issues will reside in 1 or more of these units. Lets start with a few questions. 1)Are your copy quality issues ONLY on color copies? or are the black and whites poor too? 2) Are you running copies only thru the document feeder or have you made any copies from the glass?
Are you printing on the copier from your computer?
Dec 04, 2009 | Gestetner DSc232sp Copier
Gestetner 5308bt copy printer error after switching on E-01 call service - How can I fix it I am on a ship at present
This is a cutter error. Check the following.
Master cut error occurred
Cutter switch
Cutter motor
Cutter drive mechanism
Open the side the master is loaded. Check that the cutter is in the home possition and that there is no used master stuck in the machine. Check the motor by entering sp mode
Function clear "107" press and hold C/clear
"131" #
"23" Start key
will return cutter to home position.
Press funtion clear to exit.
If the motor is not running you will have to replace it.
Nov 13, 2009 | Gestetner Office Equipment & Supplies
Gestetner 3245 get lighter wen run 50 to 100 pgs
the amchine runs a density patch every 50-75 prints if you run long jobs it cannot run patch till job is finished which is why your copies get lighter the longer the job
Jan 14, 2009 | Office Equipment & Supplies
Scan multiple pages to one file on gestetner 6002
I apologize but this is a little to tricky to explain here....
below are guides and information on how to set up and operate a Gestetner machine,
which will help you to sort out every thing..
This is the Gestetner Site to download manuals, user guides..
http://www.gestetnerusa.com/SupportDocumentation.html?OpenForm&zone=ZIDTDIE-54FRT7GE51&NavExpand=0
This is the Scanning Guide
http://www.gestetnerusa.com/manuals/savin/SavGestOpManuals.nsf/(All)/GX60027502ScannerReferenceScannerReference.html/$file/Scanner%20Reference.pdf
Oct 27, 2008 | Gestetner Copier
Gestetner 6002?
you can down load a user manual for the machine at www.gestetner.co.za
Jul 29, 2008 | Gestetner Copier
Cannot print from Tray 1 in Gestetner 6002
First make sure that the machine is reading/ seeing the paper size of the paper that is in the tray ( select tray 1 from the touch screen and see what the paper size reads). If the machine sees a different size then that in the tray, use the 'user tools' and change the paper for that tray. Also, go into your printer settings on/in your computer and make sure that the proper paper size is selected ( the size that is in the tray you want to print from). If the orientation of the paper size is different from the tray -- will not print and give you the error.
May 06, 2008 | Gestetner - 6002 Digital Imaging System...
Gestetner DSC530 -- Auto Document Feeder
Normally the cable from the doc feeder has come out. Turn the machine off unplug the cable from the DF to the machine then reinstall it should click turn the machine on then try.
If this doesn't work open the DF cover and check that there are the paper detect fins also when the cover is open then the machine should register a cover open this will tell you if the DF is recognized or not.
Thanks J
Dec 13, 2007 | Gestetner DSC530 All-In-One Laser Printer
55 people viewed this question
k24674
jasbo
jasbo
