Question about HP Compaq Presario V2000 Notebook
Hard Drive Installation
Installing Seagate Momentus 5400.3 120 GP. Need connection adapter.
    Guru:
  • 61 Answers
Hola yo tengo una Lapto Dell inspiron 1521 la cual me pra esenta el mensaje que no puedo escuchar musica ya que los drive de sonido no estan instalado necesito que me ayuden a instalarselo attm franklin taveras de rep. dominicana
Posted on Jun 05, 2008
I pulled the seagate 2.5"
When you use external adapters to plug drives into USB ports the drive needs to be set for mast not slave. The internal drive is one one channel and external drive is on a different channel so neither drive is a slave, both are masters with not slave drive present. Try removing the jumper you installed and try the drive, it should be seen because all windows XP or later do not need drivers for USB drives.
I hope this helps, if so please rate my solution.
BuddyMc
May 06, 2011 | Seagate Momentus 4200.2 100 GB Hard Drive
Hi, I need a SEAGATE MOMENTUS 5400.2 ST98823A 80GB
check with a good local computer shop. WE (fixya)have no idea who might sell those parts
Nov 02, 2017 | Seagate MOMENTUS 5400.2 - HARD DRIVE -...
My seagate momentus 5400.2 external hard disk can't be detected by any computer. doesnt show up in the device manager, or anything. the light is on, for some reason, sometimes it blinks red/green,...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 12, 2010 | Seagate MOMENTUS 5400.2 - HARD DRIVE -...
I was given a seagate momentus 5400.3 hard drive and i want to use it as a external usb drive i bought an external case for it and plugged it into my laptop, it see it but in device manager i am getting a...
Try connecting it to a different computer.
EXACTLY what error-message do you get?
When you double-click that entry in Device Manager, and click "reinstall drivers", allow Windows to connect to the Internet to look for a device-driver for the USB-to-disk-drive adapter (no device-driver is needed for the disk-drive itself).
Dec 11, 2010 | Seagate Momentus 5400.3 Hard Drive
I have a seagte momentus hard drive, need master password
you will haveto ask seagate forthat information
Oct 07, 2009 | Acer Aspire 5100 Notebook
I need the driver for your momentus 5400.2 hard drive
U have install all drivers properly in ur hard drive it can be work properly
Jul 11, 2009 | Seagate MOMENTUS 5400.2 - HARD DRIVE -...
A larger capacity replacement drive for my st380020a 80gb drive
The IDE version of a 160gb is a:
Seagate Momentus 160GB IDE Laptop Hard Drive
Part Number: 9S1034-506
Model Number: ST9160821A
5400RPM
The SATA version is a:
Seagate Momentus 7200.2 ST9160823AS 2.5-inch 160 GB hard drive
Jan 31, 2008 | Computers & Internet
Seagate momentus 3 60gb problem
What software did you use for the cloning?
Ghost is the preferred method.
Be sure to choose a disk to disk clone, not a partition clone.
It sounds like you may have created a 20G partition and left 40G unallocated.
Partition Magic may also take care of the problem, if you have access to a copy.
Oct 16, 2007 | Seagate Momentus 5400.3 Hard Drive
HP Compaq Presario V2000 Notebook Logo
120 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
