Question about Whirlpool Duet GHW9150P Front Load Washer
Manual Release dont find a manual release.
  • 770 Answers
Post your email i will send you the sheet on it
Posted on Jun 09, 2008
    Genius:
  • 1,028 Answers
If you're talking door release ..remove bottom panel reach up to lock location pull down on tear shaped plastic tab
Posted on Jun 07, 2008
My wash/dry cycle has finished but I can't open the door. Is there a manual release please?
turn the dial and listen for a click to release the door. no their is no manual release
Jan 06, 2015 | Electrolux Washing Machines
Manual release on door lock of a bosch nexxt series 100 washer
Try pulling door up before out. My washer does this when the rubber around the door gets a piece of wet paper under it, or I have overloaded it and the rubber gets moved. Once open, run your fingers around the rubber seal to verify nothing under it and that it lays smooth.
Jan 03, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
My washer door is locked. cant open
If the door remains locked and you cannot open it, this could be a momentary program glitch. You can attempt to reset the Central Control Unit (CCU) by unplugging the washer for AT LEAST 30 minutes. If the door still remains locked following a CCU reset, there is a manual release you can use to open the door. The following link explains how to access the release:
http://www.fixya.com/support/r3576511-door_jam_on_kenmore_elite_and_whirlpool_
In many cases, operating the manual release will return the door latch to normal operation. If you still experience problems, or have any indications of error codes on the front panel display, please post back and let me know. I hope this helps you.
Jun 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer locked. door lock light blinking. start button light on. won't do anything.
IT IS POSSIBLE YOU HAVE A DEFECTIVE DOOR LOCK OR CONTROL BOARD. CHECK YOU OWNERS MANUAL TOO SEE IF YOUR WASHER HAS A MANUAL RELEASE SO YOU CAN OPEN YOUR DOOR. USUALLY YOU CAN ACCESS A MANUAL RELEASE BY REMOVING THE FRONT BOTTOM PANEL AND REACHING UP UNDER THE DOOR LOCK AND FINDING A PLASTIC PULL PIECE WHICH YOU CALL PULL AND UNLOCK THE DOOR. MAKE SURE YOU UNPLUG THE WASHER FIRST. CHECK THE DOOR LOCK MECHANISMS TO SEE IF ANYTHING IS BROKEN AFTER YOU GET THE DOOR OPEN.
Feb 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Electric door release stopped working
does it not have a manual door release pull next to the filter
Aug 05, 2009 | Asko W600
Kenmore elite dryer 110 8772 He5 lights up, will not start no error codes. Brand new del today! Worked when tech tested it
MANUAL DIAGNOSTIC TEST
The washer must be empty and the control must be in the OFF state before pressing the touch-pad sequence to start the test.
Starting the Test Mode
-Close the door.
-Select any one key (except STOP) and follow the steps below, using the same key (remember the key):
Press/hold 4 sec's.
Release for 4 sec's.
Press/hold 4 sec's.
Press/hold 4 sec's.
Press/hold 4 sec's., release
NOTES:
-Press the same key to advance to the next failure code.
-At the end of the procedure the program will loop back to the beginning. This is a continuous loop.
-To cancel out of the Manual Test Mode press STOP.
Exit Condition Control Action To be Checked
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 01, 2009 | Kenmore Elite 45986 Front Load Washer
Duet washer door locked
After pulling the manual door release by removing the bottom door panel you are able to add 1 cap (1 tbsp) of liquid cooking oil to the water. The cooking oil will greatly reduce the amount of suds so you can complete the cycle.
Apr 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Removing the pump access cover
Half turn is usualy all that is needed - now pull filter away - you may find a slight turn back will release will align filter with its release points. (Dont use pliers as you may damage)
Apr 04, 2008 | Hotpoint Ultima WF860 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
50 people viewed this question
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
