Question about Acer Aspire™ T180 PC Desktop
Installing memory I'm trying to install more memory . I have 1gb in computer now and want to add another 1gb after installing I turn computer on the monator is fuzz. I have 4 slots for the memory 2 purple and 2 orange. were should I put the memory at?
This computer requires that memory be installed in pairs. You probably have 2 512k ram modules in there now. Put an additional matching modules in the 2 remaining slots.
crucial.com is a very helpful site for memory compatibility and installation issues.
Posted on Jun 06, 2008
    Producer:
    Uploaded 30 video answers.
  • 95 Answers
HI 1008 ,
It is very important to know which branded machine you have ; whether it's Dell , HP etc. I would also require to know the model number and whether you have a Desktop machine or a Notebook.
Anyways , here's a generic guide for your help...
http://www.helpwithpcs.com/upgrading/installing_dimm_memory_ram.htm
Goodluck :-)
Posted on Jun 05, 2008
  • Hardeepak Bhambh
    Hardeepak Bhambh Jun 05, 2008
    OOPS.... my bad.... I checked it later.... you have a Aspire T180 PC Desktop.
    Things You’ll Need:
    • A small flat-head screwdriver
    • The correct memory card update for your computer.
    Step1
    Turn off the computer and remove all cords
    Step2
    Find memory panel
    Turn the computer in a lateral position. locate the panel which allows you to
    access the RAM modules(PLEASE NOTE.... INSTALL THE 2ND 1 GB RAM IN THE SAME COLORED SLOT AS THE DEFAULT MEMORY IS INSTALLED),
    Step 3
    Static electricity can kill computer parts so before touching anything
    inside the computer you should ground yourself by touching something
    metal such as a lamp or table leg.
    I
    Step 4
    You may need to push hard as it can take 20 - 30 pounds of
    pressure to install.
    Once the RAM has been pushed into the slot as far as it goes, gently push it down until the clips click into place
    Step5
    When the memory panel is secured, flip the computer back up the right way, plug in the power cord and boot it up.
    Step6
    If the laptop does boot up correctly, click on Start, Control Panel, System and Maintenance, System.
    Step 7
    On the screen you will see how much ram is installed. It should be the updated amount of ram that you just put in.
    Step8
    If your computer does not boot up, if you receive an error message or a
    series of beeps then your COMPUTER may not have recognized the new
    memory. Remove and reinstall the RAM to make sure that they are
    securely inserted into the slots.
    If
    you get a memory mismatch error, follow the prompts and enter your
    computers setup. Then select Save and Exit. This isn’t always an error,
    a lot of laptops require this to install new RAM.
    When you start
    the aspire you may get a message prompting you to update your
    configuration settings. If you press F1 to continue and save, it will
    recognize your new ram.
  • Hardeepak Bhambh
Can I remove ram from acer aspire 3003wlci to add to toshiba satellite p205d-s7454. The acer is pc-2700 and Toshiba is Pc2-5300 200 pin DDR2. Is sticking a USB 1gb readyboost the same as installling 1gb?
To answer your question, no. Those RAM types are not compatible as they are a full generation apart in terms of a RAM lifecycle.
And to answer your question about Readyboost, no. Installing a 1gb flash drive to use with readyboost isn't the same as installing an extra 1gb of internal system memory. It essentially allows Windows to use the newly added flash drive as a system cache. See more information on Readyboost here.
Thanks, and have a great day!
Oct 03, 2011 | Toshiba Satellite P205D-S7454 Notebook
I am trying to install two 1gb ddr pc2-4200u ram into my Dell Dimension E310 desktop. I currently have two slots, I removed the original 256mb stick to make room for my two 1gb sticks. When I boot the...
I belive the problem is caused due to non compatible memory being installed . According the Dell documentation the memory specification is as under
333- and 400-MHz DDR SDRAM
1Gb Non-ECC on each slot.
Just check the speed of the memory you are trying to connect.
Dell Documentation
Thanks for using Fixya
Proton
Aug 30, 2010 | Dell Dimension 3000 PC Desktop
My computer does not work with two 2GB RAMs
I think, one, out of the two is defected. Make pair with other memory or try changing the slots and vice versa. And for dual channel memory mode, you must installed two identical memory. I mean sizes and makes may different, but bandwidth should be identical to each other.
Jul 30, 2010 | Intel DG31PR Motherboard
Just bought 1 gb of ram for dell b130. When i turn on the computer the cap and scroll lock lights flash and computer just turns off
this problem is down to mismatched ram. did you install the new 1gb of ram with the ram that was already in the laptop. if so you will just have to ues one or the other. hope this helps. leave feedback
Jun 21, 2010 | Dell Inspiron B130 Notebook
I want to increase th DDR in my emachines T2682. how much can i increase it and do i have to make any changes.?
Go to this trusted site I use all the time. http://www.crucial.com/store/drammemory.aspx Click "Scan My System" accept the download of the scanner. When it finishes it will tell you what you have and what you can add, with the cost of all options. They have good prices and are very safe & reliable. From your model # unless changes have been made you have 256MB of Ram which is far to little for XP to run like it should. This is the bare minimum for XP. Buy and install at least 1 GB of RAM. It is a simple process and you will have to make no changes to the system. Once you install the new RAM and turn the computer back on it will recognize the new memory. Follow the directions for installing the Ram and make sure to wear a ground strap or ground yourself to the exterior of the case before touching anything inside. Crucial has a section on installing RAM which you should look at if you have never done it before. Your XP will fly with 1 GB of ram and this is the best money you can spend to make it faster. I checked their site using the model # your listed and you are in luck. You can purchase 1 GB of RAM, which they have on sale, for $38.99. You have 2 slots in your computer and you will be able to leave the 256 MB intact and add the 1 GB giving you 5 times the Ram you now have. You can see the results here. http://www.crucial.com/store/listparts.aspx?model=T2682&pl=eMachines&cat=RAM
Feb 12, 2010 | E-Machines T2682 (000002965) PC Desktop
I intend to install more 1 mega of memory, but motherboard not recognized it (one dimm 1gb pc3200 cl3 184-pin dimm). Of origin the PC it has been installing 2 dimms of 512 and I intend to add +1 dimm of...
The memory may not be compatible depending on the speed. Try taking out all the memory and just installing the 1Gig stick.. does it work?
If it does then the 1Gig stick is fine, but your PC probably doesn't like you mixing different types and speeds of memory.
If it doesn't work, the 1gig memory module might not be the correct speed your PC wants.
Sep 08, 2009 | Computers & Internet
Having a problen installing 1gb ram. unit is 1gb ddr2 dimm 533mhz. computer turns on, shows that it has updated the memory, but does not boot
if the computer states that the memory has been recognised. but fails to boot. it may not be compatable memory for your CPU/Processor. Or system bus. check your previous memory stick, to ensure it,s the same running speed 533mhz. Failing this if your computer does not support this.
check the manufacturers website, to see further details:- Maximum supported memory/Speed et,c.
Systems bios date, and whether an update is available. your only other alternative is to install 2 x 512mb sticks of Ram.
Mike @ compurepair.
Jun 11, 2009 | HP Compaq dc7600 Small Form Factor PC...
Cant install full 2GB of memory in my emachines t3990
try removing the cmos battery and put it again and booting up.. since you have bought same kind of ram i dont think it could be a problem.also check for the jumpers in *********** board where you can reset your bios. be sure to read *********** boards manual before this
Feb 10, 2009 | E-Machines T3990 (RBT3990) PC Desktop
Won't Reboot after installing new RAM
If you remove the 1GB memory that you were trying to install and it will boot, then it is your new memory that is not compatible. Check here for what memory will be compatible with your laptop.
Jan 02, 2009 | Dell Inspiron 6400 Notebook
Installing 1GB Memory
the problem is will your processor read 1GB of random acess memory. install you open the laptop remove the screws and access the mother board push down the usually white clips and lift the ram straight out, when installing make sure you ease the stick into the socket and when you have it against the bottom push it firmly until the clips lock back into place.
Dec 09, 2007 | HP Compaq Presario V2000 Notebook
Acer Aspire™ T180 PC Desktop Logo
122 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
