Question about IBM (49P1605) Motherboard
Motherboard when ever I move the screen or laptop, it shuts down, is it a motherboard issue
  • 530 Answers
Hi! im josh in cebu phil. It is a simple frnd. It is not a motherboard problem. it is just a flex cable of your monitor.you need to align it very well and tighten it a little to fit exactly.it is just loosen connections. hope it i helped your.thy good luck.
Posted on Feb 13, 2009
Vertical lines on laptop screen
problem with either display or the display cable...call cust service to diagnose and fix the issue
Mar 15, 2014 | Dell Studio 1555 laptop
My del studio laptop doesn't shut down
You could have a corruption in the script or a process that won't stop. Try holding down on the power button until the screen goes dark and all lights go out. That is a hard shut down without saving settings. After it shuts down (finally) power it back up. Hit the F8 key on your keyboard the moment your machine goes to the black screen before it can load windows. That is the safe mode. Move the highlight up to safe mode or safe mode with networking and allow it to continue to boot up. Then, when it's completed the process and windows displays that it is in safe mode, do a normal restart. That should resolve the issue.
Oct 22, 2013 | Dell Studio 1737 Laptop
Acer Aspire One D255-2256 will boot and shut down but when shut off screen turns white until I unplug AC Adapter. I can power back up and boots but when shut down as long as AC adapter is plugged in screen...
Graphics chip may have failed. If screen is white there is no information being sent to the screen, but the backlight is working fine. The Graphics chip may not be replaced, but the motherboard replacement is the usual fix for this issue. There may also be a loose cable beneath the case above the keyboard, which connects the screen to the motherboard.
Sep 28, 2013 | Acer Computers & Internet
My compaq pc notebook is dead. The power light is on and i can hear the cd click but screen is black and won't load a cd either. then the computer shuts down completely and tries to boot up again. I did...
Base from the description of your problem , this seems to be a motherboard failure already. The blacking out of your screen before this problem started is a sign of something on the motherboard is already failing.
Now since the computer will just power ON and automatically shut itself down is definitely an implication of motherboard and processor failure it can be due to overheating problem, so if you want to continue using this laptop a motherboard replacement is needed, you can take replace it by yourself if you have any experience doing those kind of things but if not better take it to a repair shop or better yet do a upgrade and get a new laptop then.
Oct 08, 2010 | Compaq Presario R3000Z Notebook
Shut Down and Reboot With No Display
I can tell you, screen issues are one of the problems that goes with a laptop that is GOING TO FAIL OR ALREADY HAS FAILED.
I have this model laptop in the F500 series and mine has already failed.
Go to hplies.com and you will see almost 2,000 users with the same issue. The problem lies with the nVIDIA GFX chip on the motherboard. THE ISSUE IS UNREPAIRABLE. Any repairs will force the laptop to fail again.
This issue has actually landed me in small claims court where I am suing for hte full cost of this laptop because not only is hte laptop defective, nVIDIA admitted it, and HP covered it up.
Join us at hplies.com and we will give you the know how to get this issue fixed/your $ back. We even have links to all of the information!
Send me a PM if you want more assistance.
Dec 23, 2009 | HP Compaq Presario F500 F700 and G6000...
Bought a HP Pavilion 17'' P8600 6GB 500GB nVIDIA GIGABIT LAPTOP. When I start it up after a few minutes it shuts down. this is when power lead is plugged in and also when it is unplugged. Does this model...
When you say it shuts down, does it simply turn off straight away? If so I would say it has a faulty power connection. If it goes through the whole 'Windows is shutting down' processes then it maybe the motherboard which is faulty. Either way it sounds like quite a serious issue.
Nov 21, 2009 | HP Pavilion dv7-1130us laptop
My imb t40 laptop keep getting a black screen if it get moved or bumped a lil
Your issue is Board Flex... The t40/t41 have a split mid section and over time the lifting of the laptop from the base will flex the motherboard which can create a short in the layers of the board, it can also lift the heatsink from the graphics chip which will trigger the thermal controller,
put pressure on the palmrest area to the left side of the touchpad.. then attempt to move the laptop.. see if it stops the shutting down
Nov 15, 2009 | IBM ThinkPad T40 2373 Notebook
I have a Dell Inspiron 1520 laptop. Fan has gone
that is absolutely right i work for the same and we charge $49 If you bought the sys. after sept. 2004. and you are out of warranty.***let me know what is the blue screen all about.and stop erros code with 0x000000** this blue screen will help us to understand the issue. and i can help you to resolve your issue.
Nov 06, 2009 | Dell Inspiron 1520 Motherboard
IBM thinkpad t41 screen goes blank after being used for about 5 minutes. Could it be a motherboard issue?
If the machine keeps running it might be your inverter or your backlight for your lcd screen. Next time it happens take a flashlight and hold it at an angle near your screen. I f you can see an image it's your screen that's having the problem. If the laptop is shutting down after 5 mins it could be a heat issue. Make sure all the vents are clear and the fan is running. If all those things are working then it could be your motherboard.
Mar 26, 2009 | IBM ThinkPad i Series 1412i Notebook
Vertical lines, screen freezes, laptop shuts down
it most likely doesnt run on windows me so that theory is out.Take it to dell or call someone to fix it
-CG
Jan 24, 2009 | Dell XPS M1330 Laptop Computer PC...
Computers & Internet Logo
62 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
